Author Topic: Remote Weather Station using embedded webserver or gsm modem  (Read 2952 times)
Offline toasted siopao
  • Global Moderator
  • Pogi/Ganda Points: 107
    • TeknoBlogger
« on: March 09, 2008, 10:20:34 AM »
I have two embedded webservers here, the micros with ethernet capabilities.
One is powered by Zilog ez80 and the other one is by Wiznet.
Di ako marunong magcode sa dalawa so kakapain ko pa, anyway I am also stupid with ethernet's etc.., ang tanung, pwede ko ba ikabit itong mga embedded webservers sa router (wireless) and view the webpage na naka embed sa kanila?
Another option ko is wag na ako gumamit ng embedded webserver, gamit na lang ako ng gsm modem, I hate and don't want to use nokia phones because of the FBUS, and also the DLR3P for AT is not that stable.
How much na ba ang gsm modem?
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
Re: Remote Wether Station using embedded webserver or gsm modem
« Reply #1 on: March 09, 2008, 01:19:40 PM »
interested din ko nyan  :D
i say why not combine the two? gsm and ethernet  :)
« Reply #2 on: March 09, 2008, 02:08:05 PM »
i got a fargo maestro 20 gsm/grps modem here... sabi daw, around 12k-15k yung bili nito. and i am using it for my project too, i can't lend it to you... if you want, i have seen a gsm modem in e-gizmo, 5k. di ko nga alam kung ok naman yung reviews nun.
Offline paranz
« Reply #3 on: March 09, 2008, 02:14:42 PM »
marami student projects ang gumagamit sa Egizmo gsm modem. ok yata. But we can always use old cellphones
  • Global Moderator
    • TeknoBlogger
« Reply #4 on: March 09, 2008, 03:42:37 PM »
5k? Antay muna ako sponsor hehehehe, I have to extra nokia phones here, 3310 and 1100, both uses FBUS, tinatamad ako magcode sa fbus, and I don't know if I can make a stand alone pic micro to handle such protocol.
I will have quite a few transducer to be interfaced with the micro aside from the gsm modem/phone.
Offline krayziebone
  • Pogi/Ganda Points: 9
« Reply #5 on: March 10, 2008, 12:56:02 AM »
LAN access lang po ba o via internet na po?
kung LAN access lang po, ang kelangan mo lang malaman o i-set ay yung IP ng embedded webserver mo.. pero kung galing internet yung requests, dapat naka-set pa yung port-forwarding ng router mo patungo sa embedded webserver..
http://www.teamsushi.com/Online.htm baka makatulong..
  • Global Moderator
    • TeknoBlogger
« Reply #6 on: March 10, 2008, 06:23:30 AM »
Galing internet yung request, kasi dapat makita sya at may GUI. :)
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
« Reply #7 on: March 10, 2008, 08:18:38 AM »
FBUS with a 4MHz PIC, even with hardware UART, is pushing it because of high baud rate at 115200.
Going to 20MHz or MBUS is possible.
GPRS to the phone is maybe good to connect to internet directly. Have not tried this solution because of high cost of phone internet connection (P10/30min. minimum).  But you could batch send all data within 30minutes.
The Cebuano Geek
Re: Remote Weather Station using embedded webserver or gsm modem
« Reply #8 on: May 22, 2008, 02:38:33 PM »
Matagal na me gumagamit ng gsm module from egizmo isang beses lang kmi nagloko ung last project ko ksi may solder na nagloko dun sa ibenebenta nilang board na ksama ng gsm module.
Maganda nga project yan interesado rin me dyan matagal na. Bkit di ka na lang gumamit ng mga serial to ethernet converter like the one from tibbo. Matagal ko na rin gusto umorder nito kya lang may ibinigay cla local supplier di nman ako pinansin. Hmp
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
« Reply #9 on: May 22, 2008, 04:31:39 PM »
Tama.  From your router,  i port forward mo yung  port 80  -- the usual webserver port, papunta sa ip address ng embedded webserver.
Offline imorph
« Reply #10 on: May 23, 2008, 02:49:24 PM »
 ;D ung mga codes marami po sa internet nyan...sa hardware naman po baka makakuha ka ng idea dito... -->
http://www.remotecontroltech.com/PDF/WDC-2006-CUT.PDF
