Author Topic: Current Electricity and Static Electricity  (Read 8066 times)
Offline mumu20
Re: Current Electricity and Static Electricity
« Reply #20 on: July 02, 2010, 07:23:37 PM »
lightning is an example of dynamic electricity....
Offline iyo karpo
  • Pogi/Ganda Points: 18
« Reply #21 on: July 04, 2010, 09:17:35 PM »
anu ba ung dynamic electricity?
ung mechanics dalawa ang clase, statics and dynamics, bago makuha mo ang strength of materials.
ung dynamic electricity at static electricity - pre-requisite ba sa DC Circuit at AC Circuits.
Offline marleytrical
« Reply #22 on: September 14, 2010, 08:33:20 PM »
dito sa russia, everytime na huhubarin ko yung jacket para isabit, malakas ang pitik ng kuryente, para akong kinurot at me sound pa.....mahirap ignorin ang static electricity...
kng winter time mababa ang humidity sa Russia compared sa Philippines.
curious p din may b dito kung bak8 110 volts sa knila ksi masyado fatal sa other country pagnakoryente in 220 volts. ksi mataas ang humidity sa kinila lalo na pagwinter.
Offline iyo karpo
« Reply #23 on: September 15, 2010, 08:05:50 PM »
dapat dual 120/240 Voltage...nagtipid lang ung electric coop at utility sa pilipinas.
ung static electricity hindi nakuha sa outlet...
http://en.wikipedia.org/wiki/Static_electricity
« Reply #24 on: September 16, 2010, 08:30:59 PM »
ump tama p kau dba ang meralco triplex ang service .nila so pagnagconnect k ng line to ground 110 v un tpos pag line to line 220v tama po ba ksi nasa elec coop kmi kaya d qoh sure eh. line to ground 220. hehehehe
Offline Anti-Matter
  • Than The Dunces Are All In Confederacy Against Me
« Reply #25 on: September 18, 2010, 09:34:19 PM »
follow up question ko po ito kasi nalilito ako dito. di ba po hindi naman pwedeng magkaroon ng current flow kapag walang electrostatic charge build up?. Ang kidlat po ba current electricity or static electricity?
Lightning both current and static electricity. A lightning bolt has many thousands of amps at millions of volts. The planet spins, but also has stationary waves through which it spins. It also has friction. Both of these cause the potential in the air to rise, as well as the earth. And yes..the earth has electricity in it. We don't create electricity from nature. We simply borrow it, make it do our bidding, and return it to ground...or "earth"
Don't Try To Click This Link: http://www.subculture.com/wtc
Offline iyo karpo
« Reply #26 on: October 04, 2010, 08:57:25 PM »
anu b ang deferens ng current at static electricity?
Offline pishboy
  • Eternal Flame
    • bosshardhans.comuf.com
« Reply #27 on: December 23, 2010, 03:17:05 AM »
pumutok na ata utak ko...
There's more to electricity than i thought...
Lightning itself is static discharge, so lightning is electricity. Before lightning is static electricity and after lightning is kulog :-)
Static is the potential while electricity is the movement. Parang salita. Static is the words while electricity is the action (satsat ng satsat, wala namang ginawa...)
-pirma-
Offline sczion
« Reply #28 on: January 19, 2011, 09:29:31 PM »
Lightning is a form of static electricity... Recall from our gradeschool that a simplest way to produce static electricity is to rub two things w/ very high ionization ability (Pert. to periodic table) examples could be Sodium(Na) and Chlorine(Cl)... I wonder if you can... Just an example. in  analogy with the earth's atmosphere, there is somewhat a collision or sometimes rubbing between molecules of different gases in the atmosphere which results in "lightning" it is considered a static electricity because the transfer of electrons isn't caused by an EMF but simply by molecular collisions which are in nature.
Offline thevenin
  • Pogi/Ganda Points: 19
« Reply #29 on: January 23, 2011, 08:59:54 PM »
cspcboy....sa naga ka nagaaral?... ano real name mo?....
Offline iyo karpo
« Reply #30 on: January 28, 2011, 09:12:41 PM »
naging away pa namin as PEEE - itong What is electricity.
http://amasci.com/miscon/whatis.html
« Reply #31 on: January 31, 2011, 03:31:34 PM »
so lahat pla tyo may tma.ufter I read dis links naliwanagan n q.
Offline robbietan
  • Pogi/Ganda Points: 17
« Reply #32 on: February 09, 2011, 05:36:19 PM »
meralco does not offer a 110V service. they offer 230, 400, 460 and 34.5kV service - all measured line to line.
in some provinces, the service is 220V line to "neutral". "ground" lines are not supposed to carry current under normal circumstances.
apqi.ph
Offline iyo karpo
« Reply #33 on: April 24, 2011, 03:01:33 AM »
Meralco uses 1.5 element meter - same meter used in North America that has 220/110 volt service.
Since Meralco does not provide a ground wire like most residential installations in North America, it does not supply 110 volt service.
  • Pogi/Ganda Points: 521
« Reply #34 on: April 24, 2011, 10:08:43 AM »
^ and this is because our 220 volts is derived from 3phase 440 volts line to line voltage......so all this talk about putting one line and ground is hogwash.....
it may interest you to know that some areas in Pampanga near the Clark air base has this 110 volt service....
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
« Reply #35 on: April 24, 2011, 10:58:45 AM »
maraming sekreto at pinanggagalingan ang kuryente
pitikin mo lang yagbols mo eh makukuryente ka na agad
Offline robbietan
« Reply #36 on: May 03, 2011, 07:29:05 AM »
please do not mistake ground wire and neutral wire. ground wire is not a current carrying conductor, it is there to carry only fault current. a neutral wire is a current carrying conductor.
in the usa, the utility provides 3 wires - a live wire, a neutral wire and a ground wire.
meralco does not provide a neutral wire, although they now provide a ground wire - which makes 3 wires for new residential installations
apqi.ph
Offline robbietan
« Reply #37 on: May 03, 2011, 07:44:24 AM »
meralco service is 34.5kV, the backbone of its distribution system. for residential users, meralco provides a transformer that has a 34.5kV primary and a 230V secondary. for commercial users, meralco provides a transformer with a 34.5kV primary and a 480V secondary. heavy industrial users directly connect to the 34.5 kv lines. really, really large customers are allowed by meralco to tap to their 115kV subtransmission lines
apqi.ph
Offline iyo karpo
« Reply #38 on: May 23, 2011, 01:00:14 AM »
to clarify confusion between ground wire and neutral wire, here are the diagrams of North American Metering installations:
http://www.ic.gc.ca/eic/site/mc-mc.nsf/vwapj/CS-E-XX_AppendixA_e.pdf/$file/CS-E-XX_AppendixA_e.pdf
North American residential service has 3 wires.
Offline robbietan
« Reply #39 on: June 23, 2011, 04:37:53 PM »
meralco meters (for residential) have 1 PT and 2 CT, one CT for each leg. newer residential installations have a ground wire that can be used for equipment grounding
apqi.ph
