Author Topic: digital potentiometer and DAC question  (Read 2860 times)
Offline cyanine
« on: March 22, 2008, 08:30:48 PM »
what would be the disadvantage or advantage if i use a digital potentiometer as DAC instead of a regular DAC?
Re: digital potentiometer and DAC question
« Reply #1 on: March 22, 2008, 11:04:27 PM »
gusto ko rin malaman ito...
yung mga digital pot na nagagamit ko is hanggang 1mA lang ang maximum current na pwedeng idraw sa wiper ng pot kaya gumagamit pa ako ng op-amp voltage follower. kaya iniisip ko kung imamigrate ko yung ginagawa ko kasi andaming mapagpipilian na DAC at antataas pa ng resolutions (nakita ko kanina sa analog.com) or may alam pa kayong digital pot na serial interface (I2C or SPI)?
Offline cyanine
« Reply #2 on: April 10, 2008, 12:10:33 PM »
nang mag research ako sa google napakita ko na limitado pala ang resolution ng digital potentiometers. wala nga akong nakita na 12 bit  ???
« Reply #3 on: April 10, 2008, 12:13:42 PM »
hehehe.. kaya limitado ako sa 8-bit digital pot sa ginagawa kong project ngayon huhuhu...
buti na lang nakita ko itong thread na ito... hihingi nga pala ako ng samples sa maxim ;D ;D
Offline cyanine
« Reply #4 on: April 10, 2008, 12:18:23 PM »
8 bit digital pot din ang gamit ko :(
« Reply #5 on: April 10, 2008, 12:28:32 PM »
kakatapos ko lang humingi ng samples sa maxim... ;D
  • Pogi/Ganda Points: 635
« Reply #6 on: April 10, 2008, 02:03:43 PM »
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« Reply #7 on: April 10, 2008, 06:40:57 PM »
meron din dito... ;D
http://www.intersil.com/DCPs-DCCs/
eto 10-bit digital potentiometer...
http://www.intersil.com/cda/deviceinfo/0,0,X9118,0.html
TSSOP package <-- hindi magandang hingan ng samples..  :D
« Reply #8 on: April 10, 2008, 08:45:17 PM »
 ;D ;D ;D
pag nasira mo sa pag-solder maiinis ka lang... ;D
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #9 on: April 10, 2008, 08:47:18 PM »
buti sana kung may kasamang development board/kit..
« Reply #10 on: April 10, 2008, 08:59:09 PM »
dati andami niyan sa TI...napghalataan siguro na pinapakyaw kaya hindi na sila nagbibigay ng board...
meron dati 20W Buck Converter, 10W Class D Amplifier (for headphone and portable players), Power Multiplexer (for switching from battery to line power), madami pa, naiwan ko lang sa laboratory sa school... :'( ang nauwi ko lang yung Power Multiplexer...
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #11 on: April 11, 2008, 06:57:14 AM »
hindi pa ako nakagamit nitong digital pot.
Ano ba ang pinaka-common na IC?
Saan makabili dito sa pinas?
« Reply #12 on: April 11, 2008, 07:07:49 AM »
hindi ako sigurado kung saan meron...lahat kasi nung sa akin, hingi lang...baka sa mga nagre-repair ng mga bagong amp, digital pot gamit ng mga yun, logarithmic taper...
Offline razalas
« Reply #13 on: April 11, 2008, 07:16:18 AM »
It depends on the DAC you're comparing. If Sigma-Delta DAC vs D-pots, resolution and linearity  are the advantages of Sigma-Delta. For Flash DAC, most likely the same since they both uses semiconductor resistor ladder.
2^8 = 256 means 256 taps....
2^16 =  65536 means 65536, laki ng die nito and for sure mas mahal vs 16bit Sigma-Delta DAC.
Offline razalas
« Reply #14 on: April 11, 2008, 07:17:01 AM »
Dalas Semi/Maxim produces these types of ICs.
Offline glutnix_neo
  • Pogi/Ganda Points: 166
    • Underground Workbench
« Reply #15 on: April 11, 2008, 07:57:10 AM »
resolution is one thing, isang disadvantage is hindi straightforward ang control(I2C or other serial protocol) unlike sa DAC pwede diretso from binary - analog(well, depende din sa dac na gagamitin).
