Author Topic: samsung CT 21N30MJ  (Read 1165 times)
Offline charlie
  • Pogi/Ganda Points: 14
samsung CT 21N30MJ
« on: August 06, 2009, 10:01:49 PM »
 stanby light oki. may output supply B+. gumana sandali ng hinangan ko cold solder. 110v ko plugpero wala picture osd lng. tapos 220v ko ayun ayaw na mag oscillate. ano kaya problem?
samsung CT 21N30MJ
  • Pogi/Ganda Points: 916
Re: samsung CT 21N30MJ
« Reply #1 on: August 07, 2009, 12:09:50 AM »
sa tingin  ko may  problema  ang regulator section  nyu kng auto volt yan  dapat the same voltage B+ out yan kahit 110/220 operated...  kaso hindi xa regulated pagnakaplug-in sa 220v   meaning may problema nga yan sa SMPS nyu
try   nyu muna magpalit ng functional one na regualtor  (^_^)
Offline charlie
« Reply #2 on: August 07, 2009, 07:55:26 AM »
oki salamat
« Reply #3 on: August 07, 2009, 06:40:03 PM »
try  din resolbahin  kng anu  ang sinira bakit  hindi nag-oscillate,  maybe  sinira niya ang HOT or  avalanche zener diode
HOPE makatulong   (^_^)
Offline mr abe
« Reply #4 on: February 05, 2010, 04:11:09 AM »
try mo primary replace capacitors
Offline dan.enriquez
  • Pogi/Ganda Points: 52
  • Serbisyong Totoo
« Reply #5 on: February 05, 2010, 07:02:06 PM »
^ up..
