Author Topic: Seeking for ATMEL tutorial.. AT89C2051  (Read 8369 times)
Offline criantl
« on: August 10, 2009, 06:07:31 PM »
Hi guys.. cnu poh senyo may programming tutorial of the above mentioned IC??..
we need it tlga.. pati ung simple schematic diagram poh ng module nito??..
It seems that this microcontroller is now dominating in our study and projects..
thanks allot sa mga magbbgay.. hehe ;)
Offline subzer0
  • Pogi/Ganda Points: 38
  • Garbage In Garbage Out.
Re: Seeking for ATMEL tutorial.. AT89C2051
« Reply #1 on: August 10, 2009, 06:36:39 PM »
si beginnerwan,sir kuya at master rdpzycho ang gumagamit ng Atmel pm mo sila.
Signing Off...
Offline tiktak
  • Pogi/Ganda Points: 204
    • Tiktakx's Blog
« Reply #2 on: August 10, 2009, 06:49:29 PM »
Ito ba required ng instructor nyo? why not consider zilog or pic? ;D
8051 stuff
Offline ATE
  • Pogi/Ganda Points: 12
    • Volts and Bytes
« Reply #3 on: August 10, 2009, 06:57:57 PM »
magkakaroon ako ng free tutorial nito sa site ko... sana within one month meron na...
kaso pinag-iisipan ko pa kung AT89C2051 or AT89S2051 ang gagamitin ko...
i am also planning to make 3-in-1 programmer (8051, AVR, PIC) using PICmicro para halos lahat ng members dito pwedeng gumawa...(sana magkaroon ako ng maraming time    :( )
Offline tiktak
    • Tiktakx's Blog
« Reply #4 on: August 10, 2009, 07:11:44 PM »
ano po ba main difference nung at89c at at89s? naalala ko nung college yung isang teacher namin 8051 din tinuturo
8051 stuff
Offline subzer0
« Reply #5 on: August 10, 2009, 07:12:01 PM »
wow sige sir kuya,ang ganda naman yan,iyan nalang di ko nasusubukan Atmel Series,ang ganda yung ginawa mo na AVR Atmega32,yun yung plano ko gawin,more power sir kuya!
Signing Off...
Offline ATE
    • Volts and Bytes
« Reply #6 on: August 10, 2009, 07:16:59 PM »
yung 89S2051, in-system-programmable, double din yung RAM nito compared sa at89c2051...
yung 89C2051, parallel programmable, yung makaluma...
Offline ATE
    • Volts and Bytes
« Reply #7 on: August 10, 2009, 07:25:54 PM »
wag mo munang gawin yun, plano kong i-revise...
may ginawa na akong tutorial sa AVR before pero binura ko na... di ko kasi gusto yung pagkakagawa....
revise ko din yun pero baka ATtiny2313 gagamitin ko...
GO ako sa tutorial... yung list sa site ko, yun yung mga planned lineup...
pero yung avr, pic, 8051 palang yung pinaka-sure...
yung ibang nasa list, drawing pa lang... (wish ko lang, sana dumami free time ko)
Offline beginner wan
  • Pogi/Ganda Points: 46
    • [im]Duino
« Reply #8 on: August 10, 2009, 09:30:35 PM »
pag meron akong maitutulong sayo sir kuya, gagawin ko.. just tell me kung may kailangan ka.. :D nga pala, sa assembly ako may kaunting nalalaman pag dating sa 8051..
Offline ATE
    • Volts and Bytes
« Reply #9 on: August 10, 2009, 11:24:53 PM »
sure, trial ng keil lang ang gagamitin ko kaya assembly lang...
pero kung may gustong magsponsor dyan ng licensed keil (kahit Raisonnance pwede na) pwede ring yung C...
Offline tiktak
    • Tiktakx's Blog
« Reply #10 on: August 10, 2009, 11:29:05 PM »
may konting alam din ako sa assembly sa atmel but i prefer C :D, di na ako naka pagprogram ng atmel until now pati yung 89C430 ko naka stock padin
8051 stuff
Offline ManNoy VillAquino
« Reply #11 on: August 11, 2009, 07:55:27 AM »
debugger na lang... JTAG.
Offline criantl
« Reply #12 on: August 11, 2009, 11:04:16 AM »
hindi naman xa required, but this is the new microcontroller that we are using right now..
We also use zilog before.. mahal lng kc tlga ung zilog  IC's compared to ATMEL db??..
and i've heard na assembly language ung ginagamit sa programming right??..madali lng kya??..
haha.. still  planning to use PIC kaso wl pa cnung gumagamit dito sa school namin..
Offline criantl
« Reply #13 on: August 11, 2009, 11:08:54 AM »
haha.. salamat poh sir kuya.. anu poh ba ung pinagkakaiba ng AT89C2051 at AT89S2051??..hehe.. ung first one poh ung ginagamit namin ngaun..
haha.. sana nga madali naming maintindihan ung tutorial.. anu poh b ung mga kakailanganin namin to start our programming career with AT89C2051??..hehe
Offline criantl
« Reply #14 on: August 11, 2009, 11:17:27 AM »
haha.. salamat poh sir kuya.. anu poh ba ung pinagkakaiba ng AT89C2051 at AT89S2051 in everything??..hehe.. ung first one poh ung ginagamit namin ngaun..
  • Pogi/Ganda Points: 636
« Reply #15 on: August 11, 2009, 12:06:24 PM »
SDCC (C Compiler) gamit ko pagdating sa 8051. 'di naman din siguro ganung kahirap ang assembly ng 8051 dahil konti lang ang instructions. si Wan assembly ang gamit.
Offline motion55
  • Pogi/Ganda Points: 245
« Reply #16 on: August 11, 2009, 12:13:35 PM »
Keil C51 is a good compiler to use for the AT80C2051. Nakagamit ako nito on a small project a few years ago. I thought it was better than MPLAB+C18. You can download an evaluation copy to try it.
http://www.keil.com/c51/
"Set your mind free!"
Offline tiktak
    • Tiktakx's Blog
« Reply #17 on: August 11, 2009, 12:54:55 PM »
we use MIDE back in college for assembly, it also include SDCC
http://www.opcube.com/home.html#MIDE51
8051 stuff
« Reply #18 on: August 11, 2009, 02:36:50 PM »
ok nga 'yang MIDE, kapag hindi kasi sanay sa manual edit/compile, nakakatamad 'yung SDCC lang talaga.
ok din 'yung Keil tulad ng sabi ni sir motion55, pero nag-opt ako doon sa free na SDCC. nasubukan ko rin 'yung IAR pero mas gusto ko 'yung SDCC at Keil.
nakagamit din ako ng older language for 8051, PL/M-51. medyo madali ang syntax pero parang mas maganda ang C. hindi kasi pwede maglagay basta ng inline assembly.
Offline ATE
    • Volts and Bytes
« Reply #19 on: August 11, 2009, 07:14:54 PM »
AT89C2051 =
12 clock cycles per instruction (almost all instructions),
parallel programmable (eto yung old-style ng programming)
128 RAM
AT89S2051 =
12  clock cycles per instruction or 6 clock cycles per instruction (depende sa clock register),
in-system programmable (serial programmable),
256 RAM
=para sa akin pinakamadaling pag-aralan ang assembly ng 8051 compared sa iba
=madaling matutununan ang PIC kahit datasheet lang ang hawak mo (simple lang kasi ang layout ng mga datasheets nila)
=AVR - fav ko pero mas sumasakit ang ulo ko pag nagbabasa ng mga datasheet at application notes nito...
OT: ano bang family ang widely used sa industry(globally)?
