Author Topic: peso-5peso-10peso bill  (Read 1570 times)
Offline -Al-
  • nomanisanisland
« on: December 03, 2009, 06:42:32 PM »
mga master...idea naman po on how to distinguish in electonic means ang piso sa 5peso sa 10peso coin..   ;D
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
Re: peso-5peso-10peso bill
« Reply #1 on: December 03, 2009, 06:45:14 PM »
baka po coin ;D ;D ;D, mechanical means sa amin dati para ma detect ang .25, piso at 5 magka size kasi 5 at 10 kaya .25 nalang ginamit namin dati, wait nalang po natin mga masters :D
8051 stuff
Offline -Al-
  • nomanisanisland
« Reply #2 on: December 03, 2009, 06:52:52 PM »
coin pala... pinalitan ko na...hehehe..sorry
Offline toasted siopao
  • Global Moderator
  • Pogi/Ganda Points: 107
    • TeknoBlogger
« Reply #3 on: December 03, 2009, 06:55:07 PM »
Compare the weight from a reference.
Offline -Al-
  • nomanisanisland
« Reply #4 on: December 03, 2009, 07:17:45 PM »
iniisip ko po kasi walng problema sa piso coin..ang mahirap ung 5piso sa 10piso...are there any other possible ways?
  • Pogi/Ganda Points: 630
« Reply #5 on: December 03, 2009, 07:25:51 PM »
size plus imaging ang gamit ng ibang acceptor. medyo madugo lang. hehehe.
Offline RaffT
  • Pogi/Ganda Points: 103
  • more on R-n-D
    • MY Bots
« Reply #6 on: December 03, 2009, 08:02:34 PM »
mag iba ba diameter ng 5peso at 10peso?
Offline LuffyX
« Reply #7 on: December 04, 2009, 11:38:05 AM »
tol..itu2loy mu ba ung balak mong toilet system?. na huhulugan mo ng 5 piso para maaccess cr.. tas another piso for tisue or 10 piso ung all-in-one?.
Nobody wants to be alone.
"Christ Above All"
Offline -Al-
  • nomanisanisland
« Reply #8 on: December 04, 2009, 01:31:50 PM »
iniisip ko lang..vendo taz pwedeng manukli... ;D
image processing daw eh... T_T
patay....
« Reply #9 on: December 04, 2009, 02:23:21 PM »
parehas sis. ang alam meron lang mini ridges 'yung 10 peso coin para madaling salatin kung nasa bulsa.
« Reply #10 on: December 04, 2009, 02:33:12 PM »
mahusay sumalat si sis rdp ;D
« Reply #11 on: December 04, 2009, 02:38:04 PM »
binubuko mo naman ako sis. ;D ;D ;D
kopya ata 'yung nung HK na coin, makapal nga lang.
Offline abo0badr
« Reply #12 on: April 29, 2012, 12:50:43 PM »
yan tlga ang problema mo..kc ang 5 tsaka 10 halos mgkapariho ng size,,yung iba metal detector yata ang gmit..compare yung amount ng copper sa 5 peso sa 10 then declare condition,,,pro d ako sure..since mechanical (gawa sa kahuy) ung gAmit ko sa multi-coin project n gnawa ko..1 coin slot pro it accepts 3 denominations
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
« Reply #13 on: April 29, 2012, 01:01:01 PM »
Nabuhay na naman. ;D ;D ;D ;D
Offline nucleus
« Reply #14 on: April 29, 2012, 01:19:02 PM »
bili na lang ng coin selector na electronic, yung iniipitan ng sample coin, pag di same ng sample coin yung ihulog mo ay irereject nya ito kahit magkasing laki pa
Offline Vandread007
« Reply #15 on: April 29, 2012, 01:42:28 PM »
Weight lang ang pwede ipagcomparan ng 5 at 10 peso coin.
ganito pwede mong gwin,
Compare muna size to separate 1 peso and 5-10 peso. Pag naghiwalay na, saka mo na iseparate ung 5 and 10 peso using weight..
God is the greatest Engineer.
If at first you don’t succeed, call it version 1.0.
ACK and you shall receive.
Calculating in binary code is as easy as 01,10,11.
Black holes suck.
Photons have mass!? I didn't even know they were Catholic...
« Reply #16 on: April 29, 2012, 02:23:28 PM »
pwede pa rin ang color pattern, may silver lining kasi yung sampu.
  • Pogi/Ganda Points: 53
« Reply #17 on: April 29, 2012, 08:48:45 PM »
sa e-gizmo may multicoin ACCETOR naman ;D
1,5,10 ata' plses
Offline e-tronix
« Reply #18 on: April 29, 2012, 10:14:46 PM »
1,5,10 ata' plses
gusto niya yata DIY eh.
