Author Topic: Electric Motor as Generator  (Read 7233 times)
  • Pogi/Ganda Points: 524
Re: Electric Motor as Generator
« Reply #80 on: May 17, 2012, 11:43:56 AM »
Remember to consider the watts and not the V alone. you can up the V in the same size gen but the A will suffer anyway and you wil still get the same watts.
this is because the physical dimensions are constant or fixed, you can only increase the rpm to get higher voltages, but you are still limited by the motor size....
