Author Topic: pcb layout softwares  (Read 12143 times)
Offline beginner wan
  • Pogi/Ganda Points: 46
    • [im]Duino
Re: pcb layout softwares
« Reply #40 on: April 21, 2008, 06:50:20 PM »
may yahoo groups ang kicad users kaya may mga taong maaaring tumulong sa yo dun.. ;D ;D ;D
eto po.. maaari magpost ng mga tanong nyo.
http://groups.yahoo.com/group/kicad-devel
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #41 on: April 21, 2008, 11:05:11 PM »
aha meron pala yahoo groups. oki yan, wan. Thanx
Offline Ganda692002
  • Pogi/Ganda Points: 13
« Reply #42 on: April 22, 2008, 12:00:41 AM »
mukhang oki din ang KiCAD. I will try to learn how too use it, but ARES muna ang target ko.  ;D
You read my mind.. gusto ko rin yan pra diretso na sa simulation in one app.. Ang hirap ng iba-iba pa ang gamit..
Ang ayaw ko lang dun ay ang pangit ng osiloscope.. di ko matrace yung line.. para lang tuldok tapos nawawala.. napasobra pag gaya sa totong osciloscope hehehe..
Offline paranz
« Reply #43 on: April 22, 2008, 12:07:23 AM »
hmm meron pala simulation ang kicad? hehe i tot na schematic capture and PCB layout lang ito. Mas oki pala kung ganun  :D
Offline Ganda692002
« Reply #44 on: April 22, 2008, 12:13:09 AM »
ISIS yung sinasabi ko sir.. hehehe
hmmmnnn Now.. Pinaisip mo na ko.. baka lahat ng mga post ko dito ay mis interpreted hehehe..
lalo na pati yung mga patawa ko hehehe...
Offline paranz
« Reply #45 on: April 22, 2008, 12:18:13 AM »
ahihi ISIS pala..
i havent tried ISIS virtual scopes yet, i like better the multisim's scopes kasi maganda ang graphics hehe
gamit ko lang ISIS for pic simulation  ;D, but for analog circuit design multisim pa rin ako  8)
Offline Anna
  • ONYX - Pinoy Open Source!
    • ONYX - Pinoy Open Source Technologies
« Reply #46 on: April 22, 2008, 12:45:35 AM »
its not that hard to get used to kicad...try spending a few minutes reading the manual. :)
Cheers,
The WebMaster
Visit MetaDesign Web Solutions
Visit SPICEsim Electronic Designs
Offline mahalkosinikki
  • failure is not an option!!
« Reply #47 on: April 22, 2008, 07:57:43 AM »
parang i think i should try KiCAD hehehehe...
or i would shift in KiCAD perhaps....
 ;D ;D ;D ;D
« Reply #48 on: April 22, 2008, 11:16:42 AM »
good thing with Open Source software you can modify it to suit your needs...
you may even create a fork... ;D
Offline engraj05
« Reply #49 on: May 05, 2008, 09:53:33 AM »
search mo bro sa internet yung physical dimensions nung electrolytic cap na gagamitin mo halimbawa then doon mo ibase yung pipiliin mo sa RCL...
@sevensrting
sir pano q po mllaman kung ano po script ng eagle pra sa POV-ray? ska pno po xa gamitin?
from: http://www.electronicslab.ph/forum/index.php?topic=5.20
Offline imorph
« Reply #50 on: June 19, 2008, 09:06:49 AM »
 kahit anong software basta pwede ka gumawa ng sarili mong library, may-export/import wizard, pwedeng mag-output ng gerber files, at as much as posssible ay open source :D
ang importante sa PCB design ay library editing(ie. symbol, footprint, IBIS data, IGES or VRML 3D data,...etc.). hindi pwedeng magdepend lagi sa existing library. d naman kc ganun ka-updated yung mga integrated libraries sa mga softwares. mas madali na ang schematic capture at pcb lay-out pag ok na yung library
Offline tawe0023
« Reply #51 on: August 03, 2008, 09:45:59 AM »
panu po ba mag add ng library, tulad po ng ibat ibang klaseng laki ng toggle switch sa EAGLE LAYOUT.
« Reply #52 on: August 03, 2008, 09:48:39 AM »
gagawa ka ng bagong library? punta ka sa Control Panel ng Eagle then File > New > Library.
Offline tawe0023
« Reply #53 on: August 03, 2008, 04:04:20 PM »
SAN NMAN PO AKO PWEDENG KUMUHA NG MGA LIBRARY?
« Reply #54 on: August 03, 2008, 05:49:10 PM »
sa mismong site ng cadsoft eagle. meron doon. or gawa ka na lang kung gusto mo...
« Reply #55 on: August 04, 2008, 01:04:57 PM »
cno man may gusto ng license ng eagle 5 just pm me.
« Reply #56 on: August 04, 2008, 11:33:00 PM »
5.1.0?
« Reply #57 on: August 05, 2008, 08:18:51 AM »
5.1.0?
5.0 pa lang po. Try ko pa hanap 5.1. pero sabi  nung iba working din daw un sa later version
Offline Cute_Worm_1983
  • Pogi/Ganda Points: 16
« Reply #58 on: August 05, 2008, 08:52:59 AM »
@ nomad meron ako 5.1 na eagle, stable siya.
I love electronicslab.ph
« Reply #59 on: August 05, 2008, 09:11:59 AM »
evaluation po ginagamit ko ksi wla pa nman ako needs pra sa malaking board ska naiinis ako dahil kailangan mo pa ilegalize ung mga files pag sa ibang computer mo bubuksan.
