Author Topic: Embedded Operating System  (Read 1678 times)
Offline neytan
« on: August 14, 2009, 10:43:27 AM »
I have some questions about Embedded OS, please help me. Where will I install this OS, a normal OS is installed in a hard drive right? how about this. thanks, and please give me some links, pdf files, and the like which I could read to understand more about embedded OS. thanks.
Offline TinTopHack
  • Pogi/Ganda Points: 154
Re: Embedded Operating System
« Reply #1 on: August 14, 2009, 01:02:18 PM »
Embedded OS can be installed in a hard drive, on-board flash memory, compact flash card, SD card, Disk-On-Chip or Disk-On-Module - depending on the configuration of your embedded system.
What embedded system are you using? What embedded OS do you have?
Offline blackfin
« Reply #2 on: August 14, 2009, 07:43:47 PM »
totally agree.
for embedded systems, you normally have boot configuation to point boot sequence and OS
Offline neytan
« Reply #3 on: August 14, 2009, 11:30:53 PM »
thanks for the info, i dont have embedded OS yet. but im planning to use it with my project. Sir, can I install embedded OS in MCU? or MPU? how can i incorporate embedded System with this two? which do you think is better.. thank you so much...
« Reply #4 on: August 15, 2009, 12:17:23 AM »
ano ba 'yung project niyo sir?
Offline neytan
« Reply #5 on: August 15, 2009, 05:58:00 AM »
cge ganito po yung overview ng project ko, its a "stand alone printer" it can print specifically *.doc files directly from the USB even without connecting it to the computer. So anu po yung siggestions niyong gagamitin ko? salama po ulit Sir..
Offline neytan
« Reply #6 on: August 15, 2009, 08:43:05 AM »
Sir, you said na embedded can be installed in a hard drive, then anung pagkakaiba niya sa ordinary OS? salamat po.. please keep updating with this post, this will help me a lot..
insomartin
  • Guest
« Reply #7 on: August 15, 2009, 08:53:27 AM »
embedded software just simply means that it's just that... you can install only what you only need. parang windows xp embedded. it is the same windows xp but you'll be able to select ONLY what you'll need to run your software. it simply means that the operating system could also run in REAL TIME. windows xp/CE could do that.
i wiki mo yung windows xp embedded makakatulong yan sa usb to printer mo.
ganito yung set up ko sa isang kiosk ko. sa event.
intel ATOM 1.6 ghz  cost is 4400 petot may 1gb ram na
compact flash reader (high speed) 1,200 petot
installed with windows xp embedded.
insomartin
  • Guest
« Reply #8 on: August 15, 2009, 08:54:34 AM »
« Reply #9 on: August 15, 2009, 12:29:07 PM »
it can be done using Microcontrollers with large memories kung kailangan na mas mura, kailangan lang ng FAT reader at gagawa ng program pambasa ng .doc.
mas madali lang sa may Embedded OS lalo na kung sanay sa OS na 'yun.
Offline neytan
« Reply #10 on: August 16, 2009, 11:15:54 AM »
maraming slamat po boss, kung may tanung pa ako, i'll post soon. kaya sana po please keep checking at my post.. salamat po..
Offline neytan
« Reply #11 on: August 16, 2009, 11:23:46 AM »
wow! pwede palang MCU 'to?! sir any links that I could read to understand this further. so kung gagawin kong MCU based, hindi na po kelangan ng embedded OS. tama po ba? at panu ko naman po, eextand yung memory nito? isa pa po, panu po yung FAT reader, kasma na po ba sa programming yun..
Offline neytan
« Reply #12 on: August 16, 2009, 11:54:17 AM »
ayan may lumabas na tanung sa isip ko, kung pwede mong i select only yung pwede, panu yun? san mo pwedeng gawin yun? sa mini board dun mo maco-configure yun? after i-install o while inatalling..
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
« Reply #13 on: August 16, 2009, 12:15:12 PM »
I used nlite to strip down winxp so that puede syang mag run kahit sa old computers runing at 233 MHz
8051 stuff
Offline tiktak
    • Tiktakx's Blog
« Reply #14 on: August 16, 2009, 12:16:42 PM »
8051 stuff
insomartin
  • Guest
« Reply #15 on: August 16, 2009, 12:20:44 PM »
may command line ba na pdf reader?
insomartin
  • Guest
« Reply #16 on: August 16, 2009, 12:21:29 PM »
i was just thinking kung may commandline na pdf thingy. pwede ka na mag control nang software to print...
insomartin
  • Guest
« Reply #17 on: August 16, 2009, 12:29:19 PM »
back long time ago. kahit naka win98 ako eh sanay pa din ako sa command line. kaya nung nag nageedit and print ako nang pictures naka batch and commandline driven. much faster kasi that way.
pseudo flowchart
0. wait for usb functions..
1. when usb is inserted go SEARCH *.doc
2. show all files in a list.
3. select file from list.
4. select printer/paper size.
5. print.
goto 0
Offline neytan
« Reply #18 on: August 16, 2009, 12:30:17 PM »
boss eto bang sinasabi mo, pwedeng i-aaply sa MCU? o sa embedded OS?
Offline neytan
« Reply #19 on: August 16, 2009, 12:34:06 PM »
pseudo flowchart
5. print.
goto 0
Sir thank you po! very nice instruction... basta kapag may tanung pa po ako, sana nandyan kayo to reply, slamat po talaga!
