hello mga sirs I'm an electronics tech graduate at TUP. I am trying to repair this TV. Kolin (KC-21CS5). The problem is there is no B+ that's going to the Flyback transformer. I tried to look for a manual for this brand in Quiapo but to no avail. Can you help me?
mga sirs patulong naman po bout sa TV, kahit medjo OT kasi monitor to, tutal ang pinagkaiba naman ng tv sa monitor ay yung tuners eh..di po talaga kasi ako makahanap sa net ng definitions as well as operations ng:1. Synchro-guide2. Synchro-phase3. Synchro-lockbukas na po ito TIAtnx tnx tnx
Mga bossing good day! Patulong naman dito sa monitor ko..when i turn on lahat lang ng LED nakaturn on din...anu kaya sira nito..LG Studioworks 454V ang monitor ko.thanks in advance
Sony Blinking CodesMany of the later model Sony TV's have a built in Self- Diagnosis function. Ifthe timer/standby indicator is blinking, this could be an indication of theproblem with the unit. The diagnostic blinking will occur automatically with noaction required by you to engage it.The timing of the blinking you see would be as follows: two to eight blinks(depending on the fault) about a third of a second apart, then pauses for 3seconds, then the two to eight blinks about a third of a second apart again.Here is a list of the problems that might have occurred indicated by thenumber of blinks. The words in parentheses are those which you will see foreach of these faults on a diagnosis screen described later in this article.Unit is dead and there are no blinks---Problem in the standby powersection. Might check fuse, R607, Q601, IC601, R612 and VDR601 (shouldshow open)Continuous Blink Once A Second, No Pausing As Discussed Above---No reply from the jungle IC301 (data bus is busy, shorted to ground or heldhigh), IK video path is defective.ONE Blink--- not used for the self-diagnosisTWO Blinks---B+ over current protection (OCP) , unit goes to the standbymode then displays the 2 blink fault. Could be a short in the power supply ofany of the circuits.THREE Blinks---B+ over voltage protection (OVP), unit goes to the standbymode then displays the 3 blink fault. This is also a problem in the powersupply circuit, check T603 and R672.FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a singlehorizontal line then the video signal muted. Check IC1509, Q1505FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about30 seconds then goes to the self-diagnosis function. Something is wrong withthe video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,try turning up screen slightly.SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosisfunction immediately. Check C515 & 516 and the jungle IC, IC206.SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33kand the unit goes immediately into safety shutdown. Check power supplyregulation and horizontal circuits.EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby andblinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.Intermittent problems ?? This is a great feature. You can also bring upthese fault codes ON-SCREEN to see a list of the problem numbers with theabbreviation of the problem and the number of times this problem hasoccurred. This is slightly different than entering the service mode. To see thediagnostic screen, Press the following buttons:Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings upa screen with a list of the problems and number of times they have occurred.Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.We have repeated them in parentheses in the text for the "Blinks" describedabove so you can correlate between the diagnostic screen and the blinkcodes.So, now that you know about these self-diagnostics, how do you use them?Say that you have a set with a black screen. You see that the LED is blinking4 times....This would tell you that you have no vertical and that is why thevideo is muted. If it was blinking 6 times, you would know that you have ahorizontal fault.It's not a sure cure, but it's a little better than a poke in the eye with a sharpstick.IMPORTANT: after you repair the unit, PLEASE clear the values on thisdiagnostic screen. These codes do not reset themselves after the fault iscorrected, so if you don't clear them, you'll be seeing "old" fault codes thenext time you enter this screen.Clearing is done by going into the service mode ( display, channel, 5,volume plus, then power ) then press 8 and Enter, which of course returnseverything to the factory preset condition.
