Author Topic: program settings of ic-prog  (Read 2645 times)
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
Re: program settings of ic-prog
« Reply #20 on: November 05, 2009, 06:14:01 AM »
ICD2 is much better than JDM or serial based programmer.
Pwede ring mag-realtime-debug dito and it could be used directly with MPLAB without any 3rd party software.
The Cebuano Geek
Offline clare
« Reply #21 on: November 05, 2009, 06:22:24 AM »
any pc, laptop, notebooks pd po gamitin?? basta po my mplab? at my usb to serial???
see the opportunity in every difficulty,  not see  difficulty in every opprtunity
Offline zer0w1ng
    • The Cebuano Geek
« Reply #22 on: November 05, 2009, 06:42:21 AM »
Pwede kung ICD2 yung gagamitin mo.
MPLAB is the IDE/devt software para sa programming only.
ICD2 will work with a usb-to-serial converters.
The Cebuano Geek
insomartin
  • Guest
« Reply #23 on: November 05, 2009, 10:22:24 AM »
di mo pa napapagana yung jdm mo, tapos gusto mo na bumili nang icd2?
and you haven't isolated the problem yet. knowing that there is a very big chance your icd won't work with usb/serial converter. trust me... get if fixed first before starting a new set of headaches.
Offline Herder
« Reply #24 on: December 11, 2009, 06:22:43 PM »
rin,
anu po ginamit mong programmer at burner para na save mo ung .hex file sa AT89c2051?
thanks.
Offline tiktak
  • Pogi/Ganda Points: 204
    • Tiktakx's Blog
« Reply #25 on: December 11, 2009, 06:44:51 PM »
^^PIC16F84A po ang gamit ni rin, try to check this LINK or here if you insist on 2051 or better yet bili nalang kayo ng burner sa alexan  ;D
8051 stuff
Offline clare
« Reply #26 on: December 11, 2009, 09:22:17 PM »
icd2 n po ung gamit kong burner hehehe... ok naman po za sa serial.. pero kpg my converter ayaw nia heheheehe
Offline tiktak
    • Tiktakx's Blog
« Reply #27 on: December 11, 2009, 09:31:22 PM »
ayos! may debugger ka pa ;D ;D ;D pickit2 sa akin ;D
8051 stuff
Offline clare
« Reply #28 on: December 11, 2009, 09:34:56 PM »
gusto ko ung junebug ni nucleus! heheheh maganda ung ganon madali pa gamitin hehehe uumitin ko nga sana eh hahahahaha ;D ;D ;D
« Reply #29 on: December 11, 2009, 09:37:40 PM »
sige kunin mo lang ng kunin, madaming pera yang impaktang ms yumul na yan heheh ;D
Offline tiktak
    • Tiktakx's Blog
« Reply #30 on: December 11, 2009, 09:40:20 PM »
go! go! go!  ;D
8051 stuff
Offline clare
« Reply #31 on: December 11, 2009, 09:52:33 PM »
bruhita un ayaw ibenta sakin hehehe ayun napilitan ako magpabili ng icd2. heheheh ;D ;D ;D nitong mga huling araw eh nabuhay un eh heheh nawala na naman hehehehe ;D ;D ;D
« Reply #32 on: December 11, 2009, 09:53:39 PM »
namasyal yata gamit yung yate ng bf nyang italyano ;D
