Author Topic: PCB drill bit  (Read 2582 times)
Offline shinmin
  • Nobody gonna love me better I must stick with you
PCB drill bit
« on: March 23, 2008, 09:28:15 AM »
1/16" o 1/32" po ba yung pinakamaliit na size for PCB drilling?
PCB drill bit
Re: PCB drill bit
« Reply #1 on: March 23, 2008, 10:36:10 AM »
For resistor and capacitor component leads, 1/32 is the most common and the 1/16 bit maybe a bit big a hole to make.  1/16 bit for the ic sockets.  Sometimes, 1/16 bits are also not enough specially for high current rectifier diodes.  Just use a combination of both ..... generally use 1/32 and just enlarge the holes later on with the appropriate size bit.
Re: PCB drill bit
  • Pogi/Ganda Points: 412
Re: PCB drill bit
« Reply #2 on: March 23, 2008, 03:40:30 PM »
wala pa ba available na step drill? mas ok sana if meron nito..
Re: PCB drill bit
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
Re: PCB drill bit
« Reply #3 on: March 23, 2008, 11:30:59 PM »
mas maliit po ang 1/32
Re: PCB drill bit
Offline Macgyver
    • MakerDude
Re: PCB drill bit
« Reply #4 on: May 20, 2008, 06:29:35 PM »
saan ok bumili ng drill for pcb?  ano brand and how much nyo nabili yung inyo?
Re: PCB drill bit
Offline ahlburuto
  • E&I tech.
Re: PCB drill bit
« Reply #5 on: May 20, 2008, 07:30:50 PM »
meron akong step drill dito kaso malaki ang sie eh. from 5mm to 32mm... ???
hehehehe
br
Re: PCB drill bit
« Reply #6 on: May 21, 2008, 09:39:17 AM »
Sa mga FR4 na pcb's umiiyak yung hss na drill bit na made in china..hehehe...san kaya makakuha ng carbide tip?
Re: PCB drill bit
« Reply #7 on: May 21, 2008, 11:38:39 AM »
I bought one from DEECO ok nman cya malaki at powerful kya lang dapat may 12v 3amp ka source pra ok performance ang problem lang di ko napapagana ung speed control nya.
Wag lang kyo bibili nung sa mga mall na rechargeable (ung blue na idenedemo sa SM) ksi mahuna lalo na kung mataas ang humidity sa lugar nyo. Napuputol kci ung copper na naghohold sa brush gwa ng parang kalawang (ung sa akin ksi nakita ko ung negative terminal nakakabit ng direct sa copper).
Offline Macgyver
    • MakerDude
Re: PCB drill bit
« Reply #8 on: May 21, 2008, 12:01:02 PM »
magkano bili mo sa DEECO and may photo  ka ba dyan ?
Offline Born2BeWired
  • Pogi/Ganda Points: 168
    • e-Gizmo Mechatronix Central
Re: PCB drill bit
« Reply #9 on: May 21, 2008, 01:06:57 PM »
May local na mabibilhan kaya nito? Sa Hongkong pa kami dati nagpapabili nito...
Di talaga tatagal ang ordinary bit sa FR4. Carbide tip lasts much longer, problem lang, very brittle. Madaling mabali kung hindi steady ang kamay mo during manual drilling (drill press), and each one costs 300-500 pesos (ouch!).
Re: PCB drill bit
« Reply #10 on: May 21, 2008, 01:27:46 PM »
Yup...carbide tip requires at least 30k rpm! at dapat walang wobble yun ha..kaya hindi recommended sa mini hand drill..
Re: PCB drill bit
« Reply #11 on: May 21, 2008, 08:52:29 PM »
pwede naman sa Dremel at 18k RPM. pero kailangan talaga steady ang kamay.
mahal sa RS. pero naaalala ko meron.
may mga nabibiling carbide tip dito, pero hindi ko alam kung meron nung maliliit.
merong online, resharpened bits http://drillbitcity.com/
Re: PCB drill bit
