Author Topic: Sino meron PIC LF series?  (Read 1286 times)
« on: July 20, 2009, 11:32:12 AM »
I'm looking for LF series PIC 16LF88 sana kasi may gagawin lang me projects that needs only 3V of power. Bka nman meron kayo dyan at least 5pcs. PM for price and delivery method and charge.
Thank you po.
Offline Mayalin22
  • Pogi/Ganda Points: 400
Re: Sino meron PIC LF series?
« Reply #1 on: July 20, 2009, 02:25:27 PM »
sister iba-burn nyo po ba sa 3v
Baka pwede po burn nyo sa 5v tapos run sa 3v
Offline macky
  • Pogi/Ganda Points: 51
« Reply #2 on: July 20, 2009, 02:37:40 PM »
^i think run-time yung required 3V supply nyan and not only for burning. LF talaga need ni sir malditah
john 3:16 | oil of gladness
Offline Mayalin22
« Reply #3 on: July 20, 2009, 02:47:22 PM »
option lang po yung sa akin  kung wala syang makitang LF  ;D ;D ;D
it can run kc as low as 2V ang 88  ;)
Offline macky
« Reply #4 on: July 20, 2009, 03:09:08 PM »
^sorry po kung di ko po makuha yung point ninyo... ;D ;D ;D
eto po kasi yung nasa datasheet ng F88:
yun nga pong "LF" series ang may minimum supply voltage na 2V to run.
Offline Mayalin22
« Reply #5 on: July 20, 2009, 03:32:23 PM »
so mali pala datasheet ko tsik tsik tsik ;D ;D ;D
Taken from Pic16F87/88 datasheet
Low-Power Features:
• Power Managed modes:
- Primary RUN: RC oscillator, 76 μA, 1 MHz, 2V
- RC_RUN: 7 μA, 31.25 kHz, 2V
- SEC_RUN: 9 μA, 32 kHz, 2V
- SLEEP: 0.1 μA, 2V
• Timer1 Oscillator: 1.8 μA, 32 kHz, 2V
• Watchdog Timer: 2.2 μA, 2V
• Two-Speed Oscillator Start-up
Special Microcontroller Features:
• 100,000 erase/write cycles Enhanced FLASH
program memory typical
• 1,000,000 typical erase/write cycles EEPROM
data memory typical
• EEPROM Data Retention: > 40 years
• In-Circuit Serial Programming™ (ICSP™) -
via two pins
• Processor read/write access to program memory
• Low-Voltage Programming
• In-Circuit Debugging via two pins
• Extended Watchdog Timer (WDT):
- Programmable period from 1 ms to 268s
• Wide operating voltage range: 2.0V to 5.5V
Offline glutnix_neo
  • Pogi/Ganda Points: 165
    • Underground Workbench
« Reply #6 on: July 20, 2009, 03:43:50 PM »
Thank you po.
parang meron yata ako LF pero hindi yang 16lf88 (IIRC 28pins or 18 pins yun), nasa lucena. tingnan ko paguwi ko.
makikipagswap na lang ako ng ADC modules, or kahit isang bluetooth module ;D
« Reply #7 on: July 20, 2009, 03:48:21 PM »
Kahit ano, gusto ko lang sana 16LF88 kasi may built in ADC na. Di ko pa nabubuksan Bluetooth module ko pero willing ako makiswap. Meet-up na lang tayo sa lucena deretso EB na he he he
Offline glutnix_neo
« Reply #8 on: July 20, 2009, 03:52:02 PM »
ayun, malamang may builtin adc na rin yung pic ko, check ko rin baka naman andun sa bahay ko sa cubao, hehehe
mga aug2 ng hapon pa uwi ko hanggang aug3 ako dun,
« Reply #9 on: July 20, 2009, 03:56:33 PM »
Sunday ng hapon, pwede siguro ako nun.
Offline macky
« Reply #10 on: July 21, 2009, 10:46:27 AM »
Low-Power Features:
- SLEEP: 0.1 μA, 2V
data memory typical
via two pins
yan yung nasa harapan ng datasheet, that means "in general" pero yung difference ng may "L" ay nandun sa ipinost ko. kaya nga may "16F" at "16LF" dahil yun ang ipinagkaiba. ;D ;D ;D
