Author Topic: pano po i-interface ung rfid sa VB6? Please help..  (Read 937 times)
Offline bano_ako
  • uuhhh??!
« on: July 24, 2009, 10:28:35 PM »
pano po ba i-interface ung rfid sa vb6?
bale ung rfid ung magtitrigger para lumipat ng form1 to form2 sa visual basic..
salamat!!  ;D
don't talk when your mouth is full....
Offline TinTopHack
  • Pogi/Ganda Points: 154
Re: pano po i-interface ung rfid sa VB6? Please help..
« Reply #1 on: August 14, 2009, 01:29:26 PM »
First step, check what is the interface used by your RFID reader.
Usually - serial (RS232) yan. In some cases keyboard wedge interface.
Once you know the interface, you use the appropriate communication method.
1. Kung RS232 - you use MSCOMM
2. Kung keyboard wedge - you assume data is coming from the keyboard
In your form one, you use the appropriate method to check if data from the RFID reader
has arrived. Once detected you can load form2 and do what needs to be done.
