Author Topic: ICD2 clone kits for sale... whose interested.  (Read 6940 times)
Offline Google
  • Pogi/Ganda Points: 20
Re: ICD2 clone kits for sale... whose interested.
« Reply #60 on: September 19, 2009, 10:24:10 PM »
sis, i would be better if you'd include the ICSP in your board...
papost nmn ng schematic nito kasama yung ICSP
insomartin
  • Guest
« Reply #61 on: September 19, 2009, 10:32:37 PM »
http://www.instructables.com/id/SDG140KFEQHFHZ7/
jdm ISCP (no debug of course)
this should be built in sa circuit. not a separate programmer. kasi wala pang 5 pesos yung components.
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
« Reply #62 on: September 19, 2009, 10:36:55 PM »
ganito ginagawa ko sa mga board ko :D
8051 stuff
Offline Google
« Reply #63 on: September 19, 2009, 10:46:16 PM »
bale kailangan ko pa ng separate na dc supply sa para sa ICSP at iba pa yung sa ICD2?
Offline tiktak
    • Tiktakx's Blog
« Reply #64 on: September 19, 2009, 10:50:00 PM »
kahit wala po supply yan kapag prinogram yung ICD2 ang magbibigay sa kanya ng VDD
8051 stuff
Offline Google
« Reply #65 on: September 19, 2009, 10:56:42 PM »
ah.. ic yan na lang gamitin ko mga magkano aabutin niyan sis?
Offline tiktak
    • Tiktakx's Blog
« Reply #66 on: September 19, 2009, 11:08:39 PM »
oo pala sis kapag may power na naka kabit, alam ko sa ICD2 i off nya din yung VDD para sa target, ganun kasi sa pickit eh :D siguro more or less 300 yang board na yan kasi 150 yung F84 eh, mas mura siguro kung 16F628 ka nalang sis puede mo gamitin internal oscillator nun :D
8051 stuff
Offline OPTIMUS PRIME
  • Pogi/Ganda Points: 28
« Reply #67 on: September 20, 2009, 09:07:57 AM »
mga bro JDM na ata ayan dina ICD2 hehehe
Just some thoughts : the serial JDM di ba delikado sa serial port e ala isolator yan....sa tangs na gaya ko sunog yan
« Reply #68 on: September 20, 2009, 09:58:10 AM »
mura lang ang ICSP...
look at this:
notice, nagdagdag lang tayo ng several components. normally, may 10k at 100nF na tayo sa MCLR pin. naglagay lang tayo ng header, isolation circuitry(470ohmz, 1n4148 or schottky diode like bat42). kung gagamitin natin ang PGD at PGC, lagyan nalang ng resistors(i use 1k) to isolate them during programming. notice also the header (from pickit2 ito), notice the sequence. very much the same as with ICD2 (genuine or clones). I suggest ganyan din ang sequence ng header sa board so any programmer could reprogram.
so mura lang. additional of (1) header, (1) diode, (2) resistors... plus additional effort on the routing... heheheh ;D
this is a very good discussion of ICSP:
http://www.embedinc.com/picprg/icsp.htm
sana malinaw na, OT na eh! ;D
very much correct sis, during initialization (connecting of ICD2 or PICKIT sa target board), it detects if the board have power (VDD), kung wala, sya na ang magsusupply. syempre kung meron, automatically, disconnected na yan. JDM-based programmers could  not handle this. so kung JDM-based ang gamit na programmer, better yet, disconnect the supply before connecting the programmer.
Offline tiktak
    • Tiktakx's Blog
« Reply #69 on: September 20, 2009, 10:29:26 AM »
@6.99 PM sent hehe ;D
8051 stuff
« Reply #70 on: September 21, 2009, 09:41:09 AM »
mga Bro
1.yun pa lang diode na na bias from 7805 from out nya pin 3 to pin 1 ano ang effect nya. Napansin ko lang to sa Inchworm ni Blueroomelectronics ni tester ko mukha la naman rise or fall ng voltage at current..check ko din datasheet ng 7805 ala din ganung mood of connection.
2. yung max 232 di din tumataas ung 12 v na boost nya pag kinabit mo na 10.48V actual na alang.
Ito mga concern ko which hinders me to buy ICD2 clones
Offline Google
« Reply #71 on: September 21, 2009, 11:08:56 AM »
sis bat gnuun yung laman ng .rar na sinend mo sabog na notepad
Offline tiktak
    • Tiktakx's Blog
« Reply #72 on: September 21, 2009, 11:35:53 AM »
^^eagle files yun sis sch at brd
8051 stuff
Offline blastronics
  • when you see me running, you should better follow.
« Reply #73 on: September 22, 2009, 07:58:52 AM »
mga Bro
Nabasa ko dati, Yung diode na yun para protection yun ng Regulator during power down. Para yung capacitor after the regulator di madischarge dun sa output nung regulator, as if nag-suplly ka sa output (pin 3). Kaya wala syang purpose during normal operation.
and yung sa output ng max, it suppose to be as as source para lang pumasok sa programming mode yung PIC. its not suppose to be a source of 12v. ( and i think the output voltage of MAX depends on the capacitor used.)
