Author Topic: how to put heat sink paste or silicon paste on the procee?  (Read 1720 times)
Offline almost
  • All good things must come to an end...
« on: September 16, 2009, 12:44:41 PM »
how to put heat sink paste or silicon paste on the procee?/ Microprocessor chip...??kasi na monitor ko temperature ng CPU ko eh umabot ng 90 degrees...kaya bgla nalang nag shutdown...kaya gusto lagyan ng paste..kaya lang di ko pa na try to..ano po ba mainam gawin mga tol?
Offline 0b00000111
  • Pogi/Ganda Points: 398
Re: how to put heat sink paste or silicon paste on the procee?
« Reply #1 on: September 16, 2009, 12:50:50 PM »
taas nyang 90degrees. doublecheck mo rin kasi baka di ayos yung lapat ng heatsink... merong instructions sa artic silver website kung paano maglagay ng paste
Tel #: (63)(2) 536-3378
Globe +63915-973-7691
Smart +63921-779-0748
Location Map
Offline Mayalin22
  • Pogi/Ganda Points: 400
« Reply #2 on: September 16, 2009, 01:04:16 PM »
very thin lang sis yung halos kasya lang sa Microprocessor chip... pag sobra sobra kc didikitan lang ng alikabok...
Simpler designs are usually better.
  • Pogi/Ganda Points: 630
« Reply #3 on: September 16, 2009, 01:13:14 PM »
^ at 'di rin magco-contact ng tama 'yung heat sink at CPU kung marami. suggest ko rin sana i-lap 'yung heat sink, medyo matrabaho nga lang.
Offline kalansing
  • Pogi/Ganda Points: 18
« Reply #4 on: September 16, 2009, 02:34:41 PM »
hello sis. what processor are you using?
i've had problems with overheating with stock settings (no overclocking) and stock cooling. had several unmounting / cleaning and re applying the thermal paste trials but to no luck. sinubukan ko din mag pea size, striped, 'o' shape, 1 line, 2 lines na pag apply ng paste. ang nakakainis pa dito kahit nasa BIOS/cmos lang umaabot ng 102'C!!! until.............
may nabasa ako na i undervolt ng konti ung processor. never had problems eversince.
* trial and error, you may have to clear out the cmos settings once or twice to get the best voltage for your cpu.
download Prime95,http://www.majorgeeks.com/Prime95_d4363.html for CPU loading and coreTemp,http://www.guru3d.com/news/coretemp-099526-released/ for cputemp monitoring
a. list mo yung default voltage core.
b. check out the next Lower voltage available in the settings. start from there.
c. boot windows
d. run prime95 .. test mo for an hour. pag wala errors encountered. restart pc.
e. go to CMOS and set it to another lower voltage.
f. go back to [d.] till you hit errors during tests. -this means na hit mo na ung baseline. step up one notch on the voltage settings.
from 76-85 idle naging 52-54... :)
nagkataon parehas pa kami ng barkada ko ng cpu. nakapag palit na sya ng motherboard same results. nag upgrade ng pagkamahal mahal na cooling fan. nag rerestart pa rin. nung nag undervolt naging stable na.
« Reply #5 on: September 16, 2009, 03:14:29 PM »
ok din 'yang undervoltage, bukod sa bumababa temperature, saves battery sa mga laptop na meron sa settings.
Offline almost
« Reply #6 on: September 16, 2009, 08:59:52 PM »
hirap yata yan ah..pero try ko sabi ni kalansing..salamat ah..
Offline almost
« Reply #7 on: September 16, 2009, 09:21:55 PM »
by the way kalansing, san ba makikita yung default voltage core?tsaka paano ba set ang voltage?hehe
Offline beginner wan
  • Think Positive! Matutupad yang dream mo!
    • [im]Duino
« Reply #8 on: September 16, 2009, 09:40:26 PM »
bout dun sa paste, may nakausap ako dati isang working CoE, may friend daw syang technician na naglalagay ng  "toothpaste" sa heatsink ng cpu para daw masira at ibalik nya uli. so ngayon, nung inayos nya(CoE) yung isang PC, inamoy nya yung paste dun sa may heatsink, at sabi nya sakin, "may toothpaste oh!" so tinanggal nya.. sad to say, wala kong balita kung anong nangyari dun sa CPU.  ;D ;D ;D
i;0.?QrEpM?4DEZZ]bkH{w@F<38.Jq@92Ds3KPQj60?EA7U\3M<A84J|AI.H
R@>&?Ej,@;5H)o::7KE/:?QcXf?gX'39=,Z_Q[eYXc
« Reply #9 on: September 16, 2009, 11:33:32 PM »
 ;D ;D ;D
sa BIOS settings. ;) madalas nasa advance settings kasama ng RAM voltages and timings, at CPU speed.
Offline almost
« Reply #10 on: September 17, 2009, 08:57:29 PM »
hay salamat sa mga nag response!..sa wakas na ayos ko rin..nilagyan ko lang thermal paste..buti naman naging ok na..hehe..salamat..more power to all..
Offline blink12280421
« Reply #11 on: March 13, 2012, 04:05:31 PM »
Mga Master... 2 years na yun pc ko, since ng binili ko iyon hindi ko pa siya nalalagyan ng thermal paste. Ano po ba ang magiging epekto at nawawala ba ito na kailangan lagyan ulit.?
« Reply #12 on: March 13, 2012, 09:30:33 PM »
'di naman siya kailangang palitan frequently. kung matagal lang natuyo tapos inalis 'yung contact nung heatsink at CPU saka kailangang palitan. pero kung 'di naman ginagalaw, ok lang 'yan, makikita naman sa temp monitors kung may problema na (though madalas, 'yung fan ang unang culprit dahil sa alikabok).
« Reply #13 on: March 14, 2012, 04:42:49 PM »
Tnx rdpzycho... nalilinis ko na naman yun fan ko.. Balak ko sana on my next maintenance balaksin ko na yun fan sa processor tapos lagyan ko na rin thermal paste. No need na pala...
Offline /
  • Pogi/Ganda Points: 317
« Reply #14 on: March 14, 2012, 04:57:06 PM »
sabskryb
