Author Topic: Amp Inquiry  (Read 1110 times)
Offline b14s4
Amp Inquiry
« on: February 04, 2010, 09:17:06 PM »
Newbie here.
Just want to ask you guys if this amp can power a 10 inch sub. (car)
ito yung specs na nakita ko sa net. It the same exact model.
http://safemanuals.com/user-guide-instruct...AMPLIFICATOR-_E
Power output
60 watts x2 into 4ohms with 0.08% THD
80 watts x2 into 2ohms with 0.3& THD
160 watts x1 into 4 ohms with 0.3% THD
Frequency Response ~ 10 Hz to 50kHz
I searched the net may nakita ako na ginamit yung amp to power a pair of RF Punch SP-412 12" subs in a ported box.
I just want to confirm if this is feasible.
TIA
Amp Inquiry
Offline dan.enriquez
  • Pogi/Ganda Points: 52
  • Serbisyong Totoo
Re: Amp Inquiry
« Reply #1 on: February 04, 2010, 09:27:31 PM »
^ sir paki verify lang po yung freq. response medyo out of level..
Re: Amp Inquiry
Offline b14s4
Re: Amp Inquiry
« Reply #2 on: February 04, 2010, 09:41:09 PM »
Thanks for  the reply boss
Actually I just got the specs from the site that I mentioned above.
Currently, this amp powers my 2 rear 6.5 speakers. I just wanted to know if this baby can power an amp kahit 10" lang.
Thanks.
BTW: To the mods, paki move nalang po if mali ako ng place sa pagpost.
Re: Amp Inquiry
Offline jiggins20
  • Pogi/Ganda Points: 15
Re: Amp Inquiry
« Reply #3 on: February 04, 2010, 09:53:04 PM »
bridge mo ung amp....
Audio amp addict
Re: Amp Inquiry
  • Serbisyong Totoo
Re: Amp Inquiry
« Reply #4 on: February 04, 2010, 10:05:45 PM »
Thanks.
^ kung sa 10" spkr. sir tamang tama lang..
baka mahirapan narin yung amp kung medyo malaki na sprk na i didrive nya..
Re: Amp Inquiry
Offline b14s4
Re: Amp Inquiry
« Reply #5 on: February 04, 2010, 10:15:40 PM »
Meron pa bang sub na 10" which below 200 W (RMS)? I'm checking the dai ichi site pero mukhang down yung site to check their 10" sub specs.
Thanks.
  • Serbisyong Totoo
Re: Amp Inquiry
« Reply #6 on: February 04, 2010, 10:27:32 PM »
meron po sir..
karamihan sa mga home theater sub at 8 ~ 10",
meron din 12" na pataas..
try nyo po maghanap sa raon..
Offline b14s4
Re: Amp Inquiry
« Reply #7 on: February 04, 2010, 11:53:14 PM »
Thanks sa reply! Madami nga daw audio stuffs sa Raon. I'll try to scout around if time permits. Di naman ako maselan sa brand name and fo sure dito ko din bibilhin ang v12 amp ko hehehe.
Thanks.
  • Serbisyong Totoo
Re: Amp Inquiry
« Reply #8 on: February 05, 2010, 12:12:34 AM »
^ sa raon tetestingin nila yan mis mo para sayo..
Offline b14s4
Re: Amp Inquiry
« Reply #9 on: February 05, 2010, 12:31:34 AM »
Do you know any specific shop name that I can check? Thanks again.
  • Serbisyong Totoo
Re: Amp Inquiry
« Reply #10 on: February 05, 2010, 01:16:22 AM »
^ nakalimutan ko na mga supplier namin sa raon sir..
try nyo na lang po maglibot libot dun..
Offline b14s4
Re: Amp Inquiry
« Reply #11 on: February 05, 2010, 04:17:03 AM »
Thanks! Cheers to you boss!
  • Serbisyong Totoo
Re: Amp Inquiry
« Reply #12 on: February 05, 2010, 07:03:47 PM »
^ your always welcome sir..
Offline b14s4
Re: Amp Inquiry
« Reply #13 on: February 05, 2010, 09:58:09 PM »
pahabol lang hehehe
should I get the SVC or DVC
TIA
Re: Amp Inquiry
