Author Topic: Sony kv-21gmr1mkII no power (share ko lng)  (Read 3781 times)
Offline ado
« on: December 19, 2009, 10:52:26 AM »
shut off agad wala png 5sec.ok nman ang b+115v.sira ung fbt (8-598-960)
Offline thomz
  • Always follow the golden rule....
Re: Sony kv-21gmr1mkII no power (share ko lng)
« Reply #1 on: December 27, 2009, 06:43:11 AM »
tnx pano mo nalaman na sira yong flyback bro
Offline dan.enriquez
  • Pogi/Ganda Points: 52
  • Serbisyong Totoo
« Reply #2 on: December 27, 2009, 10:40:02 PM »
 :D :D :D :D :D :D
Offline magsy
  • Pogi/Ganda Points: 7
  • BT995 MONSTER RADIO 5TH LEVEL G-MALL BAJADA D.C.
    • www.rx931.com
« Reply #3 on: December 27, 2009, 10:49:04 PM »
palagay ko ang sira dito yung technician hindi yung fly back.... ;D ;D ;D
THE LAND OF PROMISE DAVAO CITY PHILIPPINES  wwwrx931.com
  • Serbisyong Totoo
« Reply #4 on: December 27, 2009, 11:18:13 PM »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline thomz
« Reply #5 on: December 29, 2009, 02:23:37 PM »
nawala na di nasagot tanong ko. dito kasi samin sa gapo may nagche check flyback nagpa check nga lang me kanina 40 petot singil. meron syang mga aparato na may oscilloscope kaya sure ball dahil kita pati waveform ng signal. meron ding project pang test ng flyback yong tinatawag nilang ring test. mga led lang ang indicator pero dko lam kung sigurado.
Offline KANGARO
  • Pogi/Ganda Points: 18
« Reply #6 on: December 29, 2009, 02:39:31 PM »
nde un accurate sis,,ung led ang indicator......ang alam kong pangtest ng flyback un talagang may lumabas na current
Offline thomz
« Reply #7 on: December 29, 2009, 08:22:03 PM »
@ XIII "The Conspiracy"
tingin ko rin nga gnun. pro khit si sam naglabas ng gnung klase ng tester.
Offline I n s i d e r 2010
  • Pogi/Ganda Points: 100
« Reply #8 on: December 29, 2009, 08:26:05 PM »
cguro checked  na nya ang b plus nung alisin nya ang flyback kaya sure na sya sa post nya
nagshare na nga ung tao ng nagawa nya eh kaya d dapat pagtawanan bro
bakit super galing ka ba at sinabi mo na ang sira ay ung technician?
  • Serbisyong Totoo
« Reply #9 on: December 30, 2009, 02:04:37 AM »
corrected by...sir KAGAWAD...
Offline Vaounsi
  • Pogi/Ganda Points: 146
« Reply #10 on: December 30, 2009, 08:31:53 AM »
hehehe lagot kau palo kau master kagawad;D ;D ;D ;D
karamihan sa sira ng flyback di mo na kailangan pa check, pag baguhan ka siguro papacheck ka pa, pero pag experience na alam mo na kung saan susukatan ang flybck kung shorted, alam mo rin sa sukat palng ng voltahe sa b+, marami paraan na masasabi na sira ang flyback habang nagtrotrouble shoot ka po...diskarte lng...
Offline thomz
« Reply #11 on: December 31, 2009, 07:00:22 AM »
 @Ac-Dc
baka marami ka mai share sa flyback testing mas maganda siguro gawa tyo ng thread para dyan.
Offline Siramiko
  • Pogi/Ganda Points: 35
  • thank you elab
« Reply #12 on: December 31, 2009, 07:14:34 AM »
ayus! salamat sa share mo
share mo naman kung pano mo na sigurong yan ang sira, at yung pamamaraan  para macheck ang flyback
baka meron ka pang mai-sheshare dyn wag ka mahiya,   mag share ka pa  ;)
I shall return
« Reply #13 on: December 31, 2009, 08:19:15 AM »
[/quote]
korek AC_DC
noon bago pa lang ako sa trouble shooting nagaalangan pa ako kung sira nga ang flyback
kaso wala pang available na checker noon d2 sa malapit sa amin
 sabi nung master ko hanap ako flyback at swap namin
ganito  diskarte ko kung alanganin nga ang flyback
may xtra ako 1  flyback pang check kung may pagbabago sa b plus
b plus lang naman ang mostly problema (dropped b plus)
hayaan mo na yung sa secondary voltages nito as long as nagoscillate ito for a seconds lang
mga masters ndi pa naman ako pumalpak sa pagrereplace ng flyback
kahit ala na ako flyback checker
'voltage measurement lang ang katapat nun' sa unit board
Offline Vaounsi
« Reply #14 on: December 31, 2009, 08:48:58 AM »
smple tips kung sira flyback...
b+ drop, pero nakahang ang hot, pag disconnect sa primary pin ng flyback good b+...
shorted between ground, primary pin, collector pin ng flyback may
resistance reverse, dapat parang diode masukat..
friying noise sa flyback, sa sony palit muna ng crystal oss, pag nag friying parin sira flyback..kasama na sipol..make sure lng na good lahat parts sa paligid ng flyback..
laging sibak h-out kahit nakahang na ang yoke.. check din diode sa vertical nakasiback din ng h-out..
h-voltage shut down, tangaling anode cap, then power up ang unit, using long screw driver, observe ang arking, dapat kulay blue, pag red or yellow sira flyback...
no output sa ibang pin, pero nagagawan paraan kuha ka lng sa flyback pulupot ka lng ng wire.. pero my ibang model na my feed back galing flyback ang hdt, pag ganito palit na flyback..
cyempre kasama na  visible na arking dyn, sa lahat ng parte ng flyback..
sana nabyan ko kau tips..
Offline thomz
« Reply #15 on: December 31, 2009, 09:30:14 PM »
ayos salamat ng marami
Offline marcialnasi
« Reply #16 on: January 03, 2010, 08:49:32 PM »
ganito para mas madali ung trouble shooting natin lagi nyong isama ung number ng jungle ic para makapag bigay naman ako ng short cut method especiaaly sa sony magandaa kc ung protect nyan kaya d mo mapipilit mag oscillate yan pag me trouble.
« Reply #17 on: January 03, 2010, 08:52:23 PM »
sis umpisahan mo na at susunod kami
about sony protection muna
Offline marcialnasi
« Reply #18 on: January 03, 2010, 09:02:51 PM »
halos lahat ng sony models merong x-ray protect circuit.short cut method ko po check b+=normal check +24v on vertical supply=normal(pero as syempre dropping dahil nag shu ahutdown) ika nga walang overload.check HOT kung overheating=normal naman/pin out mo na agad kung aling pin ng jungle ung x-ray protect then short to ground mo.monitor b+ habang i po power on mo pag normal.check raster check audio kung meron then un ok na po.sometimes  u really need to dis able the x ray protect para malaman mo ung source nung culprit..pero sad to say ung mismong x ray prot ang me problema.. un lang po salamat sana makatulong
  • Serbisyong Totoo
« Reply #19 on: January 03, 2010, 09:12:38 PM »
ayos..
