Author Topic: Arduino to PIC help...  (Read 2381 times)
Offline babytoybits
« on: January 12, 2010, 09:44:48 PM »
Hi masters...gumagawa po ako ngayon ng serial interface, nagawa ko na siya sa [im]duino (bought from sir wan... ;D) and I want to create a similar program for PIC...eto po ung arduino code at sana matulungan nyo ako kung pano siya gagawin sa PIC with the same output...thanks
*  ap_ReadMultiAnalog_2
*  Reads an two analog inputs and sends their values over the serial port.
*  Values are preceeded by an identifier (here letters 'A' and 'B') and after
*  each value a line break is sent.
*  This file is part of the Arduino meets Processing Project.
*  For more information visit http://www.arduino.cc.
*  copyleft 2005 by Melvin Ochsmann for Malmš University
// two variables for each input pin to read and store the values
  int analogInput_1 = 2;
  int analogInput_2 = 3;
  int value_1 = 0;
  int value_2 = 0;
// an identifier for each value
  int id_1 = 'A';
  int id_2 = 'B';
void setup() {
// declaration of pins modes
  pinMode(analogInput_1, INPUT);
  pinMode(analogInput_2, INPUT);
// begin sending over serial port
  beginSerial(9600);
void loop()
// read the values od the analog pins and store them in variables
  value_1 = analogRead(analogInput_1);
  value_2 = analogRead(analogInput_2);
// print out the variables preceeded by their IDs and followed by a carriage return
// (that allows us to know where the values end and when to expect the id)
    printByte(id_1);
    printInteger(value_1);  printByte(10);
    printByte(id_2);
    printInteger(value_2);  printByte(10);
// and wait shortly to not overload the port/board?
    delay(10);
I've already tried something on proton kaso hindi gumana...huhu
eto po yung ginawa ko:
'*  Name    : UNTITLED.BAS                                      *
'*  Author  : [select VIEW...EDITOR OPTIONS]                    *
'*  Notice  : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
'*          : All Rights Reserved                               *
'*  Date    : 1/11/2010                                         *
'*  Version : 1.0                                               *
'*  Notes   :                                                   *
' Device declaration
        Device 16F877A              ' Produce code for a 16F877
        XTAL = 20                  ' Use a 20MHz crystal
        ADIN_RES = 10                ' Set analog pins
        ADIN_TAD= FRC
        ADIN_DELAY=50
        ADCON0 = %00000001
        ADCON1 = %00001111
' Declaration of serial communication
        Declare HSERIAL_BAUD  = 9600                  ' Set baud rate to 9600,19200,38400,57600,115200
        Declare HSERIAL_RCSTA = %10010000       ' Enable serial port and continuous receive
        Declare HSERIAL_TXSTA = %00100000       ' Enable transmit and asynchronous mode
        Declare HSERIAL_CLEAR = On         ' Enable Error clearing on received characters
' Declaration of variables
        Dim BUFFER  As Byte           ' General storage
        Dim value_1 As Word
        Dim value_2 As Word
        DelayMS 200              ' Wait to stabilize
        value_1=0
        value_2=0
'sending analog values
Main:
        value_1 = ADIn 0
        value_2 = ADIn 1
        HSerOut["A",Dec value_1,10]
        HSerOut["B",Dec value_2,10]
        DelayMS 10
        GoTo Main
galing lang po ito sa sample codes, ineedit ko lang po...
Music is my passion but engineering will be my profession...^_^!
Offline babytoybits
Re: Arduino to PIC help...
« Reply #1 on: January 12, 2010, 11:14:09 PM »
Help... :'(
Offline Mayalin22
  • Pogi/Ganda Points: 402
« Reply #2 on: January 12, 2010, 11:51:53 PM »
try mo nga to
        @CONFIG_REQ
        @__config HS_OSC & WDT_OFF & PWRTE_ON & BODEN_OFF & LVP_OFF & WRT_OFF & CP_OFF & DEBUG_OFF
        ADIN_TAD= FRC
        ADIN_DELAY=50
        ADCON1 = %10000010  ' Right justify analogue result
        Dim value_1 As Word
        Dim value_2 As Word
        value_1=0
        value_2=0
Main:
        value_1 = ADIn 0
        delayms 100
        value_2 = ADIn 1
        delayms 100
        delayms 10
        DelayMS 10
        GoTo Main
Offline babytoybits
« Reply #3 on: January 12, 2010, 11:54:45 PM »
>>>trying... ;D
Offline babytoybits
« Reply #4 on: January 13, 2010, 12:03:50 AM »
wala parin syang output ate...ginamit ko yung USART tool ng mikrobasic pang test... :'(
Offline Mayalin22
« Reply #5 on: January 13, 2010, 12:09:41 AM »
proven na yan sis... baka sa usart ka me problema
Offline babytoybits
« Reply #6 on: January 13, 2010, 12:12:09 AM »
hmmm...anu po kayang problema d2, UART to serial na nga ng gizmo ginamit ko para sure e... :'(
Offline dan.enriquez
  • Pogi/Ganda Points: 52
  • Serbisyong Totoo
« Reply #7 on: January 13, 2010, 12:13:46 AM »
^^ang galing talaga ni IDOL COOLET na MALUPET...
Offline babytoybits
« Reply #8 on: January 13, 2010, 12:40:35 AM »
e2 po yung circuit...
Offline tiktak
  • Pogi/Ganda Points: 204
    • Tiktakx's Blog
« Reply #9 on: January 13, 2010, 01:23:34 AM »
sis gumamit ka ba ng level converter bago sa USB to serial?
8051 stuff
Offline babytoybits
« Reply #10 on: January 13, 2010, 01:35:25 AM »
ano po un?
napagana ko na po siya sa USART to RS232 ng e-gizmo...pero sa max232 d ko pa mapagana, ung schematic lang po sa proton tutorial ang ginaya ko... ???
Offline tiktak
    • Tiktakx's Blog
« Reply #11 on: January 13, 2010, 01:43:08 AM »
yung max232 po yun ;D
8051 stuff
Offline Mayalin22
« Reply #12 on: January 13, 2010, 03:22:33 AM »
parang mali connection mo sis...
Dapat cguro ganito (Direct connection) as per you diagram
LCD RX ----------- Micro TX (RC6)
LCD GND ---------- Micro Gnd
LCD TX ----------- No connection
pag ayaw pa din malamang sira na tx ng pic mo, kasi nagsalubong yong tx to tx
Offline babytoybits
« Reply #13 on: January 13, 2010, 05:03:22 PM »
ate gumana na po cya...
di po ako gumamit ng LCD, sa COMM port po ng computer cya nakakabit...ang ginawa ko ginamit ko ung UART to RS232 ng e-gizmo pero kapag sa max232 ayaw na po...
Offline tiktak
    • Tiktakx's Blog
« Reply #14 on: January 13, 2010, 05:08:53 PM »
There should be no problem pag gumamit ng MAX232 parehas lang dapat ang output maka may mali din sa max232 ckt mo baka baliktad din
8051 stuff
Offline Mayalin22
« Reply #15 on: January 13, 2010, 05:14:47 PM »
nice...  ;)
nakakalito din kasi minsan ang max232... be carefull sa tx/rx
PC RX------ < Max232 RX >TTL----------- Micro TX (RC6)
PC GND ----   Max232 GND --------------- Micro Gnd
PC TX ----- < Max232 TX >TTL----------- Micro RX (RC7
Offline babytoybits
« Reply #16 on: January 13, 2010, 05:33:43 PM »
nice...  ;)
e2 lang po connection nya? ang ginaya ko po kasi e yung sa proton tutorial...
Offline Mayalin22
« Reply #17 on: January 13, 2010, 05:44:23 PM »
Offline babytoybits
« Reply #18 on: January 13, 2010, 06:59:02 PM »
working na din siya sa max232...salamat ng marami ate coolet, may kiss ka sakin kapag nagkita tayo...hehe ;D
Offline Mayalin22
« Reply #19 on: January 13, 2010, 07:07:27 PM »
impakta ka wag na kiss magagalit fafah ko ;D ;D ;D
nice to help  ;D ;D ;D
