Author Topic: lm35 problem (milivolts)  (Read 3065 times)
Offline fred070
« on: October 05, 2009, 12:05:08 AM »
hello gandang gabi.. may tanong lng ako about sa output ng Lm35 precision centrigrade temperature sensor. . db may output xa na mV according sa mase2nse nyang heat. for example .. v = temp / 100..
first of all, gusto kong ma retrive ung value ng sensor na to to my computer, (im planning to use rs232 as the connector if availble but i think mrami pa kong dapat gmitn na capacitor resistors IC and etc pra magawa to), so nag isip ako ng  isa pa.. meron ako d2ng device na nakaka measure ng resistance, na nare2ceive nmn ng PC improvised xa pero tlgang gumagana  ;D.. ngaun ung problem ko. pwede kayang gawing resistance ung milivolts na nilalabas ng lm35 prang gn2.. 0.01v = 1 celcius = 100 ohms
i planning to use thermistor, but wla pa kong mkta ngaun d2 haha.. (thermistor = as the temperature increases the resistance increases too)
which is connected in series connection, pero nabasa ko n mas precise daw ung lm35 kesa d2 sa thermistor..
God bless to all :)
Re: lm35 problem (milivolts)
« Reply #1 on: October 05, 2009, 12:49:27 AM »
the easiest way to capture the reading of LM35 is to interface it to an ADC pin of an MCU.
so parang ganito:
LM35 ---> (adc pin) [MCU](UART)<---> level translato(max232) <---> PC serial port.
after that you could check the data sent through hyperterminal.
pwede din gumawa ng simple program sa visual C#.
« Reply #2 on: October 05, 2009, 07:25:52 AM »
meron akong naisip na simple idea sa ADC interfacing through serial port without using MCU. an SPI ADC0831 interface through the serial and bitbanging the handshaking lines
CS and CLK nakadikit sa DTR and RTS outputs, whle yung DO is nakakabit doon sa DSR or CTS inputs. (with limiting resistors + negative and positive voltage diode clamps)
parang ganito:
LM35 --- ADC0831 --- PC serial port
« Reply #3 on: October 05, 2009, 07:41:28 AM »
^sige nga sis, pag-experimentuhan mo!
baka may parts ka naman dyan... ;D
« Reply #4 on: October 05, 2009, 07:54:47 AM »
pag nagpunta ako ng gizmo bili ako ng parts ;D
« Reply #5 on: October 05, 2009, 08:20:37 AM »
sis, meron ako dito TLV1572. di yan differential input... pero SPI din.
pwede din ba yan gamitin sa proposal mo?
turuan mo ako, at try kong gawin. ;)
Offline Shey
  • Administrator
  • Pogi/Ganda Points: 154
    • Elab.PH
« Reply #6 on: October 05, 2009, 09:46:37 AM »
God bless to all :)
LM35 is designed kasi to be interfaced directly on the ADC pin of a PIC microcontroller or on standalone ADC chips..  mas accurate siya sa thermistor kasi linear yung response niya throughout the temperature range na kaya niyang i-measure..
The darkness around me
Shores of a solar sea
Sleeping
Weeping
With you
I walk alone
Every step I take
I walk alone
My winter storm
Holding me awake
It’s never gone
Your dangerous mind
As your true colours show
A dangerous sign
Offline fred070
« Reply #7 on: October 05, 2009, 11:10:50 AM »
parang ganito:
wow! ndi nga? pwde yan ha? without using MCU and max232
tska kuya mejo nalito ako haha.. pwede pa provide po ng diagram, slow po e  ;D
Offline nucleus
« Reply #8 on: October 05, 2009, 11:30:39 AM »
yung project dito:
http://www.riccibitti.com/pc_therm.htm
ayus naman din
Offline fred070
« Reply #9 on: October 05, 2009, 12:16:41 PM »
yung project dito:
ayus naman din
nagawa mo na ba to bossing?
insomartin
  • Guest
« Reply #10 on: October 05, 2009, 12:24:35 PM »
i think kahit di pa nagawa ni sir nucleus eh fully working yan. analysis pa lang ok na ok na.  ;D ;D ;D
Offline nucleus
« Reply #11 on: October 05, 2009, 12:25:21 PM »
yup pati din ata si nothing hehehe
insomartin
  • Guest
« Reply #12 on: October 05, 2009, 12:27:00 PM »
OT:
oo nga pala yan c friend nucleus, resident researcher namin dito sa electronics lab. part time devil's advocate din.
insomartin
  • Guest
« Reply #13 on: October 05, 2009, 12:27:43 PM »
nothing but chu...
Offline n0th1n6
  • Pogi/Ganda Points: 62
« Reply #14 on: October 05, 2009, 12:36:40 PM »
Ay syanga, nagawa ko na pala yan. Kelangan lang na rung regulator ay low dropout, otherwise di talaga gagana yan. At kelangan nyan yung serial port na nakakabit mismo sa motherboard, di ubra ung mga usb to serial from cdrking.
insomartin
  • Guest
« Reply #15 on: October 05, 2009, 12:39:00 PM »
downloading datasheet...
Offline fred070
« Reply #16 on: October 05, 2009, 12:46:22 PM »
wow ang ti2ndi nyo nmn.. prang mdaling gawin.. i2 nga gamitin ko.. tanong ko lng san pwede bumili ng materials n2 esp. dun sa
ds1621 or ds1631 (thermostat[digital temp sensor])
tska lm29 ( ndi ba pwede i substitute ung lm35)?
diode 1n4148 zener diod 5.1 1/2w
capacitor 47microF                -gizmo?
capacitor 100nanofarad          -gizmo?
ganda ganda.. excited na ko gawin!! weee! ;D
Offline fred070
« Reply #17 on: October 05, 2009, 12:50:50 PM »
haha.. xD xD fully working ba? san ka ba nakatira sir nucleus? patingin nga ng gawa m? hehe khit scrShot lng
Offline glutnix_neo
  • Pogi/Ganda Points: 166
    • Underground Workbench
« Reply #18 on: October 05, 2009, 12:51:54 PM »
may project ang electronic enthusiast na ginamit ito, simple temp probe na ang temp reading ay diretso sa mutimeter (10mV IIRC).
Vin, Ground, at Temp lang naman pinouts nya.
gamit kayo webcam may pc interface na kayo, hehehehe, joke.
Offline nucleus
« Reply #19 on: October 05, 2009, 01:23:10 PM »
pero pede sa datacble na katulad nung ginamit ni yus sa DS89C4XX programmer nya, tunay na rs232 level kasi yung output nun di tulad ng sa usb to rs232 ng cdrking na uart level lang
