Author Topic: Sir patulong sa Project Study for EE  (Read 11699 times)
Offline edwardcaezar
« on: July 19, 2009, 02:47:57 AM »
Sir baka my idea po kayo n pwede ishare para sa PS namin. malapit na po title defense pero la p po kami idea. Sabi ng prof nmin wag na daw about sa programming. Im a electrical engineering student of T.U.P.. 5th yr na. madami na din kc existing project sa school. di ko nmn gusto na mag modify kami ng existing. cguro pwede yun pero last option. baka po my mga possible ideas kayo mga sir, na pwde lang sa level namin ngayon. gusto ko nga sana yung makakatulong sa problema ng community, country, or environment ngayon. ;D
salamat po sa inyo mga sir....
Offline ♪ ♫ ♫ ♪ ♪ ♪ ♫ ♫ ♫
Re: Sir patulong sa Project Study for EE
« Reply #1 on: July 19, 2009, 09:43:02 AM »
Try this if u want..... di ba sa Power Systems halos lahat ng equipment (generators, transmission lines, power transformers etc) ay protectado ng relays, like Device 21s, 50/51s, 87Ts, 64Ts, etc... lahat ng ito ay DC supply powered at may back-up na battery banks di ba?
How about pag nag fail ang DC supply at nag fail din ang Battery banks back-up?
A simple cut-off or detachement or eroded DC main cable can do this. And if this happens a great fireball  :o  is going to happen anytime in terms of mS  before it can restored .....
The idea is to have a third line of defence that is simple One-Shot Capacitor Charge Back-up ...always ready to trigger the breaker in case of DC supply failure.....
« Reply #2 on: July 19, 2009, 10:29:53 AM »
Ganun po? di p po namin sir natatackle sa power sys yun sir. ngayon ko lang po yun nalaman sa inyo sir. ano po ba yung mga device na yun sir? ano rin po yung capacitor back up? pano po naging ckt protection ang Capacitor? pano po cya gagana sa system incase of trouble? di p po ba nag eexist it sa industry? sir pasensya na po kung matanong. kasi interested po ako. parang magugustuhan po yan ng panel namin.. tenks sir..
Offline elastance
« Reply #3 on: July 19, 2009, 11:34:02 AM »
try mo din "power factor correction"..concept nya is usually capacitors are gmitin pra ma change ang power factor..
since walang variable power capacitor na available so instead ang gawin mo ay mag layout of several capacitors in parallel..each capacitor has two terminals..one of these two terminals of each capacitor will be connected in common. the other terminal will be connected to a relay switch..
take note that these capacitors can be connected and disconnected to the power line automatically by an MCU.
the idea is to connect the capacitor to the power line by simply activating the relay.. different combination of capacitors connected in parallel will change the power factor.
one problem you might want to solve is how to correctly select which of these parallel capacitors will be connected to the powerline that will properly correct the power factor.
« Reply #4 on: July 19, 2009, 01:01:48 PM »
A! wala pa ba sa power system subject ang mga ito? Wala pa itong Capacitor Back-up sa mga existing power system natin sa ngayon, madali lang sana siyang gawin kaya lang, pag-wala ka pang background sa Power System Protection parang mahihirapan ka yatang e depensa ito.
Matanong ko nga pala ano mga topics sa PS subjects nyo?
Yang suggestion ni "Transformer" na Auto-Power Factor Correction okay din yan.....
Kung gusto mo simply lang pang-masa, convert sa Electronic ang nakasanayang Thermal Fuse sa mga bahay natin? Medyo mahirap siya, pero madali namang e depensa....
« Reply #5 on: July 19, 2009, 09:16:13 PM »
@ transformer
Sir maganda po yun ah. maraming salamat po. sir ano po ba ung MCU? pcncia na po ah correct me if im wrong sir, microcontroller po ba ung ibig sabihin nyo dun sir?
@ XXx
Sir, wala nmn po topic na binigay. kc sir since electrcal students kami, gus2 ko sana yung sa electrical side lang. parang ayoko po nung electronics at programming. pero pwede po yun cguro sir last option na yun.
sa power sys nmin sir nsa computation palan kami ng strands ng cable wires. nagdedesign palang din kami ng  commercial, residential, industrial. sa electrical design 2 naman po nasa power plants palang kami. yung mga hydro, thermal, wind.
Mga sir tenk you po ha. dalwang titles na agad yun. maraming salamat tlaga.
Offline elastance
« Reply #6 on: July 20, 2009, 08:42:07 PM »
@edwardcaezar
student pa ako..same tau electrical engineering 5thyr din..yup its a microcontroller..try mo good thesis yan..kailan ba proposal nyo?
« Reply #7 on: July 20, 2009, 10:54:55 PM »
@transformer
sir, last week po ng august ang title defense.
 ah sir, my existing circuit po ba kayo? pcncia na ho ha kung mejo makapal muka ko. pwede po ba pasend sa email? edward_caezar@yahoo.com. ah sir, ang " power factor corrector " po ba hindi babad sa linya? di pa po kasi yan natatackle sa power sys namin, kahit po sa Enercon di din.
sir tenk you po..
« Reply #8 on: July 21, 2009, 11:29:26 PM »
Up po
« Reply #9 on: July 25, 2009, 06:49:19 PM »
@sir Transformer
Sige po sir antayin ko yung circuit
Offline elastance
« Reply #10 on: July 25, 2009, 09:39:07 PM »
sira kasi monitor ng pc ko di ko ma open ang file..
« Reply #11 on: July 25, 2009, 10:25:40 PM »
kung gusto nyo 5n1 na proteksyon ng linya- OverVoltage, UnderVoltage, TimeDelay, OverLoad at OverCurrent (definitetime nga lang)
Discreet components lang, Op-Amps lang at Monostable na time delay.
Kung gusto nyong dagdagan ng GFCI okay rin kaya lang hindi ko pa tested, yong lima pa lang.
« Reply #12 on: July 25, 2009, 11:59:44 PM »
@sir transformer
sir ok lang po antayin ko
@sir XXx
sir my circuit na po ba kayo nito? pwede ko ba makita para mapag aralan. wala pa po nakakagawa sa amin nyan sir..
@sir XXx at Transformer
Maraming salamat ho sa inyo, Taga san ho ba kayo, para malibre ko kayo kahit pang lunch lang. :) salamat mga sir
« Reply #13 on: August 22, 2009, 12:22:59 AM »
@ edwardcaezar
Yong request mong explanation sa circuito, kung gusto mo dito nalang sa thread mo para pag-nagkamali ako may ibang makaka-correct okay.....start tayo Bukas, from transformer to relay contact line clearing.
« Reply #14 on: August 22, 2009, 01:04:06 AM »
ok sir!! Tenk you po!!! salamat po ng marami!!!
« Reply #15 on: August 22, 2009, 09:23:50 AM »
hehehehe....papaano ba tayo magsisimula nito?  ???
okay magsimula tayo sa begginning... ;D ;D ;D
« Reply #16 on: August 22, 2009, 09:31:25 AM »
Ang project ay isang electrical proteksyon device, pinuprotektahan niya kung ano mang electrical components/equiptment or appliances sa mga abnormalities na kadalasang nangyayari sa ating electrical system sa bahay.
« Reply #17 on: August 22, 2009, 09:49:40 AM »
Sa ngayon almost hundreds of electrical protection devices at schemes ang available na sa market, thanks to electronics MCUs and MPUs, pero ang pika-common sa lahat na angkop sa ating electrical system ay ang mga ito:
1. Over-Voltage Protection - ibig sabihin, proteksyon sa pagta-as ng boltahe sa nakasanayang sukat nito, na hindi kakayanin ng mga electrical/electronic na gamit natin sa bahay. Kadalasan sisirain nito ang mga gamit natin dahil sa over-fluxing ng mga transformer components sa mga gamit natin sa bahay. Sanhi din ito para magkaroon ng insulation failures ng mga components na rated lang sa standard voltage natin.
« Reply #18 on: August 22, 2009, 10:10:00 AM »
2. Under-Voltage Protection - proteksyon ito pagbumaba ang boltahe natin sa nakasanayang boltahe ng ating mga gamit sa bahay. Pagbumaba ang boltahe natin sa bahay, tataas naman pangangailangan ng kuryente ng mga eletrical/electronics na gamit natin sa bahay. (constant P = variable V X I). Kadalasang epekto nito ay over-heating dahil sa hindi makayanang daloy ng kuryente sanhi ng pagsira ng ating mga electrcal/electronics na gamit sa bahay.
« Reply #19 on: August 22, 2009, 10:20:59 AM »
sir kakabukas ko lang ng PC. Gud morning po.
