Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Hardware, Resources and Projects
Personal, Academic and Commercial Electronics Projects
(Moderator:
marcelino
patulong po sa smoke sensor project
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: patulong po sa smoke sensor project (Read 2297 times)
zzune
LR44 Battery
Pogi/Ganda Points: 0
on:
September 17, 2009, 06:01:01 PM »
idea ko po is gumamit ng phototransistor with led, pahinge naman po ng circuit. wala talaga akong idea kung pano gagawin
is pa po is heat detector... may circuit po ba kaung alam para sa ganitong sensor?
Logged
on:
zzune
LR44 Battery
Re: patulong po sa smoke sensor project
Reply #1 on:
September 17, 2009, 08:01:09 PM »
mejo magulo ata ung pagasabi ko nung una
ang need ko po sana kung pano po mag act as a switch ung phototransistor at thermistor...ung simple lng po, ung phototransistor mejo may idea na ako kasi transitor cya, pero ung thermistor wla akong maisip na circuit para gawin siyang switch na magdedetect ng heat
Logged
Reply #1 on:
SpongeBob
Lead Acid Battery
Pogi/Ganda Points: 33
Reply #2 on:
September 17, 2009, 08:06:44 PM »
Yun phototransistor tumataas ang collector to emitter current proportional to light received, yun namang thermistor tumataas ang resistance kapag mataas ang temperature.
Logged
Reply #2 on:
zzune
LR44 Battery
Reply #3 on:
September 18, 2009, 12:38:16 PM »
thanks sa info
tanong ko lng po kung ano ung nasa tabi ng diode sa pic na to
http://1.bp.blogspot.com/_zLj1Mx-ENMA/SqNn1igBteI/AAAAAAAAAUY/6M0Wd2hfQpk/s400/Untitled-1.jpg
Logged
Reply #3 on:
insomartin
Guest
Reply #4 on:
September 18, 2009, 01:19:03 PM »
^ relay.
get a good basic electronics e-books. ok yung evil genius series kung konti pa yung alam mo sa electronics. madaming sample circuits dun.
Logged
Reply #4 on:
-albert-
LR44 Battery
Reply #5 on:
October 07, 2009, 12:19:18 PM »
tama po ba ung pag connect ko?
d ko kasi ma simulate dahil walang phototransistors sa workbench ko...copy paste lng ung circuits
plano ko kasi pag na block ung ilaw sa isang sensor mag on ung LED ( yung box sa output ng or gate) ...simple lng na smoke detector with logic gates
Logged
Mayalin22
Hydroelectric
Pogi/Ganda Points: 400
Gender:
Reply #6 on:
October 07, 2009, 10:21:45 PM »
ito adjustable ang trigger
Logged
Simpler designs are usually better.
carlsfootprints
Lead Acid Battery
Pogi/Ganda Points: 25
Reply #7 on:
October 07, 2009, 11:28:44 PM »
@zzune,
kapag bibili ka na ng thermistor mo, get the highest ohm rating na meron.. nung gumamit kasi ako nun ng thermistor, hindi naaactivate agad.. perhaps may mali ako sa computation ng voltage divider pero gumana kasi nung malaki ma ung ohm
Logged
never saturate..
ultrasonic™
Solar Power Satellite
Pogi/Ganda Points: 916
Gender:
never be harsh coz everythng is fine
Reply #8 on:
October 08, 2009, 01:19:17 AM »
subukan nyu ito:
HEAT DETECTOR subok ko na kasi noon pa
TDR = 5k ohm NTC thermistor
R2 = 50k ohm trim..
Q1 = 2N3904 / 2N2222A
K1 = SPDT relay 6V
adjust lng kayo sa trimmer to improved der sensitivity
(^_^)
Logged
TV SERVICE MODE -
http://www.elab.ph/forum/index.php?topic=2267.0;topicseen
insomartin
Guest
Reply #9 on:
October 08, 2009, 01:34:19 AM »
PIR Sensor nang egizmo. i lit a lighter nag on! yun nga lang... kapag may sudden movement nagtritriger din. but sensitive sya sa ir.
Logged
carlsfootprints
Lead Acid Battery
Reply #10 on:
October 15, 2009, 01:23:01 AM »
sir martin, may working schematic po ba kayo for the PIR sensor ng egizmo? TIA
Logged
never saturate..
insomartin
Guest
Reply #11 on:
October 15, 2009, 02:01:21 AM »
^ meron.
Logged
carlsfootprints
Lead Acid Battery
Reply #12 on:
October 15, 2009, 02:03:27 AM »
ok lang po ba pashare? hehehe
Logged
never saturate..
insomartin
Guest
Reply #13 on:
October 15, 2009, 02:45:45 AM »
(of course i PM mo ako diba?!)
Logged
ultrasonic™
Gender:
Reply #14 on:
October 17, 2009, 01:53:19 AM »
Quote from: Martin on October 15, 2009, 02:45:45 AM
pwde maki-ambag din (^_^)
Logged
TV SERVICE MODE -
carlsfootprints
Lead Acid Battery
Reply #15 on:
October 18, 2009, 10:07:40 AM »
PM sent sir Martin
Logged
never saturate..
Reply #15 on:
Print
Pages: [
1
Go Up
« previous
next »
(Moderator:
marcelino
