Author Topic: interfacing our parking system to the pc and sa mobile phones...  (Read 2298 times)
Offline tondyay
« on: December 28, 2009, 12:58:13 PM »
sir.. pde po mkihingi ng advice para sa thesis namin. we are currently working with our thesis na parking system using microcontroller.. we would like na m.interface nmin cya sa sa pc using database programs.. (yung parang mg.lolog.in ka sa isang computer sa internet cafe?). ano pung ikakasugest nyu.. at yung system namin ai mai mobile application.. ex..ung custmer ay ng ng.text na gusto malaman  ang status ng parking area.. panu yung information na galing sa pc m.tratrasfer via mobile..any suggestions na medyo madali lng???... tnx.... ;)
Offline kelvinblank
  • Pogi/Ganda Points: 4
Re: interfacing our parking system to the pc and sa mobile phones...
« Reply #1 on: December 28, 2009, 01:05:38 PM »
ung communication between sa customer and the server via sms gagamit ka ng gsm module. pwede ka gumamit ng globe tattoo para makamura ka, if my pera ka mga 5k+ pwede ka buy ng benq gsm module sa e-gizmo. problem lang sa mga gsm modules if iapply mo sya sa underground parking or ung covered na parking baka maging issue ang signal dito.
« Reply #2 on: December 28, 2009, 01:33:28 PM »
Use an MCU with UART, thesis lang naman so i guess you dont have to use RS485 network para maextend ang connection.. connected sa serial port ng PC.. pero gagamit ka pa rin para sa GSM Module mo(if GSM Modem ang gagamitin, if yung Broadband modem di na kasi USB ito)
anong program ang gagamitin nyo? VB?
as for the sms, you can integrate it on the application that you are going to make...
we do have similar system like this.. pero wala syang SMS...=)
all in all you have to focus with your software...=)
Offline tondyay
« Reply #3 on: December 28, 2009, 01:36:34 PM »
ahh KK..so ang problema nlng dito ai kung pano magagamit ung GSM module... d pa kac nkakagmit nun... mahirap pa mg.modify gmit nito.. magagamit pa rin ng AT commands?....available ba yung gsm module ng globe tatoo?
Offline tondyay
« Reply #4 on: December 28, 2009, 01:41:51 PM »
sa program nami JAVA programming ang plano namin gagamitin... tska ung para sa port RS232 ok lng po ba yun?
« Reply #5 on: December 28, 2009, 02:10:08 PM »
yeah gagamit kayo ng AT commands.. yung sa Globe tatoo.. yep pede yun check mo muna yung thread dito before proceeding...
yup RS232 = serial port... yun ang gagamitin mo=) the PC will serve as the Master
Offline kelvinblank
« Reply #6 on: December 28, 2009, 02:14:09 PM »
java po gagamitin? medyo mahirap ata yan as far as i know kasi sa vb.net ung mga classes meron na gagamitin mo na lang sila at idedeclare para magamit. hmm pero kung magaling kayo sa java go
« Reply #7 on: December 28, 2009, 02:26:15 PM »
sa Java, research on Java Comm API... yung new version ng Java Comm 3.0 API IIRC, Linux ang target OS... yung version 2  ng Java Comm API ang ginamit ko dati para sa windows...
although check mo din yung RXTX for java baka may mapulot kang useful info http://rxtx.qbang.org/wiki/index.php/Using_RXTX
Offline tondyay
« Reply #8 on: December 28, 2009, 03:42:47 PM »
ah..so mas madali sa VB..gagaw rin kac kmi ng database sa whole parking area.. ang problema nmin kung pano i.interface yung information nkuha ng sensor nmin sa PIC na gagamitin den pic to pc den pc to the gSM module..baguhan lng kac kmi so wla kming nalalaman..
Offline kelvinblank
« Reply #9 on: December 28, 2009, 03:49:07 PM »
pwede mo post ung block diagram nyo?
Offline tondyay
« Reply #10 on: December 28, 2009, 03:51:06 PM »
ung para sa pic to the sensors Mplab gagamitin namin...
« Reply #11 on: December 28, 2009, 03:51:35 PM »
VB6 at .NET madali lang gamitan ng serial port... if you can freely use any language, ok na ang .NET language (C# or VB.NET)...
about database at pag .NET ginamit nyo, pwede nyo din gamitin yung Microsoft SQL Server na kasama pag naginstall ka ng Visual Studio Express...
PIC to PC == use UART
PC to GSM == depende kung ano gagamitin nyong GSM modem
ano ba yung isesense ng PIC?
Offline kelvinblank
« Reply #12 on: December 28, 2009, 04:00:20 PM »
i advice na mysql gamitin nyo kasi pwede nyo imerge yung mga database na galing sa ibat ibang pc into one
Offline tondyay
« Reply #13 on: December 28, 2009, 04:09:31 PM »
ang incoming and leaving car ang i.sesense ng PIC... so parang mai database containing ilang oras na ng.papark ang car at elan na ang babayaran... so microsoft Sql can be used para mka.interface ng ganitong fuctions from pic to pc?
Offline kelvinblank
« Reply #14 on: December 28, 2009, 04:16:48 PM »
ung sql is ung ggmtin mong database na nanggaling sa pic papasok ng pc for example ung sensor mo sa pic nagccount pg my nasesense na kotse na papasok tapos every count nya is madadagdagan ng +1 ung table entry mo sa database na name ay car count, sa tuwing my papasok na kotse ung pic mgsesend ng signal to pc na my nasense syang kotse na ipapasok naman nya sa database mo using sql
« Reply #15 on: December 28, 2009, 04:56:35 PM »
the Sensor will only give logic 1 or 0 to the MCU and the MCU will send the current status to the PC.. afterwards the PC will process the GSM Command/Instruction you will imply=)
Offline tondyay
« Reply #16 on: December 28, 2009, 05:13:37 PM »
ahh..okie2x po..i will try to implement your suggestions...salamat po.. keep you posted nlng sa improvement ng thesis namin..^__^
Offline emond
  • Long Live TAU GAMMA
    • emondsoft
« Reply #17 on: January 07, 2010, 11:08:03 AM »
for sending and receiving SMS using AT commands,9globe tattoo, you can contact me @
09212279363
YM: dark_raditz0825
www.emondsoft.qapacity.com
tnx
emond sabiniano
programmer/analyst-consultant
Offline tondyay
« Reply #18 on: February 03, 2010, 02:16:40 AM »
as for our project gumamit kami ng cellphone sony ericson at yung para sa rs23t gumamit kami ng max232 na circuit. ang problem nlng namin ngaun ay ung program sa pag interface sa project namin.. any suggestions po..ty..^^
« Reply #19 on: February 03, 2010, 04:29:17 AM »
can you communicate with the phone?
