Author Topic: Advisable sensor (type and model) to detect very near objects  (Read 1900 times)
Offline danechi08
« on: November 17, 2009, 08:52:01 PM »
anu pong maiaadvise nu na sensor (type, and model), na maglologic one lang pag super lapit na ung object?as in mga 1-5 mm nlng ung distance dun lang xa maglologic one...gagamitin ko kasi sa automatic pencil sharpener.pag ung tip ng pencil ay super lapit na dun sa sensor, maglologic one ung sensor, then papatayin nya motor.aun.thanks
Offline Born2BeWired
  • Pogi/Ganda Points: 168
    • e-Gizmo Mechatronix Central
Re: Advisable sensor (type and model) to detect very near objects
« Reply #1 on: November 17, 2009, 09:41:42 PM »
Gamitin mo microswitch para simple at mura. Maraming available sizes and form factor ang microswitch. Pick the one suitable for your application.
Offline danechi08
« Reply #2 on: November 17, 2009, 09:45:13 PM »
microswitch?meron po nun sa egizmo or alexan?
Offline Mayalin22
  • Pogi/Ganda Points: 400
« Reply #3 on: November 17, 2009, 09:47:26 PM »
suggest lang to... yung encoder ng mouse pwede cguro  :D liit lang non
Offline danechi08
« Reply #4 on: November 17, 2009, 09:54:18 PM »
ay required pla na sensor  ung gamitin, so nde considered ung microswitch..
ung sa mouse?/prang optocoupler ?e dba po, mag logic 1 parin un kht malayo medyo distance?
Offline Mayalin22
« Reply #5 on: November 17, 2009, 10:01:30 PM »
pag na-block ang slot non magbabago ang state ng output.
  • Pogi/Ganda Points: 630
« Reply #6 on: November 17, 2009, 10:11:51 PM »
sensor:
A device or organ that detects certain external stimuli and responds in a distinctive manner
detector: any device that receives a signal or stimulus (as heat or pressure or light or motion etc.) and responds to it in a distinctive manner
it's a common misconception na 'di sensor ang mga simpleng bagay. minsan kasi pinapa-complicate din ng prof ang requirements, pero sa engineering world, the simpler you implement it, the better engineer you are. ;)
'yung sa mouse, makikita mo 'yung may wheel na may slot. ;)
Offline danechi08
« Reply #7 on: November 18, 2009, 08:49:11 PM »
ok thanks po.
sa tingin nu anu suitable for this application?
capacitive sensor? or optosensor na very near lang range
Offline Shey
  • Administrator
  • Pogi/Ganda Points: 154
    • Elab.PH
« Reply #8 on: November 18, 2009, 08:55:49 PM »
ok thanks po.
I would suggest reflective object sensor like CNY70 or OPB607 available in RS Philippines or Farnell Philippines..
The darkness around me
Shores of a solar sea
Sleeping
Weeping
With you
I walk alone
Every step I take
I walk alone
My winter storm
Holding me awake
It’s never gone
Your dangerous mind
As your true colours show
A dangerous sign
Offline Mayalin22
« Reply #9 on: November 18, 2009, 09:53:00 PM »
parang mahirap i-sense ang tip ng pencil kung capacitive sensor gagamitin.. pwera na lang kung higanteng pencil  :D :D :D
mainam talaga dyan opto.
Offline danechi08
« Reply #10 on: November 21, 2009, 11:54:48 PM »
so, ung CNY70 po kea, magbabago ang state kung madedetect nia ang longitudinal area ng lead at the back of sharpener?ung po kc problem namin, since medyo manipis ang lead ng pencil.tas ung ilalim nmn ng sharpener ay may gear attached to the motor.
Offline ferdie444
« Reply #11 on: November 22, 2009, 12:19:59 AM »
bro,try to look proximitor switch probe.bale inductive type yan(made of coil) @ ang typical application nyan ay limit switch tulad ng ginagamit namin dine sa planta na indicator for close & open position ng mga control valves.pag ang tip ng proximitor ay nalapatan ng object(metal/conductor) ay mag-iiba ang output noon once na nakabit sa switching circuit.another application ay sa vibration monitoring & measurement.lahat ng vibration probe ay may gap voltage(initial position/setting),so pag lumaki ang gap ay tumataas ang gap volt. @ pag lumiit ay bumababa ang g.v.till zero even vert. & horiz. position.i think pupwede ito sa application mo.try to search bentley nevada products @ baka may available na dealer dyan sa pinas or dyan sa raon na equivalent.thanks and good luck.
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
« Reply #12 on: November 22, 2009, 12:22:00 AM »
how about itong photo reflective sensor na ito kayang kaya nyang i detect ang malapitan at medyo maliit din sa tingin ko kaya naman nya ang sa lapis
8051 stuff
insomartin
  • Guest
« Reply #13 on: November 22, 2009, 12:28:29 AM »
these are cost efficient way of detecting objects. microswitch have a switching offset of at lease .5mm meaning it can detect and switch (logic high or low or bahala kna).
meron sa egizmo, deeco at alexan nito. add more if you need to. smaller the better.
Offline kelvinblank
« Reply #14 on: November 22, 2009, 01:04:06 AM »
idol tlg mga tao d2
Offline danechi08
« Reply #15 on: November 22, 2009, 06:32:29 AM »
wow.andamin nu pong naitulong.super duper salamat!.!
ferdie, electron and tiktakz, thanks=)!on my way to raon to search for those items=)
Don martin.wow.career mode.thanks sa visual representation.kaso, nde dw tlga pde microswitch smin.try q ulit kulitin.sna pumayag.
thanks sa inyong lahat!.ill try yo update you for the improvement
Offline ferdie444
« Reply #16 on: November 24, 2009, 12:11:38 AM »
@danechi08, you're welcome bro @ ganyan talaga dito sa forum...tulungan.good luck....
Offline danechi08
« Reply #17 on: November 24, 2009, 09:51:32 PM »
girl nga po pla q.nde boy.hahaha.=)
Offline danechi08
« Reply #18 on: November 24, 2009, 10:08:13 PM »
ay guys, pinayagan na pla kami na microswitch gamitin.aun.anu kaya magandang orientation nung microswitch with respect to the sharpener's side, since the bottom is already occupied by the gear
insomartin
  • Guest
« Reply #19 on: November 24, 2009, 10:11:33 PM »
