Author Topic: (altenative) Loader circuit for DS89C4x0  (Read 3956 times)
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« on: October 01, 2009, 12:28:31 AM »
ito gumana ito sa kasagsagan pa ng bagyo.. :D pero inabot ng brownout.. :-\
from the conventional "Serial Load Hardware Configuration"
to this one:
*uses PL2303 from this cable: CHEAP USB-serial interface cable for our MCU projects!
*completely USB-powered
*no other addtional IC (e.g 74xx125)
inside the cdrking's nokia data cable:
connections (tapping of wires):
actual circuit:
*has a pull-up of P3.7 pin (only for some batches of ds89c420 as indicated in the errata)
the 40-pin obsolete DS89C420 (may 2 stocks pa pala ako nito sa province :) ):
the software:
*the actual hardware is not working with version 2.4.10 ??? :-\
*works also with Loader420 and hyperterminal.. :)
http://files.dalsemi.com/microcontroller/dev_tool_software/mtk/obsolete/
Re: (altenative) Loader circuit for DS89C4x0
« Reply #1 on: October 01, 2009, 12:44:40 AM »
nice one... very helpful! :D
Offline clarkent
  • Pogi/Ganda Points: 20
  • iehs
« Reply #2 on: October 03, 2009, 05:53:43 PM »
yus yan ba yung cnasabi mo sakin na cable na nabili mo?ayos ah.kaya lang parang nkakatakot subukan sa laptop.hehe
  • Pogi/Ganda Points: 630
« Reply #3 on: October 03, 2009, 06:54:21 PM »
bakit naman nakakatakot? 'yung USB to UART chip naman ang masisira kung may mali. ;D ;D ;D
« Reply #4 on: October 03, 2009, 06:58:01 PM »
dissection ;D ;D ;D
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #5 on: October 03, 2009, 08:35:24 PM »
the "classic" LED blinker program.. :D
demo:
http://tinypic.com/r/2w4cw7b/4
« Reply #6 on: October 03, 2009, 08:43:02 PM »
panalo talaga ang DS89C450. ;D ;D ;D pwede pang gamitin sa OSD applications. best of all, FREE. ;D ;D ;D
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #7 on: October 03, 2009, 09:22:40 PM »
nung sina-simulate ko sya sa proteus using 8052 device,
parang hindi sya nagbi-blink. yung pala "high-speed" nga pala ang mga DS89C4x0.
kaya ayun inadjust ko na lang yung "delay()".. :)
Offline beginner wan
  • Pogi/Ganda Points: 46
    • [im]Duino
« Reply #8 on: October 04, 2009, 08:57:21 AM »
ayos na ayos yung prototype ah! ang galing!
may question ako dito sir yus, diba yung chip ng dallas may kailangan kang galawin na register para magamit mo sya na highspeed?  ??? ??? ???
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #9 on: October 04, 2009, 10:48:50 AM »
... diba yung chip ng dallas may kailangan kang galawin na register para magamit mo sya na highspeed? ...
ang pagkakaintindi ko, wala ng gagalawin sa registers..
ang pinagkaiba  nya sa 8051 is yung "clock cycles per intruction".
yung DS89, kayang umabot ng 1 clock cycles per intruction (depende sa type ng instruction).
while yung original probably requires more than 1 clock cycles (up to 12),
kaya effectively nadidivide yung speed nya ng execution.
(yung mga pic16F kelangan ng 4 clock cycles bago matapos ang isang instruction)
« Reply #10 on: October 04, 2009, 10:58:45 AM »
ayos yus ah! di ko alam na may proteus model pala na pwedeng gamitin  for testing ...
thanks! ;)
Offline clarkent
  • iehs
« Reply #11 on: October 04, 2009, 12:01:09 PM »
ganun pala yun. ;D hehe cge masubukan nga sa laptop sa opis.hehehe
« Reply #12 on: October 04, 2009, 01:35:40 PM »
ang alam kong may register wan 'yung Timer. pwede kasi siyang i-parehas ng timing sa lumang 8051 para pwedeng drop-in replacement.
« Reply #13 on: October 04, 2009, 01:45:37 PM »
anong ibig mong sabihin nito sis?
ganito ba? same code sa 8051 then compile to 8052, tapos dapat working?
tried ko ngayon... same code dun sa at89c21, pinalitan ko lang yung header sa 8052.h. compile then working naman sa proteus.
#include <8052.h>
#define OVERFLOW_1S 50
char const MAP[ ] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80 };
void timer0_init (void)
TMOD = TMOD & ~0x08;
//T0_CT_ = 0;
TMOD = TMOD & ~0x04;
//T0_M1_ = 0;
TMOD = TMOD & ~0x20;
//T0_M0 = 1; //16-bit
TMOD = TMOD | 0x10;
TR0 = 1;
void main( void )
unsigned char i;
unsigned int overflows = 0;
timer0_init();
P1 = 0x00; // initialize P1.0 = 0;
while(1)
if(TF0)
TF0 = 0;
overflows++;
if (overflows >= OVERFLOW_1S)
overflows = 0;
i++;
if (i>=8) i = 0;
P1 = MAP[i];
« Reply #14 on: October 04, 2009, 02:05:22 PM »
IIRC, naka-default na same ang Timer speed, pero mas mabilis na ang processing. pero pwedeng ilipat sa high speed na 1:1 'yung timer.
    • [im]Duino
« Reply #15 on: October 04, 2009, 02:19:19 PM »
ah.. diko pa kasi nababasa masyado datasheet nya.. tnx sir! medyo napansin ko nga din na iba yung blink ng led ko nung gamit ko yung sa dallas compared sa at89s52..
Offline macky
  • Pogi/Ganda Points: 51
« Reply #16 on: October 09, 2009, 02:05:23 PM »
wow! meron din pala ako sa bin ko nito 2 pcs din:
mahirap ba pag-aralan coding nito?
john 3:16 | oil of gladness
« Reply #17 on: October 09, 2009, 02:21:53 PM »
kung marunong ng C sis, madali lang sa SDCC. ;D
Offline macky
« Reply #18 on: October 09, 2009, 02:30:36 PM »
^thanks!!! SDCC pala yang M-IDE?
Offline clarkent
  • iehs
« Reply #19 on: October 09, 2009, 03:26:54 PM »
to this one:
actual circuit:
the software:
ano po kaya ang pwedeng ipalit sa HC/LS125? wala kasi akong mabilan nito dito sa bicol e. di available sa mga electronics store.
