one thing tungkol d2 sa post ni nucleus di po ganitopag more fuel = less power or puwedeng malunod na tinatawag in mechanic term then pag nalunod mahirapan na pandarin or di aandarang theory po nito ay sa fire triangle ignition, fuel. oxygen sa tatlong yan mawala ang isa wlang fire.one good example: mag lagay ka ng alcohol sa glass container then sindihan mo tapos habang may apoy inti unti mong takpan ang baso ma recognized mo na habang lumiliit ang butas ng baso humihina ang apoy hangang sa matakpan mo mamamatay ang apoy kahit may alcohol pa sa loob
naikwento nga sakin ito ng tatay ko sa intake manifold yung nilalagyan ng charge yung fuel para mas madaling macombust
kng gusto mo madaling ma com bust kelagan mo ng high octane or Nitrous oxide called nitro to evaporate the fuel quickly. hindi yung electric arcing which contribute as igniter. kasi ang arcing saka spark plug ay parehas ng function
You mean you are trying to make ozone.. and feed it to the combustion chamber..I think it will make combustion more efficient since it has 3 oxygen(O3) instead of 2 (O2).. but saying that its energy efficient ay medyo diskumpyado ako cause I think it takes a lot more energy to make ozone artificially than you would make if you burn it.. pero siguro kung makakakuha ka ng ozone freely sa environment then it would make for a better combustion.. One problem is that Ozone being 3 oxigen is verrrry corrosive to metals not only that it is very reactive(like pure Oxygen remember the warning on pure oxygen tanks) might also combust metals on contact( imagine mo na masusunog pati casing ng engine).. at isa pa its very toxic.. so practicality of using it is alanganin..unless you want to cheat on racing na kahit masira engine at baterya basta manalo lang ehhh bahala ka na.. di ko lang alam how much ozone is produced in a corona at kung malaki nga ba ang naitutulong nito kasi kung kunti lang na ozone parang wala ding epek.....
I think it will make combustion more efficient since it has 3 oxygen(O3) instead of 2 (O2).. but saying that its energy efficient ay medyo diskumpyado ako cause I think it takes a lot more energy to make ozone artificially than you would make if you burn it.. pero siguro kung makakakuha ka ng ozone freely sa environment then it would make for a better combustion.. One problem is that Ozone being 3 oxigen is verrrry corrosive to metals not only that it is very reactive(like pureOxygen remember the warning on pure oxygen tanks) might also combust metals on contact( imagine mo na masusunog pati casing ng engine).. at isa pa its very toxic.. so practicality of using it is alanganin..unless you want to cheat on racing na kahit masira engine at baterya basta manalo lang ehhh bahala ka na.. di ko lang alam how much ozone is produced in a corona at kung malaki nga ba ang naitutulong nito kasi kung kunti lang na ozone parang wala ding epek.....
meron akong plan for experiment dahil ang carbon monoxide ay cause ng unburned fuel yung unburned fuel na ito ibabalik mo sa engine para ma fully burned
magiging less efficient ang engine mo nito, mas mabuti pa cguro kung siguradohin na lang na sapat ang oxides (i think meron ng ganitong mechanism ang mga modern designed cars
correction po sa madla ang exhuast po ng engine ay hindi carbon dioxide(CO2) ang sa realidad po carbon Monoxide(CO) due to luck of oxygen and ang carbon monoxide pong cycle ito di gaya ng CO2 na ang kumakain nito ay plants and trees. but car exhaust without a catalytic converter contains 7,000 parts per million.meron akong plan for experiment dahil ang carbon monoxide ay cause ng unburned fuel yung unburned fuel na ito ibabalik mo sa engine para ma fully burned
try nyo nga Agua Oxinada na additives....H2O2 pwede kaya?
sa totoo lng yung binabalik yung un burn fuel meron na nito sa sa karamihan engine except motor cycle itong passage na ito ay yung tinatawag na PCV valve kung kamilar ka sa engine? at kung alam mo ang parts ng engine and function pero this PCV ay small amount lng ito ng un burned fuel na ibinabalik. yung experiment na balak ko na try mo na ba? at yung nasa isip ko alam mo kung paano ang gagawin ko? ride on ka nalang bro tayo din ang makikinabang d2 pag sucess ang experiment ko ang tanong ko lng sa mga manufucturer ng mga engines bakit hindi nila built-in ang turbo sa engine as engine parts kesa sa gawa cla ng gawa ng mas malaking engine na walng turbopangalawa kung titignan mo ang turbo simple parts lng ito compare mo sa engine na mas malaki pero bakit mas mahal pa ito or parehas na ang price ng engine?pang tatlong tanong nagawa na ang catalytic converter but still mahal ang price nitokung talagang eco friendly ang mga gumagawa nito dapat mura ito para sa mundoor ginagamit lng nila ang word na eco friendly ko the money ang tunay na eco friendly ay yung may knowledge sharing without money talk
puwede siguro kung Gas form di gaya ng N2O(nitrous oxide) na gas formpangalawa kung hahalo ito sa gasoline + h2O2 mag hahalo kaya?according sa wikipedia ginagamit din yung H2O2 sa rocketry same as N2Oang pinag kaiba lng wla sinabi na puwedeng gamitin sa car racing ang H2O2 ang mga sulution lng kasi puwede ay:Add hydrogen contentadd oxygen contentand reburn the unburn fuelHydrogen peroxide (H2O2) is a very pale blue liquid, slightly more viscous than water, that appears colorless in dilute solution. It is a weak acid, has strong oxidizing properties, and is a powerful bleaching agent. It is used as a disinfectant, antiseptic, oxidizer, and in rocketry as a propellant.[2] The oxidizing capacity of hydrogen peroxide is so strong that it is considered a highly reactive oxygen species.
so importante na optimized (by proper tune-up) yung air/fuel mixture na pumapasok sa engine to minimize CO emmissions.
