Author Topic: How to make PCB using XEROX???  (Read 11594 times)
Offline marcasjr™
« on: March 19, 2008, 06:12:30 PM »
Need to Iron ???
What paper I will use ?
Instruction please...
Offline kamote
  • Pogi/Ganda Points: 4
Re: How to make PCB using XEROX???
« Reply #1 on: March 19, 2008, 06:27:15 PM »
puedeng gumamit ka ng transparency...
or the other method is baby oil...
print mo circuit sa magandang printer...  tapos apply mo ng baby oil, hangnag magign translucent ang paper..
punasan mo excess oil... ready na ipatong sa photopcb.  this is applicaple sa medyo makakapal na traces up to 25 mil (based on my experience) :P
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
« Reply #2 on: March 19, 2008, 06:29:33 PM »
I have done this but using laser printer.
I used GLOSSY paper from magazines. You could use your new FHM issue.  ;D
Needs the PCB to be cleaned and sanded well so that toner will stick.
Print the positive mirror image of the design.
Place the paper on the sanded/cleaned PCB with the toner marking touching the copper of the PCB.
I placed another clean bond paper (without printings) on top as protective layer.
Iron the paper. Slide the iron without moving the magazine paper.
If you feel it already sticking. Just estimate it or do trial and error for the exact time because this depends on your clothes iron.
Then dip it in cold soapy water. Wait for a few minutes until the paper is partially dissolved.
Rub the paper off with your thumbs but carefully not to include the toners stuck on the copper.
The difficult part to the remove is the holes on the pad. So bigger pad holes is better.
After, you could directly dip this to your Ferric chloride of Cupric chloride solution.
The Cebuano Geek
Offline zer0w1ng
    • The Cebuano Geek
« Reply #3 on: March 19, 2008, 06:31:46 PM »
I am using ordinary tracing paper in printing designs for photo pcb exposure.  You could buy this cheap at National Bookstore.
The Cebuano Geek
Offline marcasjr™
« Reply #4 on: March 19, 2008, 06:45:53 PM »
Pde po bang instead na laser printer ay XEROX?
may nabasa kac ako sa net
Offline zer0w1ng
    • The Cebuano Geek
« Reply #5 on: March 19, 2008, 07:01:10 PM »
Maybe.
But honestly, I don't know.
I only tried using laser printer.
You could try it though. Just make sure the PCB are cleaned well and sanded. If not, the toner won't stick.
The Cebuano Geek
Offline jr_agustin2008
  • Proud member of the IECEP EVSU-SC!
« Reply #6 on: March 19, 2008, 07:44:27 PM »
mr. Marcasjr  sabihin mo po kung natesting mo ung xerox..
kasi that sound very interesting.. ;D tnx
EVSU... EVSU what???
Offline marcasjr™
« Reply #7 on: March 19, 2008, 08:34:49 PM »
Ok,I will try it tomorrow ;)
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #8 on: March 19, 2008, 10:32:42 PM »
Madali lang ito. Ang PCB design i-print mo using inkjet or laser. Tapos ipa-clear photocopy mo, several copies. Tell the attendant to set to "very dark" setting para oki ang result. Pwede mo gamitin yung special na bondpaper. Tapos plantsa-method na  ;D
Since you have many xerox copies, pwede ka mag trial&error if first time mo magplantsa-method
OR
ipa-photocopy mo using ordinary acetate and use it for presensitized PCB. Though, mas oki kung print mo nalang agad sa colored transparency yung PCB design para no need to photocopy
« Reply #9 on: March 19, 2008, 10:36:24 PM »
anu pong special na bondpaper??
Offline paranz
« Reply #10 on: March 19, 2008, 10:40:25 PM »
kahit ano basta huwag lang ordinary bond paper. Pwede tracing paper if ok sa xerox machine. Ok rin daw ang photopaper.
Offline macky
  • Pogi/Ganda Points: 51
« Reply #11 on: March 20, 2008, 08:04:55 PM »
i use backing sheet of wallpaper stickers, mas kumakapit talaga sa PCB pag-iron mo within 20 seconds of full settings ng electric iron mo.
mas maganda ang transfer kung kaka-labas lang ng printout sa laser printer/xerox machines at iplantsa mo na.
john 3:16 | oil of gladness
Offline marcasjr™
« Reply #12 on: March 21, 2008, 08:25:37 AM »
pweeedeee... ;)
« Reply #13 on: March 21, 2008, 10:23:27 AM »
huwaw! galing! tnx for the info...
 ;D ;D heto pogi points na lang.. hehe
Offline marcasjr™
« Reply #14 on: March 21, 2008, 04:05:35 PM »
I use xerox instead of laser printer,bihira na shop d2 sa batangas ang meron laser printer  ;D
may konting error ata ano?pintel pen mode ;D
  • Pogi/Ganda Points: 412
« Reply #15 on: March 23, 2008, 03:46:10 PM »
Hoy Lito!! bat mo naman siniwalat yung process natin?? bwehehehe...nice to see you here boz...
I totally agree...used the sticker backing paper..yung madulas na paper na naiiwan after removing the sticker..print with laser printer or any copier machine (toner type ha) then iron it on habang mainit-init pa!!
RBT
  • Pogi/Ganda Points: 630
« Reply #16 on: March 23, 2008, 03:54:01 PM »
mas gusto ko yung FHM na hiniram lang... ;D
« Reply #17 on: April 04, 2008, 10:42:40 AM »
ok lang naman yung xerox ang gamitin for plantsa method. kasi sa tingin ko lang ha: parehas naman ang component ng toner ng laser at xerox machine. di ba heating yung process para matransfer yung toner sa paper?
teka lang. di pa ako nagwiwiki! hehehe
Offline macky
« Reply #18 on: April 09, 2008, 01:57:08 PM »
RBT
sabi ko na ikaw yan rhonnz!
akala ko kasi hindi mo sikreto yan, kasi sinabi mo sa akin HEHEHEHEHE!!!
okey laang yan, at least naibulgar natin na sayo nagmula yang process or teknik na yan:
CORRECT or BEST MEDIUM for Iron-On transfer sa PCB etching!
Offline paranz
« Reply #19 on: April 09, 2008, 02:21:42 PM »
Marami na yata nakakaalam nito, hindi na ito sekreto  ;D
