Author Topic: about z8f042Asj020sg modified board ng e-gizmo pls help po :(  (Read 792 times)
Offline dq3sm
« on: January 09, 2010, 05:07:33 PM »
Pahingi nmn po ng simple tutorial about this board na nbili nmin s e-gizmo
we have sample programs sa CD pero nalilito pa rin po kami kung panu i-execute ung mga files...
paturo din po 'bout sa configuration sa connection between module -> board -> PC (serial port)
kung anu po dpt nming gawin. ???
salamat po.
pahabol din po may alam po ba kung anu mga function nito:
eZ8asm
ez8cc
ez8lib
ez8link
grep
make
p1
p2
p3
naan dito po ba ung Build,Compile,connect and run button?
balak po kc namin gumawa ng pinasimpleng Studio using Vb un po kc suggest samin ng mga panelist
Offline dq3sm
Re: about z8f042Asj020sg modified board ng e-gizmo pls help po :(
« Reply #1 on: January 19, 2010, 10:40:11 PM »
Bump~ ko lng po nid ko po kc tlga...
ez8link - build/compile
pro d ko po makita ung Go button sa lib  :(
Offline mykelcos
  • iGnoRancE iS next tO bRilliAnce.
« Reply #2 on: August 25, 2012, 11:40:15 AM »
hello. nasolusyunan mo po ba ung problem nyo po dito? ito rin po problem ko ee :(
"little knowledge is dangerous...
that's why learning is a must."
