Author Topic: instant usb pic programmer  (Read 3324 times)
  • Pogi/Ganda Points: 412
Re: instant usb pic programmer
« Reply #20 on: August 01, 2009, 10:27:57 AM »
sumakit ang ulo ko sa hayup na HL-340 na yan! download ako ng driver sa CD-R King site mali naman...ito yung driver na napagana ko...
http://www.4shared.com/file/122091170/ed0b5be3/_2__CH341SER.html
Offline OPTIMUS PRIME
  • Pogi/Ganda Points: 28
« Reply #21 on: August 01, 2009, 11:36:48 PM »
@sario
Ayaw talaga sa wISP628 ko at ICD2........
Try ko tom yung recommend ni Kasamiko....
Offline SArioDabidG.
  • Pogi/Ganda Points: 7
  • Gawa lang ito ng tao. Kaya natin ito!
« Reply #22 on: August 02, 2009, 04:18:05 AM »
...ano kaya problema niyan...sa wisp pareha lng naman pin gamit sa serial...sa icd2 di talaga gumagana ang tm-1061
"One way to back-up your codes is to post them in forums and let others store them for you."
« Reply #23 on: August 02, 2009, 10:04:28 AM »
sa software mukha pede din mag cause siguro
Offline drx2k
  • Pogi/Ganda Points: 15
    • Drx2k Network
« Reply #24 on: August 19, 2009, 12:46:52 AM »
malapit ko na rin mabuo at masubukan itong programmer from ohonsoft..
kumpleto na rin ung mga component na kailangan at tapos ko na rin nmn yung pcb layout nito
sana nga lang di pa sira yung pic16f628a ko..
may tanong lang ako, pwede ba na di na i-connect yung lvp sa pgm ng mcu?
sa layout na ginawa ko, di ko na nailagay yung lvp
tpos ung 78L012 at 78L05, pinaltan ko na lang ng LM7805 at LM7812, since parehas lng sya na voltage regulator ang pagkakaiba lang ay ung rating ng current..ayus lang diba yun?
« Reply #25 on: August 19, 2009, 12:57:45 AM »
tried the parallel programmer of oshonsoft na 5 pins lang (without the pgm). working naman....
ok lang yan... malaki nga lang.
« Reply #26 on: August 19, 2009, 04:35:27 AM »
..this is a very good and cheap programmer. usb pa. gamit2x ko na sxa ngaun. ung crystal gamit ko is 20 Mhz. but this progammer is somewhat slower than JDM. ayun sa codes 56000 ang baudrate nya. di katulad sa jdm diretso na sa serial port.
..the speed of this programmer is limited by the microcontroller..
..but still it is a gud programmer. lov it, cheap na cheap..
..paano magpost ng pic2ure?
« Reply #27 on: August 19, 2009, 05:16:35 AM »
..i'm planning to build a debugger/programmer ano ba maganda? :) :)
Offline drx2k
    • Drx2k Network
« Reply #28 on: August 19, 2009, 09:01:44 AM »
ah pwede ignore na lang yung lvp pin at di i-connect
oo nga malaki nga lang
ganito kalaki yung actual size na ginawa kong pcb layout
maya ko pa siguro ito mabubuo, papaphotocopy pa ako ng pcb layout nito sa acetate
i hope gumana na sya...
Offline drx2k
    • Drx2k Network
« Reply #29 on: August 19, 2009, 09:05:07 AM »
ganon po ba, slower than JDM itong programmer kahit 20Mhz na ang crytal ng PIC16F628A
plan ko kasi gamitin yung internal oscillator na 4Mhz eh, pero kung lalong babagal, gagamit na lang din ako ng external 20Mhz Crystal
« Reply #30 on: August 19, 2009, 09:51:16 AM »
don't use lower xtal speed. pasiguro lang... the page says use more than 8Mhz nga... baudrate is directly affected by the crystal osc.
Offline drx2k
    • Drx2k Network
« Reply #31 on: August 21, 2009, 11:15:47 PM »
hayzz build failed..
di ko pa rin mapagana ito...
saka ko na lang ulit bubutintingin ito..
lagay ko muna ito project queu hehehe
« Reply #32 on: August 24, 2009, 02:58:13 AM »
this was my first programmer.
Offline jaythecaesarean
« Reply #33 on: June 03, 2010, 09:05:05 PM »
ang galing naman... masubukan nga... ang tagal kong naghanap ng gaya nito...  ::) ::) ;D :o :o :o
