Author Topic: Medical Instrument Modification  (Read 1596 times)
Offline Fulcrum
« on: March 16, 2008, 01:53:35 PM »
I have this medical instrument that runs on 4 AA batteries which in turn powers a bulb. It also has a non-illuminated switch to turn it On/Off. Is it possible to have it run on an ac-dc power supply and convert its switch to an illuminated one?  Any referrals as to where I can have it done?
thanks
 :D
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
Re: Medical Instrument Modification
« Reply #1 on: March 16, 2008, 02:06:08 PM »
I have this medical instrument that runs on 4 AA batteries which in turn powers a bulb. It also has a non-illuminated switch to turn it On/Off. Is it possible to have it run on an ac-dc power supply and convert its switch to an illuminated one?..
regarding the power supply,
if you want to maintain/regulate the output of this supply equal to 4 AA-batteries (which equivalent to 6 Volts),
the simpliest, i think, is to use a 7806 regulator IC..
Offline motion55
  • Pogi/Ganda Points: 244
« Reply #2 on: March 16, 2008, 03:03:06 PM »
Is this medical instrument hooked to the patient? Connecting it to AC may pose as a shock hazard to the patient specially to a heart patient. I'd be wary with tinkering with medical instruments specially used in life critical applications.
"Set your mind free!"
Offline Fulcrum
« Reply #3 on: March 16, 2008, 03:07:08 PM »
nope its not hooked to a patient. actually its just a lensmeter.
Offline LAN_sir
« Reply #4 on: March 17, 2008, 09:31:30 PM »
Lensmeter?
Use by optometrist in measuring eyeglass & contact lens power?
What brand?
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
« Reply #5 on: May 31, 2008, 01:58:54 PM »
madali lng gawan ang power supply nyan..  ;)
ung switch naman? hmm. panu ba? using light as a switch? ganun ba po?
use sensors.  ;)
Offline alanjay18
« Reply #6 on: May 06, 2009, 01:11:39 PM »
I'd be wary with tinkering with medical instruments specially used in life critical applications because of the problem regarding to the equipment..
_________________
Ultrasound Repair
Offline fox
  • Pogi/Ganda Points: 11
« Reply #7 on: May 06, 2009, 06:04:08 PM »
_________________
Ultrasound Repair
whats the problem bro.? i don't get it.
spy on me baby use a satellite
Offline fox
« Reply #8 on: May 06, 2009, 06:12:20 PM »
thanks
 :D
bro post mo pic. ng lens meter mo para may idea sila kung ano itsura.
