Author Topic: sharp 14" 110V AC japanese tv  (Read 5028 times)
Offline Siramiko
  • Pogi/Ganda Points: 35
  • thank you elab
Re: sharp 14" 110V AC japanese tv
« Reply #60 on: December 16, 2009, 11:36:56 AM »
additional po, sa horizontal section at first my nakita akong coil yung bilog na my apat na terminal, nakita ko un putol na ung connection nya sa secondary kasi sa sobrang manipis, what i did duon ako kumuha ng pang replacemnet sa board ng ibang tv na 21" na my ganitong hitsura, ung size nya pareho, ung marking lng nya at top ang mgkaiba. and im in doubts if pwede ba ito pang replacement, duda kasi ako na walang available sa electronic store. pls i need ur suggestion rgarding this. thnks
mag babago nga ang width nyan kapag sira ang coil na yan
I shall return
Offline I n s i d e r 2010
  • Pogi/Ganda Points: 100
« Reply #61 on: December 16, 2009, 12:40:31 PM »
hor drive transformer yan bro,mababago ang frequency mo pag mali ang nailagay bro pero marami naman yan sa mga chop chop board.
Offline cass
  • Pogi/Ganda Points: 6
« Reply #62 on: December 16, 2009, 12:58:35 PM »
pero my mabibili ba dito sa electronic shop bro?
« Reply #63 on: December 16, 2009, 01:08:27 PM »
parang wala eh,baklasin mo nalang ung orig nyan, unahin mo baklasin ung nasa ibabaw na mas malaking magnetic wire,then ung maliit na wire,idugtong mo na kz simple lang yan at basta maibalik mo sa orig turns ang coil sure gagana na yan.
Offline cass
« Reply #64 on: December 16, 2009, 01:27:58 PM »
my napansin na naman ako mga masters, madaling uminit ung dalawang resistor na naka parallel, 2watts po, na 470ohms at 1 k. nakaparallel cya po patungong flyback, pero hindi nman cya nag change value. normal ba un?
  • Pogi/Ganda Points: 915
« Reply #65 on: December 16, 2009, 01:39:18 PM »
agreed   baklasin   mu  nlng  yan...  at  hanapin  ang  naputol  na magnetic  wire & connect  ulit..
pwde  pa  yang  remedyuhan... sayang  yan...
gudlak...
Offline cass
« Reply #66 on: December 16, 2009, 04:46:15 PM »
ung dalawang resistor na naka parallel ay connected with B+ po cya
« Reply #67 on: December 16, 2009, 07:25:16 PM »
iinit talaga yan bro! wag lang na pwding pagsindihan ng cigarrete at may overload na sa out nyan.
 ;D ;D ;D
Offline cass
« Reply #68 on: December 17, 2009, 09:51:57 AM »
at kagawad, nkahiram ako ng analog tester sa kaibigan ko, sinukat ko ung B+ main filter cap, ung negative probe po ay connected with ground neck ng crt at ng tinutok ko ung positive probe ng positive cap bumaliktad ung reading, patungong left ung needle...i tried with 9v battery ok naman ung reading 9v....ayyyyyy! naku mabuang ko crispin, ;D gusto ko ng umiyak.. ;D
bro ung binabanggit mo na cap eh width cap un na nkaparallel sa hor out at ground. sa b plus cap ka magsukat ng voltahe kz pag sa collector ng hor out ka magsukat eh false reading ang masusukat mo kz ung tester na gamit mo ay ndi effective sa hor output checking. try to disconnect ung socket ng deflection yoke then check the voltage dun sa sec cap at wag dun sa mismong hor out.pag 100volts plusang reading  ikabit mo ngayon ang yoke at pag ndi nagbago ang voltahe it means ok na ang hor ckt mo. malapit ng matapos ang unit mo bro,gudluck at natutumbong este natutumbok mo ang mga payo ng mga master d2. kaunting tyaga lang bro at sabi nga nila pag may tyaga may nilaga.
Online pete
  • Pogi/Ganda Points: 771
« Reply #69 on: December 17, 2009, 10:10:20 AM »
k lang yan transformer driver lang naman pala yan.. try mo lang. :D :D
Offline Vaounsi
  • Pogi/Ganda Points: 146
« Reply #70 on: December 17, 2009, 10:55:12 AM »
mainfilter cap sa primary? dapat ang ground mo ay sa primary din kaya nagnegative yan ang nasukat mo.kung tinutukoy mo ay filter cap sa secondary b+ make sure na ang negative ground mo ay connected sa chasis..
nagawa mo na ba ang hdt na naputol? gawin u muna un bago u problemahin iba sir.. wag ka umiyak baka lalo masira yan pag natuluan ng luha mo.. ;D ;D ;D
Offline cass
« Reply #71 on: December 17, 2009, 11:02:44 AM »
ok na po ung naputol na coil po, at ung tinutukoy ko po ay ung secondary filter cap, chassis ground ung black prove ko po, ung ground na sa neck ng crt, pwede ba un?
Offline Vaounsi
« Reply #72 on: December 17, 2009, 11:09:54 AM »
yap pwede, pag sa analog mo ginamit naganegative? e sa digital mo? baka may tama analog tester mo sa high range v..
« Reply #73 on: December 17, 2009, 12:26:22 PM »
bro kung ok ang tester mo at pag sinukat mo ung b plus nya at nagnegative reading pakicheck ung connection ng crt ground papuntang ground ng crt board. sure putol yun.
Offline cass
« Reply #74 on: December 17, 2009, 12:39:09 PM »
kagawad bumaliktad lng ung needle ng analog meter ko, hindi mabasa. cg tingnan ko ung ground nya frm crt to board baka open
« Reply #75 on: December 17, 2009, 09:48:57 PM »
subscribing  nlng  muna  (^_^)
Offline cass
« Reply #76 on: December 18, 2009, 10:49:43 AM »
kagawad ok nman po ung crt ground. at ngayun ung B+ nya naging stable na rin 115V ung reading, ang problema nga hindi ko alam kung mgkano B+ ng tv na to, normal ba to? sa pin ng flyback my nasukat ako na 137V sa 6-pin, ano kaya un? at RGB transistor sa crt board ung dalawa 130V at ung isa 100V lng. t napansin ko po hindi umilaw ung heater filament, pero my nasukat ako sa pin ng flyback na 6.2V suspect ko un ang heater voltage. tama ba ako mga masters?
« Reply #77 on: December 18, 2009, 11:28:11 PM »
6.3V yan  nga  ang  heater  voltage  check  mu  kng  umaabot  ba  yan sa  CRT board mu.. baka  kasi  open yung fusible resistor mu...  kaya  hndi  umiilaw  o  mismu  CRT/picture tube  ang Sira  kaya  hndi  umiilaw
tungkol nmn sa RGB  mu  hndi  yata  balansee  ang supply  mu masxadong mababa ang isa...  check  mu  muna ang  C  board..  &  sali  mu  na rin ang  jungle/chroma ic
Offline thomz
  • Always follow the golden rule....
« Reply #78 on: January 21, 2010, 06:26:20 AM »
ok po ba ung ginawa ko sir ac-dc? ung green na capacitor po ay connected to D1554 at collector terminal to ground. pag pina pull out ko un, stable ung B+, pag connected po un magsimulang umakyat ung B+. cg po palitan ko nalang ung D1554 at ung 474/200 na capacitor?by the way anong purpose ng cap na un sir?
pasingit lang mga sir ang pagkakaalam ko kc yong capacitor na nkkbit s HOT collector @ emitter ang function nyan is for tuning, kasi yong frequency ng hor.  (15.7 khz) klangan steady nk tuned kc yang hot, flyback,yoke at tuning cap pag isa dito nawala or change value magbbgo frequency. good for you di bumibigay hot mo pag tanggal to nk encounter n kc ako na change value tuning cap namumutok ng hot. sana makatulong
Online pete
« Reply #79 on: January 21, 2010, 10:26:10 AM »
pag shorted siguro ang cap na to pero kong tinanggal lang malamang babago lang ang size ng picture.
