Author Topic: sanyo 14kx2- standby mode  (Read 1106 times)
Offline charlie
  • Pogi/Ganda Points: 14
« on: December 08, 2009, 01:55:20 PM »
jungle la7681a
regulator c4429
vertical la78040n
problem: satandby mode
pag "on" yung mga voltage sa chopper or secondary ok naman kaya lng sandali lng
i replaced vertical ic same problem
any one who can help me salamat po
Offline Vaounsi
  • Pogi/Ganda Points: 146
Re: sanyo 14kx2- standby mode
« Reply #1 on: December 08, 2009, 02:40:54 PM »
hang mo hot mo po, then observe b+ kung shut down pag on mo po... pag shut down , PS problem mo, pag hindi nagshut down secodary PS poblem mo po.. para malamn lng natin kung saan prob ng shut down..
Offline edz
« Reply #2 on: December 08, 2009, 02:59:32 PM »
bro makesinget lang baka makatulong ako sau,ung test prod mo ilagay mo sa fly bck 24V DC tapos On mo sa remote kong may high voltage ba.kong mayron man tapos mawala agad ung suppply bro.sure ako cra ang resistor.
Offline charlie
« Reply #3 on: December 08, 2009, 08:26:24 PM »
bro eto yung mga voltage sa secondary ng chopper when power sw. is sw. on
always B+voltage 125v
always B+voltage 18v
always B+voltage 24v ( standby voltage ) sw. to supply vertical output ic
hang ko line papunta ng fb shut down pa rin
hang ko yoke same pa rin
Offline Vaounsi
« Reply #4 on: December 08, 2009, 08:34:59 PM »
ayon sa iyong statement na hung muna b+path papuntang flyback shut down pa rin.. ibig sabihin primary PS problem mo, focus ka ngaun sa PS.. check ecaps, diode, regulator ic..replace regulator para malaman mo agad..
  • Pogi/Ganda Points: 924
« Reply #5 on: December 08, 2009, 08:40:03 PM »
c4429 ang  reg. familiar  sa  akin  yan  hah...
paki check  nyu  nga  yung signal  diode  malapit sa vertical section  i forgot the exact part number location..
kalimitan  short  yan...  nakapakamot  ulo  din  yan sa akin
baka  kasi  pareho..  try  nyu  lng  wla nmng  mawwla   (^_^),V,,
