Author Topic: 3310 no display no backlight  (Read 1849 times)
Offline jumong
« on: March 23, 2008, 08:33:55 AM »
any idea kung anong part ng phone ang dapat kulikutin
Re: 3310 no display no backlight
« Reply #1 on: March 31, 2008, 12:47:09 PM »
baka maluwag na yung buong LCD assembly lalu na duon sa connector part.  Isang buo kasi iyan pero yung connector di naman naka-fix, parang press-on lang.
  • Pogi/Ganda Points: 414
« Reply #2 on: March 31, 2008, 02:23:46 PM »
No display, No backlight? try mo txt or tawagan kung tutunog...or try mo call 112...if maka connect then sa no display sa lcd/lcd connector ka concentrate..
or else...baka CS (contact service) ang unit mo...
Offline vista
« Reply #3 on: April 01, 2008, 03:45:17 PM »
Greetings sa lahat! Jumong na-solve naba problem mo? may point si kasamiko, try mo dial 112 or "emergency call" at try mo pa-miscol ang number mo, kung di ka maka-contact sa 112 at di rin nag-ring even if you are sure na nasa "ON" status ito, baka "DEADSET" ang phone mo may problema sa hardware or software. check mo rin ang status ng battery mo or hiram ka muna ng battery sa iba baka battery lang ang problema.
kung wala talagang positive response ang phone mo, try mo na re-program bago ka tumira sa hardware nito, dapat talaga mauna ang software troubleshooting bago ang hardware troubleshooting............... Good Luck!  ;D :)
Offline jumong
« Reply #4 on: April 10, 2008, 12:31:19 PM »
may problema pala pcb trace na nakakabit sa baterry terminal.
Offline ahlburuto
  • E&I tech.
« Reply #5 on: April 10, 2008, 12:47:05 PM »
deadset po yang unit mo. kasi walang ilaw at display. common sira nya ay sa battery terminal. if nakalas mu na yung cp mo eh linisin mo ng eraser yung part kung saan nakadikit yung battery terminal. baka madumi na yun. try mo ding palitan ng ibang battery na me charge. pag ayaw pa din eh baka software na ang sira nyang unit mo.
Offline lesterbrazal
« Reply #6 on: October 03, 2008, 04:08:34 PM »
boss musta yung unit boss kailangan i reflash yung unit program po yan
