Author Topic: sanyo ref problem  (Read 763 times)
Offline gianlolen
sanyo ref problem
« on: July 30, 2009, 09:19:12 PM »
normal po ba na mag init ang mga side ng ref?grabe kaya ang heat nya.salamat po!
sanyo ref problem
Offline robbietan
  • Pogi/Ganda Points: 17
Re: sanyo ref problem
« Reply #1 on: July 31, 2009, 08:50:49 AM »
could be the way the ref dissipates the heat from its system. if the ref does not have metal grills at their back to dissipate heat, the ref may have been designed to dissipate heat this way.
apqi.ph
Offline brian_po
  • Pogi/Ganda Points: 40
  • Babaero ka ah
« Reply #2 on: July 31, 2009, 11:17:13 AM »
normal lang ito.
actually mas ok pag mainit ang gilid. it means that the cooling system is good..
high side kasi ng system ay nasa gilid ng ref. "almost all brands" unlike sa old models
na nasa likod ang condenser ng ref.. kasama din ito sa design kasi mas manipis ang foaming ng body.
they put the high side of the system sa sides to prevent moistures.
-Conserve Water; Drink Beers
