Author Topic: Signal 6610i  (Read 853 times)
Offline lorwin04
Signal 6610i
« on: July 17, 2009, 12:34:54 AM »
Ask Ko Lang Poh Panu Ang Pwede Kong Gawin Pag Walang Na Signal Ang 6610i?
And Last Option Is Jumper Diba? Panu Poh Gawin Un?
Thenks In Advance!
Signal 6610i
Offline Ugin
  • Pogi/Ganda Points: 48
Re: Signal 6610i
« Reply #1 on: July 17, 2009, 07:13:05 AM »
First, determine mo una kung ano ang hindi nagpa-function sa phone mo, if the transmitter section or reciever.
For reciever, go to setting, network and set it to manual not auto. If phone found network, then reciever is ok. Pag walang makitang network it means reciever is not functioning.
You can check TX by pressing # then call button. Go to a nearby radio or TV, kung may interference sa TV or radio coming from your phone, then TX mo ok, if not Tx section is not functioning.
Re: Signal 6610i
Offline amp
  • Pogi/Ganda Points: 11
Re: Signal 6610i
« Reply #2 on: July 17, 2009, 07:58:07 AM »
Thenks In Advance!
you can used HWK to check kung san ang trouble just run selftest.
Re: Signal 6610i
Offline lorwin04
Re: Signal 6610i
« Reply #3 on: July 18, 2009, 10:40:27 PM »
Oo Panu Poh Ang Gagawin Pag Ayaw Lahat Magfunction?
I Mean Wala Talaga? Time Na Ba Para Sa Hardware?
Paturo Naman Ng Jumper Settings?
Salamat Poh!
Re: Signal 6610i
