Author Topic: PROBLEM ON MY CPU.  (Read 1429 times)
Offline rochoy
PROBLEM ON MY CPU.
« on: December 08, 2009, 10:27:25 PM »
pag-on ko po ng avr automatic na din pong nagbubukas un cpu tpos kelangan pa pindutin un F1 para magstart un pc sa default.
anu po ba solusyon dun? ???
PROBLEM ON MY CPU.
  • Pogi/Ganda Points: 433
Re: PROBLEM ON MY CPU.
« Reply #1 on: December 09, 2009, 08:45:39 AM »
Sir ano po motherboard brand po nito? Malamang po CMOS battery kailangang palitan.
Offline nucleus
« Reply #2 on: December 09, 2009, 11:05:16 AM »
sya nga CMOS battery :)
Offline KANGARO
  • Pogi/Ganda Points: 18
« Reply #3 on: December 09, 2009, 12:17:02 PM »
CMOS wrong setting bah ang nakalagay....tapos pagbukas mo nde na exact ang date & time...replace battery and try to clean up ur PC.
Offline BANNEDMemberAccount
  • Pogi/Ganda Points: 130
« Reply #4 on: December 09, 2009, 12:31:29 PM »
pagka -cmos battery napapansin mo jan. yung time mo laging nagrereset. tapos minsan hihingi ng setting sa cmos.
kapag nag-oon kahit nde mo pindutin ang on ng cpu, posibling may shorted na sa mobo mo.
MSI ba mobo mo?
kaya ko naitanong kasi yan ang laging problema ng msi after 1 year
« Reply #5 on: December 09, 2009, 12:40:31 PM »
Check mo yung power config settings sa bios settings mo.  Usually may mga settings dyan na auto power-up yung pc one it detects power.  This is normally needed kapag nagkaruon ng power failure so that the pc would start up itself once power is restored.
Offline rochoy
« Reply #6 on: December 11, 2009, 10:47:29 PM »
salamat2 po check ko po 2om un motherboard slamat!
Offline kiD.elab
  • kiD at eLab
« Reply #7 on: April 06, 2010, 09:43:58 AM »
yhup, pag F1 - cmos battery
pag auto power on - cmos settings, ganyan ginagawa ko, (minsanan lang)
bAkit pag si Andrew E. - shOwtimE .. sHowtiMe .. pAg si viCe gaNda naMan. - kaBayo ,, bakLa ,, baKLa ,, hOi ..! - kaBayo ngA bA siYa?
Offline de PatAtas
  • Pogi/Ganda Points: 330
  • ' The unbreakable
« Reply #8 on: April 06, 2010, 10:17:50 AM »
' bili ka CR2032 batt.,then e set mo ang TIME AT DATE masusulusyonan ang paf FF1 mo,,pero yung sa on agad sya sa palagay ku di na sa Batt yan..
Offline enriz622
  • Pogi/Ganda Points: 304
« Reply #9 on: April 08, 2010, 09:37:29 PM »
malamang stuck-up ang switch o kaya dirty, walis ng kunti
Offline /
  • Pogi/Ganda Points: 317
« Reply #10 on: April 08, 2010, 10:55:21 PM »
Sa cmos set up po, sa state after power loose i lagay mo sa off.
Offline enriz622
« Reply #11 on: April 08, 2010, 11:55:43 PM »
tama si hunter sa cmos nga yan, default siguro ang on,bagsak na kasi cmos nya, change mo na lang setting pag napalitan mo na new batt.
