Author Topic: UPS Problem  (Read 2847 times)
Offline Warstg_20
Re: UPS Problem
« Reply #20 on: April 05, 2010, 04:42:25 PM »
Hayaan mo na munang ma-charge ng walang load UPS mo, para mafull charge yung bagong battery. Initial charge lang karaniwan kapag bago para may basis kapag tinesting kung ok. Kung ordinary UPS katulad sa mga desktop computer 650VA hayaan mo na muna naka-on na walang load para makapagrecharge to full yung battery.
Sana makatulong.
thanks po master jassharing . charge ko muna
http://lm-eccsc.blogspot.com/
http://warlitobaya.blogspot.com
"If YoU WeRE RiGHT No ONe's REMmeMBer, iF YOu WeRE WRoNG No ONeS FoRGet"
Re: UPS Problem
Offline Warstg_20
Re: UPS Problem
« Reply #21 on: October 20, 2010, 08:40:44 AM »
mga master patulong naman
may ups po ako d2 na may sound. .
(tik-tak) then mag-long beep sya. .
 bago po ang batery n2...
Re: UPS Problem
  • Pogi/Ganda Points: 411
Re: UPS Problem
« Reply #22 on: October 20, 2010, 11:18:54 AM »
Tatlo lang karaniwan codes nyan overloaded, over voltage o kailangan mo na naman ng initial charging ng battery. Lalo na at bago yang battery.
Charge mo sa external charger kung duda kang overvoltage ang ibig sabihin nung beep. Baka kasi may sirang component check mo na lang din.
Re: UPS Problem
Offline Warstg_20
Re: UPS Problem
« Reply #23 on: October 20, 2010, 11:28:16 AM »
thanks JS
charging na cya... pinabayaan kulang naka-plug sa outlet,. nawala nalang ang beep.. hehehehehhe
Re: UPS Problem
Re: UPS Problem
« Reply #24 on: October 20, 2010, 11:33:36 AM »
Baka nadrain yung battery tapos initial check ng ups di siya pasado kaya long beep siya.
Monitor mo na lang para sigurado.
Re: UPS Problem
Offline Warstg_20
Re: UPS Problem
« Reply #25 on: October 20, 2010, 12:23:02 PM »
opo master JS
Offline centOS
  • Pogi/Ganda Points: 45
  • screw the screw
Re: UPS Problem
« Reply #26 on: May 03, 2011, 08:43:40 AM »
nice thread. meron ako na post dito about sa powerware 3kva ko problem nya walang output pinalitan ko na ng battery lahat pero problem still parin...
anu kaya problem nito...
Offline x13r_kit_0
  • Pogi/Ganda Points: 149
  • --__x13r_kit_0__--
Re: UPS Problem
« Reply #27 on: May 03, 2011, 10:11:56 AM »
 subs po muna...balikan ko nalang to...
   =How about the other side?=
Re: UPS Problem
« Reply #28 on: May 03, 2011, 01:18:07 PM »
Baka may bumigay na Power FET?
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
Re: UPS Problem
« Reply #29 on: May 03, 2011, 01:23:26 PM »
Tip #1 Subscribing ;D
Re: UPS Problem
« Reply #30 on: May 03, 2011, 01:26:58 PM »
O kaya yung fuse?
Tip # 1 na lang uli.
Offline centOS
  • screw the screw
Re: UPS Problem
« Reply #31 on: May 03, 2011, 01:59:07 PM »
O kaya yung fuse?
ok ang fuse nya na check ko na ganyan den sagot sa thread ko pero ganun parin until now naka tambak pa ang unit.. hehe sana meron dito naka encounter ganun problem...
tia mga sis...
Offline de PatAtas
  • Pogi/Ganda Points: 330
  • ' The unbreakable
Re: UPS Problem
« Reply #32 on: May 03, 2011, 04:36:26 PM »
' bakit anu ba ang problema ng uPS?
Offline x13r_kit_0
Re: UPS Problem
« Reply #33 on: May 03, 2011, 04:41:22 PM »
 post mo mga links dito nun sis at balikan natin,.nu model pala yun..wala output,may power po ba..
Re: UPS Problem
« Reply #34 on: May 03, 2011, 05:12:08 PM »
Picturan mo yung internal para makita namin. Ng matuto rin.
Kasi 3kv, baterya ng auto ang nakalagay dito.
Offline centOS
  • screw the screw
Re: UPS Problem
« Reply #35 on: May 04, 2011, 10:36:40 AM »
Offline liam john
  • Pogi/Ganda Points: 9
  • bakit nag adik ka!!??
Re: UPS Problem
« Reply #36 on: June 17, 2011, 05:30:40 PM »
^may display ba sa front pannel nang UPS mo??
sa pagkatanda ko 8pcs. na 7ah ang battery nang ganitong model
dapat replaced mo lahat nang batt.
^ _^                                                   ^ _^
pag ayaw may dahilan pag gusto palaging mEron paraan"
Offline centOS
  • screw the screw
Re: UPS Problem
« Reply #37 on: June 18, 2011, 07:40:28 AM »
^yes meron display sa front panel sir... tapos lahat ng battery nito na replace ko na then charging overnight pero wala parin syang output pag testing.. [online naman ang display message sa panel nya ]
Re: UPS Problem
« Reply #38 on: June 18, 2011, 11:15:12 AM »
Matagal na palang nakatingga yan sis. Subukan mo kayang ikunsulta ki sir glutnix.
  • Pogi/Ganda Points: 231
Re: UPS Problem
« Reply #39 on: June 18, 2011, 11:16:25 AM »
sis anong brand ang UPS mo at anong model#?
Re: UPS Problem
