* 200 MHz ARM920T processor o 16 KB data cache and 16 KB instruction cache o MMU enabling Linux? and Windows CE? o 100 MHz system bus * MaverickCrunch? math engine o Floating point, integer and signal-processing instructions o Hardware interlocks for in-line coding * MaverickKey? IDs for digital rights management or design IP security (special order feature) o 32-bit unique ID o 128-bit random ID * Integrated peripheral interfaces o Graphics accelerator o Three-port USB 2.0 full-speed host (OHCI) o Three UARTs (16550 type) o IrDA interface, slow and fast mode o LCD interface with dedicated SDRAM channel o Touchscreen interface o SPI port o AC '97 interface o I?S interface, up to six channels o 8x8 keypad * External memory options o 32-bit SDRAM interface, up to four banks o 32-, 16- and 8-bit SRAM/Flash/ROM I/F o Serial EEPROM interface * Internal peripherals o Real-time clock with software trim o 12 DMA channels for data transfer that maximizes system performance o Boot ROM o Dual PLLs to control all clock domains o Watchdog timer o Two general-purpose 16-bit timers o General-purpose 32-bit timer o 40-bit debug timer * General-purpose I/Os (GPIOs) o 14 enhanced GPIOs including interrupt capability o 18 additional optional GPIOs multiplexed on peripherals * Package: 272-pin TFBGA; option for lead-free assembly and industrial temperature ratings
un ARM, pwde ba un linux as OS?
