Author Topic: paint as HV insulation coating?  (Read 1017 times)
Offline RaffT
  • Pogi/Ganda Points: 103
  • more on R-n-D
    • MY Bots
« on: January 17, 2010, 04:34:24 PM »
guys,
 pwede kaya ang regular acrylic spray paint gawing light High voltage insulation?
 gamit kasi sa tesla coil ko, is PLASTIC VARNISH .. pero sobrang tagal mag CURE.. aabot ata ng 1 week..sobrang tagal...
 just checking if pwede...
 tnx :)
Offline nucleus
Re: paint as HV insulation coating?
« Reply #1 on: January 17, 2010, 04:47:26 PM »
guys,
 tnx :)
may lead content ang paint hindi ko lang alam yung clear acrylic kung meron, yung fiber glass resin pwede yon mabilis lang matuyo :)
Offline RaffT
  • more on R-n-D
    • MY Bots
« Reply #2 on: January 17, 2010, 05:25:45 PM »
ah ok... sorry hindi pala "colored" paint yung sinasabi ko kundi yung "clear gloss" or "topcoat" .... :)
I hope wala nga laman na LEAD yun(baka conductive)...
EDIT:
ano pala ang "common" name nito at saan pwede mabili? how FAST is the setting?
Offline nucleus
« Reply #3 on: January 17, 2010, 05:33:17 PM »
EDIT:
dito samin sa paint center nakakabili di ko kabisado yung talagang name pero kapag bumibili ako dito samin sinasabi ko lang "resin na pang fiber glass" ;D may kasama itong hardener tsaka cobalt 1 hour lang matigas na sya, ito mismo yung ginagamit ng nagfifiber glass :)
Offline OPTIMUS PRIME
  • Pogi/Ganda Points: 28
« Reply #4 on: January 29, 2010, 12:05:46 AM »
Sir say mo polyester resin yan ang chem name ng fiberglas chemccal na generically called resin(base material) tapos may kasama yan na hardiner ask mo kung may liquid sila pero meron yan sure yun.
 How fast yung setting depende sa dami ng hardiner. Mas madami mas mabilis pero side effect is madali magcrack. Para malabnawan ask for the thinner specific sa polyester.
Kung insist mo mabilis try to cool the chemicals having hinahalo dahil baka d mo pa malublub yung transfo mo tigas na.
With your week long prob na ayaw matuyo try to oven it. Pero wag mo biglain at masunog cyempre. Or ibabad mo sa araw.
For topcoat clear na acrylic matigas din yan you can go with it...or industrial floor paint pede din...same composition nyan sa fiber glass basta polyester....May isa din na pede epoxy paint may hardener din yan pero amide base pero medyo mahirap e work out pero mas mura sa polyester base
« Reply #5 on: January 29, 2010, 12:14:47 AM »
Sir cobalt yung nag papabilis sa pagtigas nyan kasam yung manganeses pero mas ok kung slow curing para wag madali mag crack or mabakbak.
For lead sa enamel lang cya gingamit...like quick dry kaya maski ala araw natutuyo cya. Heat at attck resistance di masyado maaasahan
Offline dan.enriquez
  • Pogi/Ganda Points: 52
  • Serbisyong Totoo
« Reply #6 on: January 29, 2010, 12:43:45 AM »
subukan mo rin sir yung electrical varnish na ginagamit din sa transformer..
mabilis lang yun matuyo..
