Author Topic: Best Schematic to Pcb converter?  (Read 1115 times)
Offline Carla
  • ~Simply Carla~
« on: December 05, 2009, 11:07:05 AM »
Ano po ba ang magandang gamitin pang convert sa PCB from Schematic?
Offline Google
  • Pogi/Ganda Points: 20
Re: Best Schematic to Pcb converter?
« Reply #1 on: December 05, 2009, 11:32:41 AM »
Circuit Wizard
Offline Carla
  • ~Simply Carla~
« Reply #2 on: December 05, 2009, 11:53:59 AM »
natry ko pa lang po is PCB wizard... complete po ba components nyan and madali lang pong gamitin?
  • Pogi/Ganda Points: 635
« Reply #3 on: December 05, 2009, 11:57:53 AM »
wala namang best pagdating dito, depende lang sa preference. ;)
KiCAD gamit namin dahil open source, legally free. library nung schematic capture medyo kulang pero madali namang gumawa ng parts. library naman ng footprints sa PCB, merong nakukuha na converted from Eagle, though madalas, sariling footprint pa rin ang gamit.
Offline clare
« Reply #4 on: December 07, 2009, 02:00:55 PM »
dip trace maganda rin gamitin heheeh try mo heheehe tamad kasi ako... madali gamitin kahit kapain mo lng ung functions ^_^ madami rin xa mga components
see the opportunity in every difficulty,  not see  difficulty in every opprtunity
Offline subzer0
  • Pogi/Ganda Points: 38
  • Garbage In Garbage Out.
« Reply #5 on: December 07, 2009, 02:26:47 PM »
yung eagle marami na syang footprint,ok na ok sya at kayang laparan ng elongated yung pads for DIYer's and hobbyist using presensitized etching:-)
Signing Off...
Offline bose5566
  • In God We Trust.
« Reply #6 on: December 11, 2009, 05:12:12 PM »
yung circuit wizard,sir anung link....
Life is a contact Sport.
