Author Topic: Solar Tracker  (Read 1964 times)
Offline marleona
Solar Tracker
« on: September 21, 2009, 12:18:56 AM »
tanong ko lang po???? Ano ang mas efficient in terms sa pag harness ng solar energy ung panel na may solar tracker o ung malaki ang surface area ng PV panel? tnx!!!
It is not the answer that enlightens, but the question.
Don't hesitate to ask question.
If you don't ask, you don't get.
Solar Tracker
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
Re: Solar Tracker
« Reply #1 on: September 21, 2009, 09:54:48 AM »
Ang with tracker ang efficient kapag compared to plane ang solar panel for morning at afternoon ay inclined ang beams.
Pero kung marami kang panels, you could make a curved collector.
So kung morning at afternoon, direct rin ang rays nung sun.
The Cebuano Geek
Re: Solar Tracker
Offline marleona
Re: Solar Tracker
« Reply #2 on: September 22, 2009, 09:14:39 AM »
maraming salamat sa tulong heheheeh,nalinaw na rin kung ano ang mas efficient. kaso kapag maraming panels magastos baka hindi kayanin hehehe . may madadagdag pa ba kayong suggestions.
Re: Solar Tracker
insomartin
  • Guest
Re: Solar Tracker
« Reply #3 on: September 22, 2009, 05:55:58 PM »
it might ad 5-10 percent try adding an extra mirror so that light is pointed sa pv panels. i don't know kung pwede ito but i 'think' that should work thou. kasi may nabibili na pinapatong sa solar panels to gain extra watts.
Re: Solar Tracker
Offline marleona
Re: Solar Tracker
« Reply #4 on: September 24, 2009, 10:52:07 AM »
may additional din po akong tanong para sa solar tracker. Paano po maintegrate ung solar tracker sa solar pane? May idea po ba kayo kung ano pwede naming gamitin na circuit, o di kaya opinion para mag track ung solar panel???
Re: Solar Tracker
Re: Solar Tracker
« Reply #5 on: September 24, 2009, 01:22:16 PM »
ginagamitan 'yun ng motor at info tungkol doon sa location. may mga PV cells din na madaling masira kapag hindi naka-direct sa kanya 'yung ilaw.
Offline zer0w1ng
    • The Cebuano Geek
Re: Solar Tracker
« Reply #6 on: September 24, 2009, 03:05:20 PM »
For us in the tropics, solar tracking is easy because we don't have big variations of sun up and sun down in any time of the year.
Even just mechanical solutions could be made.
Just position the panels facing east in the morning and west in the afternoon and returning back to the east during morning.
Just do a 12 hour reversible motor switching and its done.
The Cebuano Geek
Offline n0th1n6
  • Pogi/Ganda Points: 62
Re: Solar Tracker
« Reply #7 on: September 24, 2009, 03:14:02 PM »
Pwede rin ba sir yung approach na ala line following robot yung sensor. 2 photo transistor na properly positioned sa east at west side ng panel tapos pag pareho ang light nila naka brake yung motor. Pag naging mas maliwanag sa kabila andar ng konti yung motor papunta dun hanggang sa magpareho uli yung light magkabilang side. Medyo lagyan na lang ng konting allowance para di naman matrigger ng kokonting variation sa light (hal. me napadaang ibon):)
Offline zer0w1ng
    • The Cebuano Geek
Re: Solar Tracker
« Reply #8 on: September 24, 2009, 05:47:31 PM »
May problema kung auto-seek with intensity feedback kung maging cloudy.  The tracker could go haywire moving west to east to west again.
The simplest is to just do a 12 hour motor speed control.
The Cebuano Geek
Offline n0th1n6
Re: Solar Tracker
« Reply #9 on: September 25, 2009, 09:05:45 AM »
I see. Can it be designed so that an additional wide angle sensor (or array of sensors) monitors the entire surroundings to see if the current amount of light is enough to produce some voltage if not then don't bother tracking the sun? If an array of 3 sensors are used, can we also monitor the difference in the amount of light it picks up, if very little is seen then idle the tracker.
Just thinking out loud :)
Offline zer0w1ng
    • The Cebuano Geek
Re: Solar Tracker
« Reply #10 on: September 25, 2009, 10:10:16 AM »
Pwede siguro with some intelligence in the software.
Pero mas OK and uncomplicated kung TIME based kasi *predictable* na ang movement ng araw even in all days of the year and in different locations.
Motor position could be made using rotary encoders.
The Cebuano Geek
Offline n0th1n6
Re: Solar Tracker
« Reply #11 on: September 25, 2009, 10:27:58 AM »
I see, just exploring the possibilities sir. Yun pong sinasabi mo ay mas simple ang cost effective kasi di na kelangan ng sensor.
+1 :)
Offline zer0w1ng
    • The Cebuano Geek
Re: Solar Tracker
« Reply #12 on: September 25, 2009, 01:00:01 PM »
Thanks for the point ;D .
I was thinking also that servo motors could be used as tracker.
180 degrees and reversible. Easily controlled by adjusting only the pulse width.
This just need a lookup table for PWM width versus the time/angle of the sun.
The Cebuano Geek
Offline n0th1n6
Re: Solar Tracker
« Reply #13 on: September 25, 2009, 01:09:28 PM »
Iniisip ko stepper para di na kelangan encoder, # of steps vs time/angle.
Offline zer0w1ng
    • The Cebuano Geek
Re: Solar Tracker
« Reply #14 on: September 25, 2009, 02:05:45 PM »
Pwede rin stepper.
Pero you have to make sure of the torque is enough.
Else pweding mag-miss ng step and will not be aligned.
Pwede ring auto-recalibrate with a home switch, so everyday ma-correct ang missed steps.
The Cebuano Geek
Offline n0th1n6
Re: Solar Tracker
« Reply #15 on: September 25, 2009, 02:15:33 PM »
Ok, got it sir. San na kaya si TS?
Offline marleona
Re: Solar Tracker
« Reply #16 on: September 28, 2009, 02:52:26 PM »
may mga cirucit po ba kayo pwedeng mapakita dito kung pano gawin ung solar tracker nung lahat po ng sinabi niyo katulad ng 12 hour motor speed control etc... tnx!
Re: Solar Tracker
