Author Topic: amplifier problem kenwood ka-555 vintage amplifier  (Read 2050 times)
Offline grizzom
  • Walang malayong kulangot sa mahabang kuko.
« on: January 12, 2010, 03:06:12 PM »
pinalitan ko na ung i.c ng amplifier ko kaso nung kinabit ko na ung speaker  2munog lan sandali ung speaker then nasunog na ung speaker anu pa kaya problem ng amplifier? kung my diagram po kayo pa share naman?  anu test kaya gagawin ko... gsto ko kc tunog ng vintage ampli.
thanks po...
  • Pogi/Ganda Points: 776
Re: amplifier problem kenwood ka-555 vintage amplifier
« Reply #1 on: January 13, 2010, 12:51:11 PM »
remove mo ang ic tapus sukatan mo ang voltage nya wagkang magpapalit ng ic kong dkapa sure kong tama ang voltage nya.. replace all resistor na makikita mong nag over heat/change value ,capasitor at transistor kong may driver pa.. paki post mo ang part # ng IC or hanap mo nalang sa datasheet4u.com
Offline danny
  • Pogi/Ganda Points: 324
« Reply #2 on: January 13, 2010, 12:54:43 PM »
mukhang malaki ang DC offset mo kaya nasunog speaker mo
pwede ka din gumamit ng dummy load
and better kung may variac ka din for troubleshooting
it will help you a lot.
danny
Online tony
  • Pogi/Ganda Points: 540
« Reply #3 on: January 13, 2010, 12:58:25 PM »
look for open resistors, there are flameproof types that look okey visually but testing reveals drifted value or worse nag-open na sya....in general, look for fried components and replace all of them before powering up...if you miss out on one, me problema ka...
unlless na merong kang +/100 mV na output offset, wag mo ikabit yung speakers, susunugin mo lang yon pag ikinabit mo kaagad...
Offline grizzom
« Reply #4 on: January 15, 2010, 08:19:43 AM »
thanks po sa reply sir i check ko try ko palitan muna lahat ng resistor.. i will update po kung anu ngyari..
Offline grizzom
« Reply #5 on: January 15, 2010, 08:25:45 AM »
@ mukhang malaki ang DC offset mo kaya nasunog speaker mo
Sir panu ba ung dummy load? cencia na po hindi pa ako ganun ka familiar kc computer po work ko pinagtyagaan ko lan ayusin ung ampli na un pag my free time ganda kc un nung ayus pa.
thanks po sa lahat ng comments i have idea na.
Online tony
« Reply #6 on: January 15, 2010, 08:36:34 AM »
ang objective mo sa repair ay maalis yung output offset voltage...pag nagawa mo yon...gagana na yung amp mo...
« Reply #7 on: January 15, 2010, 10:48:57 AM »
yon ang pamalit mo sahalip na speaker ang gagamitin pwede ang resistor
Offline pEN DoTA
  • Pogi/Ganda Points: 187
« Reply #8 on: January 15, 2010, 10:55:50 AM »
sundin mo lang ang relies ng mga master. remove muna ung IC at saka sukatin ang supply voltage. don't overlook the electrolityc capacitor, malaking part sa circuit un...
GOD LOVES YOU
Offline grizzom
« Reply #9 on: January 15, 2010, 12:08:51 PM »
thanks po mga master..
Offline pEN DoTA
« Reply #10 on: January 18, 2010, 11:21:27 AM »
kumusta na ung amp, any update?
GOD LOVES YOU
Offline de PatAtas
  • Pogi/Ganda Points: 330
  • ' The unbreakable
« Reply #11 on: January 21, 2010, 03:57:05 PM »
hai ,,po sa nyung lahat,,mga master..tanung ku lang po...sa dalawa po na rectifier diode 2 ampere galing po sa center top na transformer.....open po ang isa..pinalitan ku po nag fast recovery diode FR202 ok lang po ba...? gumagana naman po sya..JVC component system po ito..nag aalinlangan po kasi aku baka ba back job.
Offline grizzom
« Reply #12 on: January 22, 2010, 07:11:50 PM »
master ok na ung amp galing thanks a lot.
« Reply #13 on: January 22, 2010, 07:13:31 PM »
tika lang anong ginawa mo pa post naman para sa karamihan. thanks
Offline grizzom
« Reply #14 on: January 22, 2010, 07:15:20 PM »
pinalitan ko ung mga transistor at cap  and resistor d ko na check isa isa pinalitan ko nlg lahat mura lang naman para sure na ako d masisisra  ung iba.
Online tony
« Reply #15 on: January 26, 2010, 08:11:16 AM »
"shotgun approach" ang tawag dyan....
« Reply #16 on: January 26, 2010, 09:07:51 AM »
hahaha bahala na damay lahat hehehe
Offline khabod
« Reply #17 on: August 10, 2010, 04:14:41 PM »
mga master sa pagrerepair ng amplifier...
ano po kaya problem ng ampli ko lagi kc may humming tapos minsan pag sinalpak ko na guitar biglang may malakas na tunog na parang basag.
basta ganun po ang nangyayari.salamat po sa magrereply
tnx again....
