Author Topic: how to utilize Analog-to-Digital Converter Module of a Microcontroller ?  (Read 10176 times)
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
paano ba gamitin yung ADC module ng PicMicro (e.g pic16LF73/pic16F73) ?  ???
paano sya ia-activate / i-initialize ?  ???
saan dapat magsimula ang design/program ?  ???
ano ang mga design restrictions ?  ???
Offline toasted siopao
  • Global Moderator
  • Pogi/Ganda Points: 107
    • TeknoBlogger
Ano programming language gagamitin mo? May na post ako dito na project using PIC16F877A.
  • Global Moderator
    • TeknoBlogger
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
Ano programming language gagamitin mo?..
CCS C ang gagamitin kong compiler..
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
  • Global Moderator
    • TeknoBlogger
Ibig sabihin ata nyan ang sampling nya is 8 bit.
  • Global Moderator
    • TeknoBlogger
This function will read the digital value from the analog to digital converter. Calls to setup_adc(), setup_adc_ports() and  set_adc_channel() should be made sometime before this function is called.   The range of the return value depends on number of bits in the chips A/D converter and the setting in the #DEVICE ADC= directive as follows:
#DEVICE
 8 bit
 10 bit
 11 bit
 12 bit
 16 bit
ADC=8
 00-FF
 00-FF
 00-FF
 00-FF
 00-FF
ADC=10
 x
 0-3FF
 x
 0-3FF
 x
ADC=11
 x
 x
 0-7FF
 x
 x
ADC=16
 0-FF00
 0-FFC0
 0-FFEO
 0-FFF0
 0-FFFF
Note:   x is not defined
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
ahh.. parang resolution..  :D
ibig sabihin, pag ginawa kong:
#device adc=16tataas resolution ng ADC ko..  ;D
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
question:
sa CCS C, anong pinagkaiba ng code na:
value=read_adc();saka:
read_adc(ADC_START_ONLY);
delay_us(xx);
value=read_adc(ADC_READ_ONLY);
anong advantages saka disadvantages nila?  ???
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
question:
delay_us(xx);
I am not sure of how the CCS library works.
But ADC needs a small delay for settling and hold time.
And conversion also takes a few cycles depending on ADCS setting.
The conversion is started by setting GO/~DONE to 1 then should wait for GO/~DONE bit to be cleared.
You should look at the resulting ASM or the library source.
Maybe code #1 incorporates all the steps.  Useful for beginners.
While on #2, it is broken down into each step of the conversion.  This way you can have full control of the A/D conversion by doing something while waiting for the ~DONE flag. Also the settling and hold time is not needed if you are not switching from one A/D input to another. So skipping this and the delay only on initialization, then using #2 makes the conversion faster.
The Cebuano Geek
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
regarding sa hardware:
magkakaproblema kaya ako kapag ganito circuit ko:  ???
input(tru coax) --- 2Mohm---2Mohm---------ADC port
                                                  1Mohm
                                                    GND
(i hope maintindihan nyo circuit ko)
voltage divider lang sya ?5 (parang voltage probe na x5 hehe)
ang concern ko is yung impedance, masyadong mataas!
di kaya magka-error na sa reading ng analog voltage ?  ???
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
                                                  1Mohm
                                                    GND
why not choose lesser resistance values? The higher the series resistance, the smaller the current getting into the ADC pin, which means the charge holding capacitor of the ADC module will takes a significant amount of time to charge. This will lead either to significant error in the voltage reading or a slower sampling time.
If you are using PIC microcontroller, the recommended total source resistance seen by the ADC input pin should be lesser than 10k ohms. The smaller the source resistance the better.
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
why not choose lesser resistance values?...
hmmm.. gumagawa kasi ako ngayon ng DIY oscilloscope. hehe  ;D
tinaasan ko yung resistance nya para gayahin yung mga mamahaling voltage probe
(supposed to be 10Mohm)..
what if padaanin ko muna sa sa op-amp (or diff amp)?  ???
di kaya mas malaki ang error ko?
may opamp ba na kayang mag-operate down to 3.3V supply?
...which means the charge holding capacitor of the ADC module will takes a significant amount of time to charge. This will lead either to significant error in the voltage reading or a slower sampling time...
sa ngayon naka-set yung TAD ng ADC sa 3.2us, ok na kaya yun?
2us daw ang minimum ng pic16LF73 according sa datasheet..
Offline zer0w1ng
    • The Cebuano Geek
                                                  1Mohm
                                                    GND
voltage divider lang sya ÷5 (parang voltage probe na x5 hehe)
If you look at the datasheet there is a +/-500nA leakage on the A/D input. This is like a 10M on parallel either to GND or VCC at 5V.
Also the A/D capacitance of 120pF will drop down the voltage during sampling.
Still on the datasheet, Microchip recommends a max. source impedance of 10Kohms to be accurate.  Your schematic shows a 1M impedance.
I think you need an opamp follower to decrease the impedance.
The Cebuano Geek
Offline zer0w1ng
    • The Cebuano Geek
Yes, it is needed. See my post above.
No. Opamps should not affect. Voltage offset though affects at lower inputs near 0V. But you could correct this by using a negative voltage supply or floating ground (1/2Vcc) and subtract the 1/2Vcc in software.
Yes there are. We are using mostly 3V opamp. LMV358 is the one we use.
Yes, TAD is minimum 1.6uS in 877. Maybe same as your chip.
BTW, you can use the smallest TAD to be fast.  This does not affect your input impedance. But the 120pF sampling cap does affect in AC reading.
The Cebuano Geek
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
paano yung floating ground???
right now, yung supply ko is only single +3.3V, almost near na sya sa maximum supply ng LCD display ko..
it would be impractical kung gagamit pa ko ng additional negative supply..  :(
Offline zer0w1ng
    • The Cebuano Geek
Add a 1.65V regulator or another opamp to output 1.65V and put the negative input (scope GND) of your scope there.
You main input opamp still is supplied at 3.3V. Your pic ground will not be the same as your input ground.
The Cebuano Geek
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
1.6us kung 16F73
2us kung 16LF73 --> ito gamit ko ngayon, para pwede ko syang i-operate down to 3.3V..
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
hindi ko pa rin ma-imagine ito, kanina pa..  :'(
paano nya nako-correct yung offset voltage during when the input is near 0 volt?  ???
Offline zer0w1ng
    • The Cebuano Geek
If the opamp config is single supply and the non-inverting input reaches near zero, the output will have an error.
To solve this the input ground will be raised to 1.65V.
Like this:
Scope IN+o---------|+\
                   |  +-+--o To ADC
                |  |/   |                o 3.3V
                +-------+               100K
Scope IN- o----------------+--+  |       |     |
                           |   \-|--+   100K  1uF
                                        GND   GND
Edit: Using this, you can also read negative values or zero crossing AC waves. Just subtract half of the max reading in software.
The Cebuano Geek
