Thanks sis! Tuloy mo lang... dont hesitate kung may tanong ka pa. Make it more specific though para tackle natin 1 by 1... Goddluck!
@maryeanThat's right start with the basics. HTML then go on with other languages after you've learned enough to fully grasp the foundations. Para di ka masyado dependent sa mga tools.Dami ko na encounter applicants who say they are proficient with this or that language. Then sa exam naman hindi maka-gawa ng simple text box input or table layout using notepad. Marunong lang pala pag gumagamit ng WYSIWYG editor.The links provided by cirkitbored and others are more than sufficient starting points for your quest. Just ask kung may problema ka pa as you encounter them. Take it one step at a time. Sigurado maraming tutulong sayo dito.
@ElektroniC8But you also have to consider the inherent strengths and weakness of the choice of language to use. Some languages are more appropriate than others for a particular solution. Ex. some languages are better and easier to develop for web based customer-facing user interface, while a different language is better suited to handle number crunching back end operations. Both could be part of a single project.These as well as other factors like development time, hardware/resource dependencies, available libraries, monetary investment in additional training or support are all essential considerations from a business perspective.At the end of the day, it all boils down to how much extra effort you the programmer is willing to render to solve a customer's/user's problem. If you're confident that you can give a solution by using what you already know, go for it. If you're more flexible and the client has the budget and willing to wait, do more research or study a new language and try a different approach.
thanks sa mga comments... I really want to go Php but I am really into .NET programming since matagal ko na siyang gamit... maybe I'll go with ASP.NET way... maraming salamat!
