Author Topic: Samsung 2233sw monitor blacks out  (Read 830 times)
Offline wapax28
« on: January 02, 2010, 10:52:33 AM »
running naman po ang CPU, inboard po nakaplug yung monitor, pagbukas ko pa lang ng CPU mag flash lang yung brand ng mobo tapos black screen na, i turned off the monitor and turned it on again, mag didisplay lang yung monitor ko about 2 seconds then black screen na naman, tas ganun ulit turned off and on, 2 seconds display den black screen na naman, ncheck ko na po ung mga cables, pero ganun pa rin, ano po kaya problema??
alternatively ginamit ko ang laptop ko to test the monitor, pero same output, ganun pa rin, nag bablack out talaga, mukang monitor talaga ang problema, bakit kaya ganun?
Offline Vaounsi
  • Pogi/Ganda Points: 146
Re: Samsung 2233sw monitor blacks out
« Reply #1 on: January 02, 2010, 11:05:19 AM »
monitor cra nyn,karamihan nyan bloated ecaps, at cold solder, magresolder ka po..
Offline gie62
  • Pogi/Ganda Points: 56
« Reply #2 on: January 02, 2010, 05:58:30 PM »
pwedeng inverter o mahina na yung backlight nyan..pwede rin sa psu.
Offline I n s i d e r 2010
  • Pogi/Ganda Points: 100
« Reply #3 on: January 02, 2010, 10:03:55 PM »
resolder ka sa muna sa c board
check mga voltages saka post ka ulit d2 bro
Offline dan.enriquez
  • Pogi/Ganda Points: 52
  • Serbisyong Totoo
« Reply #4 on: January 02, 2010, 10:07:10 PM »
korak..
Offline wapax28
« Reply #5 on: January 03, 2010, 12:46:30 PM »
salamat po sa replies.. ill try your suggestions..
Offline marcialnasi
  • Pogi/Ganda Points: 35
« Reply #6 on: January 03, 2010, 09:33:56 PM »
pakicheck na rin ung mga grounding screws sa inverter module baka maluwag/
