line-1 (U-Z), line-2 (V-X), line-3 (W-Y)line-1 (U-Y), line-2 (V-Z), line-3 (W-X)
Yong Delta to Wye bro, kaylan nya ito dapat e engage sa crushing operation?
In Philippine Electrical Code the real answers are using four magnetic contactor to forward-reverse wye-delta motor control circuit, that means are reversable rotation of induction motor (clockwise and counter- clockwise) 10hp and above could be use the motor sequence in reversable rotation in this option, so four magnetic contactor are adviseable.Each control are assign for this in Forward, Reverse, Wye and Delta...this is not to save in highly maintenance or savings your money to provide each control because this is mandatory to use the four magnetic contactor in this motor control circuit...Now, in this sequence the only problem is how will you tap the wiring in permanent connection, maybe all of you have answers for this and analysis about this wiring diagram and all of you are showing your optional answers that maybe correct or not but my question is, did you test this in experimental connection in your own opinion, have you experience this motor control in your work in industrial field, did you have encounter this in trouble shooting or installation in your company during your duty?..I really appreciated all your opinion here in this analysis of forward-reverse wye-delta motor control circuit or power diagram, but you may a sure of your comment or suggestion to be practising as consultant or inspector if you have a doubt in your opinion, thank you to all and more power to all members...
.....gusto pa yata e designer ng Rockwell at Siemens e peace
Mahal sumingil mga yun ah. Hehehehe.....
Bale ganito ang sequence nung machine na sinasabi ko na parehas ng querry ng t.starter.Forward wye then forward delta (continous running yan hanggat di nataas ang ampere eh tuloy ang crushing, once nag high current at nalagpasan ang current setting nung sensor with a span of time set. Mag reverse yan ng reverse wye then reverse delta, then me timer yan for reverse after matapus countdown eh balik sa forward rotaion with wye delta ulit. Ganun lang operation. Di na yung delta to wye. Di ba kaya lang naman nagkaroon ng wye delta sa 60hp eh sobrang laki nung motor kaya ganun starting method nya. mas ok to kung sof start ang method para wala ng madaming contactor at timer..... hehehehe... Napakasimple, Less maintenance pa at tipid pa sa kuryente...BR
