Author Topic: UPS Problem  (Read 2853 times)
Offline Warstg_20
UPS Problem
« on: February 07, 2010, 12:02:29 AM »
 ;D ;D
Post nyo po d2 mga na-encounter na ninyong trouble sa UPS.
Kahit anong brand : mailiit man hanggang sa malaki...... etc...
1.  Tapos paano nyo ginawa?
2. Ano-ano mga Pinalitan ninyo?
3. Tsaka kung may mga schematics diagram kayo post nyo rin D2.
4. Etc..
http://lm-eccsc.blogspot.com/
http://warlitobaya.blogspot.com
"If YoU WeRE RiGHT No ONe's REMmeMBer, iF YOu WeRE WRoNG No ONeS FoRGet"
UPS Problem
Offline drin20
  • Pogi/Ganda Points: 17
Re: UPS Problem
« Reply #1 on: February 07, 2010, 12:38:44 AM »
pwedi po ba modify ang battery ng UPS? sa mataas na current?  para tumagal ang power?
Re: UPS Problem
Offline xycofreak
  • So What kung TESDA Graduate lang ako...
Re: UPS Problem
« Reply #2 on: February 10, 2010, 01:45:07 PM »
usually battery lang nmn kadalasan nasisira d2... refill lang ng alkaline
modification i doubt
Re: UPS Problem
  • Pogi/Ganda Points: 231
Re: UPS Problem
« Reply #3 on: February 10, 2010, 02:13:11 PM »
Pwede rin pero marami ka dapat e consider bago mapataas ang current rating ng Ups kasi design na talagayan ng Manufaturer..isa na dyan yung inverter capacity ng mga FETS, Transformer, current sensing circuit at etc.
pero kung mag aangat kalng ng current ng baterya gagana din yan huwag lang sobra ang taas makaka epecto na yan sa performance ng Circuit..sana makatulong
Re: UPS Problem
  • Pogi/Ganda Points: 413
Re: UPS Problem
« Reply #4 on: February 10, 2010, 02:21:14 PM »
Well consider mo rin ang heating effect nito dun sa FET mo mas mainit. I think component selection design makabase rin kung gaano ang itatagal sa UPS mode ng battery. Baka mag-alam ka masunog ito kasi ganitong minuto lang ang itatagal ng battery and then shutdown na sya.
Re: UPS Problem
Re: UPS Problem
« Reply #5 on: February 10, 2010, 02:22:36 PM »
Patanong na rin, ano ang gamit na solution sa Sealed type battery ng UPS?
Offline ian23jess
Re: UPS Problem
« Reply #6 on: February 12, 2010, 10:35:35 PM »
;D ;D
4. Etc..
reserve supply fault po para sa chloride 20kva EPEM adjust the SBS board into off position SW2.1=off SW2.2 =Off (for 220vac) and SW2.1 = On Sw2.2 =Off (for 230VAC) gawin mo lang ito kung ang ups mo ay nagaalarm dahil na sisense nya na ang reserve supply mo ay mababa pero tama naman ang mains input mo. yun lang po sa ngayon he he he he
Offline Warstg_20
Re: UPS Problem
« Reply #7 on: February 21, 2010, 12:50:21 PM »
Quote from: ian23jess
ano po ibig sabihin nyo master? saan po itong banda sa board?
If pwede master post naman po kayo ng screen shot if k lang.. ;D
Offline Warstg_20
Re: UPS Problem
« Reply #8 on: February 21, 2010, 12:57:34 PM »
ang parefill po ba n2 kailangan nako on ang UPs or Patay, kasi nakita ko ussually sa mga automotive shop, pagnalagay ng battery sulotion nako on ang makina...
thanks..
Offline Warstg_20
Re: UPS Problem
« Reply #9 on: February 21, 2010, 12:59:08 PM »
may mga nabilili po ba ng mga schematic ng diagram ng UPS..
Offline Warstg_20
Re: UPS Problem
« Reply #10 on: February 21, 2010, 01:07:00 PM »
May mga UPS po kasi me d2 na cra, pag-binibigyan nagload namamatay, ano po ba posible na cra n2?
thankssss..
Offline de PatAtas
  • Pogi/Ganda Points: 330
  • ' The unbreakable
Re: UPS Problem
« Reply #11 on: February 21, 2010, 02:57:20 PM »
' patay po dapat,,,kasi bubuksan mo yan eh,,,tapos ihiwalay mo po yung battery,,,pwede rin bumili ka nalang ng bagong battery pakita mu lang yung sample..
Offline Warstg_20
Re: UPS Problem
« Reply #12 on: February 21, 2010, 03:36:04 PM »
thanks po master kapyas
Offline de PatAtas
  • ' The unbreakable
Re: UPS Problem
« Reply #13 on: February 21, 2010, 03:56:28 PM »
 'welcome po...
Offline ian23jess
Re: UPS Problem
« Reply #14 on: February 21, 2010, 05:35:23 PM »
sir sensya na po confidential eh.. nasa university po kasi ako bk mahuli ako eh mapaaga pa uwi ko ng pinas he he hehe  kung sakali lang naman na mayron kang brand ng ups na ganito CHLORIDE 20KVA
about don sa board madali lang malocate dahil nakasulat na mismo sa board kung anong klaseng circuit sya binigyan lang kita ng idea para magamit mo kung sakali in the future he eh he he about naman doon sa mga ups mo baterya lang po ang problem its better bili ng ng VRLA type na baterya.. mas mahaba kasi ang buhay ng mga to.
Offline Warstg_20
Re: UPS Problem
« Reply #15 on: February 22, 2010, 06:48:19 AM »
thanks sir.. try ko pag-uwi mamamaya galing sa office..
Offline ctferndo
Re: UPS Problem
« Reply #16 on: March 09, 2010, 10:24:40 AM »
thankssss..
usually battery. if not, the power components like the MOSFETS / IGBTs or relays
Charlie Fernando
Offline ctferndo
Re: UPS Problem
« Reply #17 on: March 09, 2010, 10:30:17 AM »
Puede. pero you have to consider charging time/current of the battery. If you make the battery too large, the charger will take longer to fully charge the battery. The charging current may not be sufficient to charge the battery and you will end up destroying the battery.
Hope this helps.
Charlie Fernando
Offline Warstg_20
Re: UPS Problem
« Reply #18 on: April 05, 2010, 12:50:31 AM »
Salamat mga master..
Soory po sa late na Reply,. napalitan ko na po ng mga bagong battery ang mga UPS ko r2,..
Kaya lang may isa po sumablay, hehehehehe
ang nagyayari sa kanya pagsinukat mo ang output okey, pagnagsupply napo ako or sinaksak kuna ang PC sa kany namamatay.. (bago napo battery nya) Ano po magandang gawin dito?
thanks..
Re: UPS Problem
« Reply #19 on: April 05, 2010, 08:54:32 AM »
Hayaan mo na munang ma-charge ng walang load UPS mo, para mafull charge yung bagong battery. Initial charge lang karaniwan kapag bago para may basis kapag tinesting kung ok. Kung ordinary UPS katulad sa mga desktop computer 650VA hayaan mo na muna naka-on na walang load para makapagrecharge to full yung battery.
Sana makatulong.
Re: UPS Problem
