Author Topic: PIC16F84A-based LCD timer need help  (Read 960 times)
Offline su1c1d4l
« on: February 10, 2010, 04:20:04 PM »
Hi everyone! :)
Patulong nman po sa project ko, i need a timer (12-hour cycle) program displaying hours:minutes in the LCD with PIC16F84A . hnde pa po kc ako masyado marunong sa PIC programming eh. :-\ Bale yung project ko po mg aask xa kung anung time ise-set mo, first yung hours, then and minutes, pgkatapos at that time na naset mo mg aactivate ang AC lamps na nkakabit sa PORTA.
eto po ung schematic ng project ko.
Offline su1c1d4l
Re: PIC16F84A-based LCD timer need help
« Reply #1 on: February 18, 2010, 11:15:13 AM »
ay mali pala ung schematic.. ;D e2 na po:
Offline ajrob
« Reply #2 on: February 18, 2010, 01:16:16 PM »
hahahahaha!!! :D :D :D :D :D
hindi rin ako marunong sa pic!!!!!!
am very sorrrryyyy!!!! >:( >:( >:( ;D ;D ;D
« Reply #3 on: February 18, 2010, 01:18:57 PM »
what language and compiler ang gagamitin mo?
we can help you on how to program it, but i think we cant make the whole thing for you=)
Offline su1c1d4l
« Reply #4 on: February 19, 2010, 01:43:59 PM »
 :)  assembly po gamit ko and mpasmwin lg ung compiler. nagawa q na ang whole circuit with the relay, and currently im testing my program. hnd kc ako marunong sa tmr0 ng PIC16F84A, delay lg na subroutine gnamit ko as of now.  :-\
Offline su1c1d4l
« Reply #6 on: February 19, 2010, 02:14:43 PM »
thanks, il read this one for now.  :)
Offline ajrob
« Reply #7 on: February 19, 2010, 02:30:34 PM »
have fun in reading!!!!
« Reply #8 on: February 19, 2010, 02:47:11 PM »
goodluck=)
also you can find routines for the LCD in that book=)
Offline motion55
  • Pogi/Ganda Points: 244
« Reply #9 on: February 19, 2010, 03:09:20 PM »
Mali pa rin ata. The RESET pushbutton will short +5V to GND when pressed. Pin C1 of the switch should be connected to pin 4 of the PIC. Pero sa totoo lang, hindi mo kailangan ng RESET button. Pwede na tanggalin.
"Set your mind free!"
Offline su1c1d4l
« Reply #10 on: February 19, 2010, 04:48:53 PM »
thanks po sir!  :)
