Author Topic: PA HELP PO SA MGA COMPUTER EXPERTS....  (Read 1272 times)
Offline eljay06
« on: November 22, 2009, 05:34:06 PM »
mga idol nid ur help.......
NO DISPLAY PERO GUMAGANA UNG CPU.....
UNG YELLOW LIGHT SA MOBO NAKA ON NAMAN(sa loob)...pero ung led sa labas ung red lng ung umiilaw ung yellow nde...
all fans gumagana......
nid help po pls..........
Offline boki
  • Pogi/Ganda Points: 7
  • Hampaslupang trabahador
    • Magatol pa sa Ikus
Re: PA HELP PO SA MGA COMPUTER EXPERTS....
« Reply #1 on: November 22, 2009, 07:00:03 PM »
Kindly check your video card if it is properly inserted and/ or gently wipe its connector with a rubber eraser. Then re-insert again. If not successful, try to find other video card you may test to your unit.
Offline jeje-BUSTER
  • Pogi/Ganda Points: 12
« Reply #2 on: December 10, 2009, 09:06:48 PM »
nakakarinig ka ba ng beep codes during boot up?? kung meron pa, malamang bad memory or bad video card lang.. you can try sir Boki's suggestion..
last month kc nagloko pc ko.. ganyan din symptoms, walang beep codes, walang video out..all lights on sa board, all fans turning..
board na pala ang sira.. kaya hinabol ko warranty, papalitan daw sa january.. ayun libre replacement ko.. hehehe
-=jeje=-
Offline BANNEDMemberAccount
  • Pogi/Ganda Points: 130
« Reply #3 on: December 10, 2009, 09:25:49 PM »
aabutin ng 1 wik karamihan sa warranty minsan mahigit isang buwan pa. sa tunog madalas makuha kung ano sira depende sa brand ng mobo mo. kapag ganyan walang display
  • Pogi/Ganda Points: 433
« Reply #4 on: December 10, 2009, 09:51:57 PM »
Unahin mo itest ang monitor mo kung ok. Kung ok malamang video card. Or memory.
Since mas maganda icheck muna memory card kung marumi yung edge connector nyan. Linisin mo using pensil eraser method. Tanggalin mo muna sa system yung CPU at mismong saksakan para totally walang power saka mo gawin yung paglilinis (hawak ka rin muna sa bare metal ng CPU case para magdischarge ng static sa kamay). Then reinsert at test uli. Pag hindi yun naman video card mismo kung plug in lang yan. Pag hindi pa rin, lipat mo naman sa kabilang slot yung memory card mo na kaparehong spec. Kapag hindi pa rin.
Kung wala ka spare na video card o memory card mas mainam dalhin mo na sa shop. Para di ka madoble ng bibilhin kung alin talaga nasira. O kung may warranty pa gamitin mo na lang warranty.
Sana makatulong sa iyo.
Offline dheckz
  • everything i need is you... my beginning my foreve
« Reply #5 on: January 20, 2010, 11:08:47 PM »
ganyan din naging sira ng PC ko..tnry ko lahat ng trials walang nagnyari... mobo daw ang sira sabe nung agent na bnilan ko ng unit ko.. bago pa naman kaya replace agad... hehe
Offline zai
« Reply #6 on: April 23, 2010, 12:06:48 AM »
pag nagbbrowse ako may ibang site na puro CHINESE CHARACTERS or kung anong characters un na di ko alam...puno ung page na puro ganon...naguupdate naman ako ng java... anyone who could help?? please...
Offline voltaman_krc
  • aruuuuu!
« Reply #7 on: April 23, 2010, 12:16:12 AM »
try to change the video card if you have spare.
or maybe sa memory, do you hear a beeping sound? if yes, try to reconnect the memory, then clean the connectors with
an eraser. after doing it, reconnect the memory to the motherboard.
usb kayo ng usb.... "FLASH DRIVE" ang tawag dun.
Offline de PatAtas
  • Pogi/Ganda Points: 330
  • ' The unbreakable
« Reply #8 on: April 23, 2010, 08:31:11 AM »
' try mo pres yung numlock o capslock sa keyboard mo....pag umilaw sya..vcard nga ang problema , pero kung di sya umilaw..its means di po gumagana ang mboard mo,,try mo linisin mga slots ng RAm tsaka, mo on ulit,,dapat makakarinig ka ng isang beep lang,,,
Offline engineer7@home
  • Google Search--> Noel Rios Circuit Cellar
« Reply #9 on: May 21, 2010, 01:10:12 AM »
Yung LED sa motherboard which is lit means Standby power is OK if the power supply is OFF.
If you hear One long beep and two short beeps, it means Bad Video Card
If you hear a continous beep, it means the memory is Bad.
Please check the speaker if it is OK to hear the beeping sound according to POST.
Please also try to remove all devices in the expansion slots and start with a plain memory and/or video card to isolate the failure.
If this helps, please give me a pogi point.
Love the Lord your God with all your heart & soul and with all your mind & strength.And love your neighbor as yourself.
The devil only comes to Kill,Steal & Destroy John 10:10
UKrobotics
Microcircuits gave me schizophrenia for Php2600/month in 1992
« Reply #10 on: May 21, 2010, 01:19:06 AM »
Sometimes, the settings in the CMOS memory gets corrupted and you must CLEAR the CMOS settings by moving the jumper to one position and returning it to the original position.
Also, if the Lithium Battery falls below 3.0V this problem also appears since the non volatile memory cannot retain the current settings.  The battery backed SRAM or non volatile memory has a lower limit to remember its current state.
UKrobotics
