Author Topic: what is the purpose of twisting wire pairs  (Read 915 times)
Offline Captcha
« on: March 22, 2008, 11:46:27 PM »
is this for structural puroposes only or is there some good reason why they twist wire pairs?
Offline spidamang
  • Pogi/Ganda Points: 27
    • Iwan nyo na ang friendster, mag Facebook na kayo!!! :D
Re: what is the purpose of twisting wire pairs
« Reply #1 on: March 22, 2008, 11:50:43 PM »
It is to eliminate crosstalk;D
Confidence: The feeling you have before understanding the situation.
« Reply #2 on: March 22, 2008, 11:50:59 PM »
crosstalk.
Offline penny
  • Pogi/Ganda Points: 22
« Reply #3 on: March 22, 2008, 11:51:14 PM »
Para macancel out ung EMI
  • Pogi/Ganda Points: 631
« Reply #4 on: March 23, 2008, 01:54:36 AM »
a little explanation...
EMI is proportional to the current and the area of its loop i.e. from the source to destination back to source...
kung yung wires mo spread apart ng 1 mm, 1 meter long wire will have an area of 1000 mm^2...kung twisted yung wire mo, near 0 yung area mo kaya lessened yung effect ng noise current...
Offline Born2BeWired
  • Pogi/Ganda Points: 168
    • e-Gizmo Mechatronix Central
« Reply #5 on: March 23, 2008, 11:25:21 AM »
Lahat ng sagot ay tama, and this one hits the bulls eye. Once a wire forms a loop, it acts as a radiator and receptor (antenna, if you will). Twisting the wires together eliminate this loop and minimizes this problem. Twisting will also keep the impedance of the wire constant over its lenght. This is also a good thing. :)
« Reply #6 on: March 23, 2008, 11:31:09 AM »
naranasan ko na ito nung nag implement ako ng CAN based data acquisition...   ;D ;D ;D
